Here you will learn how to create ladder diagram from Boolean logic and understand the basics of PLC.
Note: The PLC example shown here is for educational use only for students to understand PLC ladder diagrams.
Create Ladder Diagram
Problem Statement
Design a PLC ladder logic for the following Boolean Expression.
We are using toggle Inputs to control the output.
Find out the equivalent ladder logic for the given boolean logic.
 Y= AB+CD
Video
This video tutorial helps you to learn the creation of ladder diagram based on the given boolean expression.
Digital Inputs
The inputs listed below.
A: I0.0
B: I0.1
C: I0.2
D:I0.3
Digital Outputs
The outputs listed below.
Y: Q0.0
Boolean Logic Ladder Diagram
Program Description
- We used Schneider Electric EcoStruxure Machine Expert Basic software.
- In the above program, Normally Open Contacts are used for input A, input B, input C and input D.
- Input A and Input B are connected in series, thus implementing AND Logic Gate.
- There is again the implementation of AND Logic Gate as Input C and Input D are connected in series.
- There is also implementation of OR Logic Gate as AB and CD are connected in parallel.
- For the output Y (Q0.0) to be ON, Input A and Input B should be ON.
- Turning ON only one input i.e., either input A or input B will not turn ON the output Y (Q0.0).
- Turning ON Input C and Input D will also turn ON the output Y (Q0.0).
- If only one input i.e., either input C or input D is turned ON, then the output Y (Q0.0) will remain OFF.
Logic Result
Check the below logic output result with simulation.
When both Input A and Input B are ON
The signal will pass through Input A and Input B when turned ON. If only one input i.e., Input A or Input B is turned ON, the output Y (Q0.0) will not turn ON.
The inputs A and B are in series and are used as Normally Open Contacts. So, for the output Y (Q0.0) both the inputs i.e., input A and input B should be ON.
When both Input C and Input D are ON
When Input C and Input D are turned ON, the output Y(Q0.0) will turn ON. Input C and Input D implement AND Logic Gate as these are connected in series and are taken as Normally open Conatacts.
When both the inputs i.e., input C and input D are turned ON, then only the output Y (Q0.0) will turn ON, If only one input is turned ON i.e., only input C or input D is turned ON, the the output Y (Q0.0) will not turn ON.
- Types of Electrical Industrial Relays
- Project System Architecture Documents
- Double-acting Pneumatic Cylinder Logic
- Transferring Data Across PLC Systems
- Omron PLC Programming Training Course
