Reading: Concept of Latching in PLC
Inst Tools > Blog > PLC Tutorials > Concept of Latching in PLC
Last updated: March 4, 2021 3:27 pm
2 Min Read
Explain the Concept of Latching in PLC using relevant example.  Draw a Ladder Logic to control a bulb using push buttons in PLC with latching.
  • I0.0 : START (ON) push button.
  • I0.1 :  STOP (OFF) push button.
  • Q0.0 : output energize coil.
  • Q0.0 (CONTACT) : latch of output coil Q0.0
As soon as start push button is pressed, the contact I0.0 (N-O) becomes N-C . As the N-O contact I0.1 is already becomes the N-C (because of the normally closed push button in physical connections), the rung goes true and the coil(bulb) Q0.0 becomes energized.
Now, if the start push button is released then also the bulb will remain ON (here comes the concept of latching).
As soon as the coil Q0.0 gets energized, the latched contact of this coil which is represented as Q0.0 (N-O) becomes  N-C  and the logic will pass through this rung and remains the bulb ON even if the start push button is released.
If we want to switch OFF the bulb ,we simply have to press the stop push button .Due to pressing of stop push button the contact I0.1 becomes N-O (normally open) and rung logic goes  false, which in turn de-energizes the coil Q0.0 and switches OFF the bulb.
Light ON OFF Control using PLC
What is Motor Jogging ?
ON Delay Timer using PLC
PLC Motor Control Logic
Applications of SCADA
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Tutorial: Siemens Communication between PLCs using I-Device
XG5000 PLC Programming for Automatic Exhaust Fan
Global Acknowledgment Instruction in Safety PLC
How to do Simulation in Schneider PLC?
PLC Latching Function
How to use Converters in PLC
Ladder Diagram Example using Memory Bits and Set Coils
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
Moving Data between PLCs – Siemens Basics – TSEND TRCV
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Structured Text vs. Instruction List for PLC Programming
Free WinCC SCADA Training Course
Free SCADA Training Course
Introduction to Schneider PLC
Different Types of Schneider PLC
ControlLogix 5580 Controllers
Rockwell PLCs for Large Scale Applications
Online time of the PLC
System and Local Time in PLC
PLC Program for motor operation based on time cycle
PLC Motor Operation based on Time Cycle Sequence – Program
PLC SCADA Water Pump
PLC Program for Controlling a Water Pump with 3 Power Sources
Siemens PCS 7
What is PCS 7?
DCS Commissioning Steps
Difference Between AIS and GIS Panels
Flow Meter Hook Up
Flow Meter Installation Guidelines
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Shaper Machine Hydraulic Circuit Design
Hydraulic Shaper Machine – Components, Circuit, Principle
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
Process vessel for measuring water level
Level Measurement Lab Exercise
Valve Glossary
Valve Terminology Glossary
Distributed Network Protocol Communication
DNP3 Communication Protocol Overview
