Reading: What is Cobot? – Collaborative Robot
Inst Tools > Blog > Common > What is Cobot? – Collaborative Robot
A cobot stands for the collaborative robot. Cobot works in collaboration with human workers in doing a job.
Last updated: September 28, 2022 4:13 pm
Common
In this post, we will see the concept of a collaborative robot (cobot).
In Industry 4.0, robots play a very important role in revolutionizing the industry. Although robots are very useful in a particular industry, it also has some cons. Robots are completely capable of replacing a human being’s work. This somehow challenges the survival of the workforce in the industry.
Also, as they work independently, they automatically reduce human dependency, and thus the manpower is reduced in a company. This can steal the jobs of many people. Also, they are very costly, big in size, and complex in programming.
Collaborative Robot
To overcome this fear of losing jobs and reducing the complexity, cobots have been designed. A cobot stands for the collaborative robot. Basically, it is designed not to completely erase human presence; but to work hand in hand with him.
Cobot - Collaborative Robot
Cobot works in collaboration with human workers in doing a job. For example, suppose a human is doing a job with his two hands and he requires the other two hands to fulfill a complex job. That job is done by a cobot.
It is like a person working in tandem with another person. The only difference will be the cobot in place of that other person.
Cobot is relatively easier to program and by means of user-friendly software and mobile applications, it can easily learn new actions. It can thus be quickly used to perform different tasks.
A robot on the other hand will do only a particular task and if it’s required to do another task, it’s a hectic task to program it once again. Robots take normally a week or few days to setup and install. But a cobot takes normally half an hour to install and use.
You must be thinking that even a cobot is replacing other humans. But cobots are normally used in case of any emergency when that other person is not available for work with the first person.
The availability of a cobot in a very short time increases its flexibility to use in many situations. Also, if a condition arises that extra work has come and it is not possible to hire a person in such a short span of time. In this case, a cobot can easily do this work in place of a human and assist the other person is doing the job.
Cobots have a very high level of accuracy. It can achieve an accuracy of 0.1 mm and is thus more reliable than a person. Each and every task will be done with consistent repeatability and accuracy than a normal human being.
As cobots work in tandem with a human, it reduces the work security fear of an employee. They are designed to work with a human and not to replace a human.
Because cobots work in synchronization with Industry 4.0 applications like artificial intelligence, machine learning, IoT, etc. they easily increase the productivity and efficiency of factory output.
Cobots are used in various sectors of a company like logistics, manufacturing, supply chain management, etc. They consume less power and are less costly as compared to a robot. As they work near to a human, they always have collision detection programs running parallel to avoid conflict with persons nearby and endangering their lives.
  • Sensors in Automotive Vehicles
  • Wireless Electric Vehicle Charging
  • Compare Robotics and Automation
  • Automation in the Mining Industry
  • Industrial Automation Virtual Reality
Multiple Lags (orders)
Polyvinyl Alcohol in Oil Field
Mechanical Torsion Meter Principle
How to Use a Paint Thickness Gauge?
All About Electric Motors and Universal Motors
Engineering Logic Diagrams
What is Optical Modulation? – Methods of Optical Modulation
Automating Lab Data Reconciliation: Key Steps to Success
What is a Laser Sensor? Principle
Robot – Anatomy, Configuration, Reference Frame, Characteristics
Optical Torsion Meter Principle
Wet Dust Suppression System
Robot and Robotics – Laws, Components, Types, Advantages
Best Instrumentation Engineering Books to Purchase
Single Block and Bleed Valve Manifold
Single Block and Bleed Valve Manifold Operation
optical fiber cable junction box
Underwater Fibre Optic Cable
Stainless Steel CNC Machined Parts
Everything You Need to Know About Stainless Steel CNC Machined Parts
Hysteresis - 2
Hysteresis
Thin Film Deposition Systems
What is a Thin Film Deposition System? How do they work?
Isometric Projection
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 2
How is Electricity Generated From Solar Energy
How is Electricity Generated From Solar Energy?
Magnatic Level Indicators Working Animation
flow Nozzle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
Pressure Transmitter
Pressure Transmitter Animation
Calculate the amount of voltage at Thermocouple
Calculate the Voltage across Voltmeters of Thermocouple
Two Wire Transmitter Working Principle
Basics of Two, Three & Four Wire Transmitters
Parking Lights PLC Program Explained with Video
Permit to Work System Online Test
