Reading: Circular Chart Recorder Calibration Procedure
Inst Tools > Blog > Common > Circular Chart Recorder Calibration Procedure
Last updated: September 28, 2022 2:43 pm
R Jagan Mohan Rao
Common Guest Articles
3 Comments
2 Min Read
Barton Make Circular Chart Recorder. Can you help me out with the calibration procedures ?
Circular Chart RecorderCalibration Procedure:
Two types of Circular Chart recorders are available for pressure recording.
One type is applying direct process pressure. For Example 0-100 psi range.
Recorder need to be calibrated according to the operating range on dead weight tester, This is same like calibration of pressure gauge in Lab.
Another type works on output from 3-15 PSI signal from Pressure Transmitter.
Calibrate recorder at 3 psi as zero and 15 psi at full scale.
Step 1: Apply known range pressure by a dead weight tester or 3-15 psi by precision regulator.
Step 2: Apply full range pressure to recorder. Adjust linkage to recorder so that pointer is max reading on the chart scale.
Step 3: Reduce pressure to zero and check the pointer reads zero on the chart.Adjust pointer if necessary.
Step 4: Repeat the steps 2 and 3 until both readings are correct.
Step 5 : Recorder linearity adjustment by keeping the signal 50 % of max reading on the chart. Adjust 50%.
Step 6 : Check the reading for 0%, 50% and full scale. you may need to adjust many times till the recorder readings are correct.
Step 7 : Record all readings on Calibration sheet.
Difference Between Microcontroller and Microprocessor
Instrument Air Sizing
Instrumentation Word Game
What is Fuzzy Logic? Advantages, Disadvantages, Applications
Optical Torsion Meter Principle
3 Comments
  • Rajesh Das says:
    December 23, 2018 at 6:57 pm
    Thank you so very much for uploading the article on chart recorder calibration procedure. It would be great tool in carrying out the field assignments.
  • Vijay Methe says:
    April 26, 2023 at 12:47 pm
    Is it necessary to record time reading or Time calibration of Circular Chart recorder is essential?
  • Hans Koning-Bastiaan says:
    October 10, 2024 at 11:04 pm
    I have a foxboro Square root extractor, but not the calibration procedure.
    Do you have the calibration procedure and if so can I have a copy?
    I use them for educational purpose.
    Hans
Compressor & Compressor Valves Maintenance
What is IO-Link in Smart Manufacturing?
Internet of Things Communication Models (IoT)
DP Transmitter Dry Leg & Wet Leg Calculations
Best Software to Use in 2023 to Help Improve the Effectiveness of Your Business
Cable Shielding – Purpose, Selection, Grounding
Free Online Radiation Exposure Calculating Platform
Software Testing Projects
Software Testing Projects – How to Approach the Process Effectively?
Ceramic Bearings
Everything You Need to Know About Ceramic Bearings
control of pneumatic systems
Control of Pneumatic Cylinder and Motor
What is an Automated Guided Vehicle
What is an Automated Guided Vehicle?
Rotary Equipment
Modern Engineering Solutions for Rotary Equipment
Types of Switches
Electrical Switches Principle & Types
Difference Between Emergency STOP and Emergency Power OFF
Essential Safety Tips for Glass Workers
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
PLC program for Sorting System by Size Example
PLC Based Product Sorting Machine System – Lift Control
traffic light plc program
Valve Position Indication
Heat Exchanger Root Cause Analysis
Heat Exchanger Root Cause Analysis (RCA)
What is PLC Redundancy
What is PLC Redundancy?
Gang Switch Principle
Reading Electrical Schematics
VFD Interview Questions and Answers
