Reading: Capacitive Time Constant
Inst Tools > Blog > Electrical Theory > Capacitive Time Constant
Last updated: July 27, 2018 11:02 am
Electrical Theory
2 Min Read
When a capacitor is connected to a DC voltage source, it charges very rapidly. If no resistance was present in the charging circuit, the capacitor would become charged almost instantaneously. Resistance in a circuit will cause a delay in the time for charging a capacitor. The exact time required to charge a capacitor depends on the resistance (R) and the capacitance (C) in the charging circuit.
The below Equation illustrates this relationship.
TC = R C
where
TC = capacitive time constant (sec)
R = resistance (ohms)
C = capacitance (farad)
The capacitive time constant is the time required for the capacitor to charge to 63.2 percent of its fully charged voltage. In the following time constants, the capacitor will charge an additional 63.2 percent of the remaining voltage. The capacitor is considered fully charged after a period of five time constants (Figure 18).
Capacitive Time Constant for Charging Capacitor
Figure 18 Capacitive Time Constant for Charging Capacitor
The capacitive time constant also shows that it requires five time constants for the voltage across a discharging capacitor to drop to its minimum value (Figure 19).
Capacitive Time Constant for Discharging Capacitor
Figure 19 Capacitive Time Constant for Discharging Capacitor
Example:
Find the time constant of a 100 µF capacitor in series with a 100Ω resistor (Figure 20).
Example - Capacitive Time Constant
Figure 20 Example – Capacitive Time Constant
TC = R C
TC = 100 µF x 100Ω
TC = 0.01 seconds
DC Motor Speed
Compound Generators
4-Wire, Three-Phase Delta Wiring System
Kirchhoff’s Laws
Resonance, Resonant Frequency, Series and Parallel Resonance
Magnetism
Impedance
AC Induction Motor Slip
Series-Wound Motor
Conductor, Insulator, Resistor and Current Flow
Voltmeters
Ammeter
Simplified Formulas for Parallel Circuit Resistance Calculations
Circuit Breaker Control Circuit
circuit breaker principle
What is a circuit breaker ?
Voltage and Current Phase Relationships in an Inductive Circuit
Armature Current in a DC Motor
DC Motor Torque
Battery Interview QuBattery Interview Question and Answersestion and Answers
Battery Terminology
Power Triangle
Power Triangle
Calculate Power in Parallel RC Circuit
Lead Acid Battery charge
Discharge and Charging of Lead-Acid Battery
Phase angle
AC Generation Analysis : Effective Values, Phase Angle and Frequency
HART Transmitters Loop Checks
electric motor actuator principle
What is a Electric Motor Actuator ?
redundant transmitters
SIS Sensors
Draw the Symbols for Liquid Level Measuring Instruments
Electrical Machines MCQ Series 17
Geothermal Air Conditioners
Types of Air Conditioning Systems
PID Controller Tunning Manually
PID Controller Parameters Tuning Manually
Playground Swing Logic Exercise Program in PLC
