Reading: Calibration MCQ – Terminology and Glossary Questions
Inst Tools > Blog > Calibration > Calibration MCQ – Terminology and Glossary Questions
Try the calibration MCQ on terminology and glossary questions covering essential terms, principles, and applications.
Last updated: July 25, 2024 3:11 am
Calibration Instrumentation MCQ
12 Min Read
Calibration MCQWhat is Calibration?What is Drift in calibration?What is Zero Adjustment?What is Offset in calibration?What is As Found Data?What is Span?What is As Left Data?What is Factory Calibration?What is Measurement Uncertainty?What is Out of Tolerance (OOT)?What is Traceability?What is Test Uncertainty Ratio (TUR)?What is a Calibration Certificate?What is Calibration Interval?What is the purpose of a Calibration Curve?What is the significance of Environmental Conditions in calibration?What is the function of a Calibration Standard?What does Calibration Tolerance mean?What is Calibration Verification?What is Calibration Adjustment?What is Calibration Uncertainty?What is Calibration Due Date?What is Calibration Process?What is Calibration Report?What is the purpose of Calibration Labels?What is a Primary Standard in calibration?What is a Secondary Standard?What is Metrology?What is Resolution?What is Precision?What is Repeatability?What is Accuracy?What is Error?What is Linearity in calibration?What is Sensitivity?What is Hysteresis in calibration?
Calibration MCQ
This instrument calibration video provides detailed explanations for the objective questions and answers.
Calibration Glossary Basics: Q&A for Beginners
Question 1
A. Repairing an instrument
B. Verifying an instrument’s accuracy
C. Adjusting an instrument
D. Setting up an instrument
Show the Answer
Question 2
A. The smallest measurable value
B. Gradual change in an instrument’s measurements over time
C. The range of measurements an instrument can make
D. Sudden change in an instrument’s readings
Show the Answer
Question 3
A. Adjusting the span of the instrument
B. Setting the instrument’s maximum range
C. Adjusting an instrument to read zero at no input
D. Calibrating the instrument’s sensitivity
Show the Answer
Question 4
A. A constant deviation in measurement readings
B. The range of measurements an instrument can make
C. The consistency of measurements
D. The maximum measurable value
Show the Answer
Question 5
A. Data recorded after calibration
B. Data from the manufacturer
C. Historical performance data
D. Data recorded before calibration
Show the Answer
Question 6
What is Span?
A. The difference between maximum and minimum values
B. The average value of a range
C. The initial setting of an instrument
D. The maximum range of an instrument
Show the Answer
Question 7
A. Data recorded during calibration
B. Data from the instrument’s manual
C. Data recorded after calibration adjustments
D. Data from previous calibrations
Show the Answer
Question 8
A. Calibration done in the field
B. Calibration done by the user
C. Calibration done at regular intervals
D. Initial calibration done by the manufacturer
Show the Answer
Question 9
A. The doubt about measurement accuracy
B. The range of possible measurements
C. The smallest measurable value
D. The difference between measured and true values
Show the Answer
Question 10
A. Measurement exceeding acceptable limits
B. Final calibration value
C. Initial calibration value
D. Measurement within acceptable limits
Show the Answer
Question 11
A. The process of calibration
B. The ability to trace a measurement back to its source
C. The error in measurement
D. The precision of an instrument
Show the Answer
Question 12
A. Ratio of measurement uncertainty to tolerance
B. Ratio of test results to specifications
C. Ratio of test to measurement time
D. Ratio of errors in test
Show the Answer
Question 13
A. A certificate of instrument ownership
B. A document for instrument purchase
C. A manual for instrument operation
D. A document that verifies an instrument’s calibration status
Show the Answer
Question 14
A. The period between successive calibrations
B. The instrument’s operating time
C. The time taken to perform a calibration
D. The duration of instrument use
Show the Answer
Question 15
A. To indicate the calibration interval
B. To graphically represent the relationship between input and output
C. To show the instrument’s precision
D. To display the instrument’s range
Show the Answer
Question 16
A. They are irrelevant to calibration
B. They determine the calibration interval
C. They define the instrument’s range
D. They affect the accuracy and reliability of calibration results
Show the Answer
Question 17
A. To provide a reference value for accurate measurements
B. To define the calibration interval
C. To adjust the instrument’s zero point
D. To measure environmental conditions
Show the Answer
Question 18
A. The acceptable range of deviation from a specified value
B. The average measurement error
C. The smallest detectable change
Show the Answer
Question 19
A. The documentation of calibration data
B. The process of recalibration
C. Checking the calibration status without adjustment
D. The adjustment of an instrument’s settings
Show the Answer
Question 20
A. Setting the calibration interval
B. Documenting calibration data
C. Modifying an instrument to correct its measurements
D. Checking the calibration status
Show the Answer
Question 21
A. The smallest change an instrument can detect
C. The doubt associated with the result of a calibration
D. The precision of repeated measurements
Show the Answer
Question 22
A. The date of the last calibration
B. The instrument’s purchase date
C. The scheduled date for the next calibration
D. The manufacturing date of the instrument
Show the Answer
Question 23
A. The design of calibration equipment
B. The documentation of calibration results
C. The repair of a faulty instrument
D. A series of operations to establish and verify the performance of an instrument
Show the Answer
Question 24
A. A purchase record for the instrument
B. A manual for instrument operation
C. A certificate of instrument ownership
D. A document detailing the calibration results and procedures
Show the Answer
Question 25
A. To provide instructions for instrument operation
B. To show the instrument’s model number
C. To display the manufacturer’s details
D. To indicate the calibration status and due date of an instrument
Show the Answer
Question 26
A. The average of repeated measurements
B. The smallest detectable change
C. The highest quality standard used for calibration
Show the Answer
Question 27
A. The difference between measured and true values
B. A standard calibrated using a primary standard
D. The smallest detectable change
Show the Answer
Question 28
What is Metrology?
A. The design of measurement instruments
B. The science of measurement
C. The process of calibration
D. The repair of faulty instruments
Show the Answer
Question 29
What is Resolution?
A. The average measured value
B. The maximum range of an instrument
C. The smallest change an instrument can detect
D. The standard deviation of measurements
Show the Answer
Question 30
What is Precision?
A. The closeness of repeated measurements to each other
B. The accuracy of a single measurement
D. The range of possible measurements
Show the Answer
Question 31
A. The ability to measure the same value multiple times
B. The ability to measure different values accurately
C. The initial calibration value
D. The smallest measurable value
Show the Answer
Question 32
What is Accuracy?
C. The repeatability of measurements
D. The closeness of a measurement to the true value
Show the Answer
Question 33
What is Error?
A. The initial calibration value
B. The smallest change an instrument can detect
C. The difference between measured and true values
Show the Answer
Question 34
A. Deviation of an instrument’s response from a straight line
C. The consistency of an instrument’s measurements
D. The smallest change an instrument can detect
Show the Answer
Question 35
B. The consistency of measurements
Show the Answer
Question 36
A. The maximum value an instrument can measure
B. The lag between input and output
C. The average of repeated measurements
Show the Answer
  • Measurement and Calibration Questions
  • Flow Transmitter Maintenance and Calibration
  • Displacer Level Transmitter Calibration
  • Gas Flow Meter Calibration Procedure
  • Raw DataSheet for Pressure Calibration
How to Create Calibration Records?
Instrumentation Engineer’s Calibration Mistakes
Portable Gas Detectors Calibration Procedure
Measurements & Instrumentation Quiz – Set 3
Process Control & Instrumentation Objective Questions – Set 6
Analog Modulators Objective Questions
Analog Indicators Objective Questions
Bio Sensors Objective Questions
DeadWeight Tester Questions
Hydrogen Sulfide Gas Detector Calibration Procedure
Data Loggers Objective Questions
Common Valve Abbreviations in US Engineering Drawings
Instrumentation Engineering Students Test
Heat Flow Balance Systems Objective Questions
pH Analyzer Calibration and Troubleshooting
Uncertainty Calculations of Pressure Calibration
Calibration Sheet
Calibration : Up-tests and Down-tests
Measurements & Instrumentation Quiz – Set 8
Sampling Circuits Objective Questions
Methods of Measurement
How to Use SMD Components in Electronic Circuits
How to Use SMD Components in Electronic Circuits?
Industrial safety Objective Questions and Answers
Top 10 Industrial safety Objective Questions
As-found and As-left Calibration
As-found and As-left Documentation during Calibration
Save to Memory Card
How to Save a PLC Project to a Micro Memory Card?
Basic AC Generator
AC Generator Parts
Interface level Measurement
Interface Level Measurement using DP Transmitter
Procedure to test the TRIAC
How to Test TRIAC with Multimeter
DTMF Based Project Topics and Ideas
Top 100 DTMF Based Projects, Topics and Ideas
