Reading: RTD Calculator : Calculate Resistance from Temperature
Inst Tools > Blog > Instrumentation Tools > RTD Calculator : Calculate Resistance from Temperature
Last updated: November 12, 2019 5:02 pm
Instrumentation Tools Temperature Measurement
3 Comments
1 Min Read
RTD Conversion tool: T to R
This is used to calculate resistance value of RTD sensor from known temperature.
This calculation tool used to find out the resistance value of a RTD sensor with known temperature.
For RTD Calculation Formulas : Click Here
Note:
1.The above RTD calculation tool designed for a standard PT100 sensor.
2.If you are interested to calculate for a different RTD then change the fixed constant values as per the sensor type.
What is Temperature ?
Calculate Current (4-20ma) from Process variable PV
Why have been limits imposed on the frequency ratio for thermowells?
Temperature Sensor Failure
Thermocouple Temperature Measurement Errors
Components of RTD
3 Comments
  • Anonymous says:
    April 18, 2015 at 10:05 am
    Simply superb
  • durgasrinivas vadlamani says:
    May 30, 2015 at 6:18 am
    nice
  • viralparmar says:
    October 12, 2015 at 2:53 pm
    thanks
Applications of Temperature Scanner
Spiral Bimetallic Thermometer Principle
Convert Process Variable to Percentage
Temperature Gauges and Elements : Detailed Specifications
Basics of Thermocouples and RTD
RTD Testing Methods in Calibration Laboratory
Thermocouples Law of Intermediate Metals
What Temperature are Celsius and Fahrenheit Value Same ?
Convert-Percentage-to-current
Convert Percentage (0-100%) to current (4-20mA)
thermocouple types
What is a Thermocouple ?
Thermocouple Standard
Thermocouple Details
Loop Current Step Response (LCSR) Test for RTD
Response Time Test of RTD and Thermocouple
Temperature Calibration Bath
Temperature Calibration Bath Principle
Thermowell Immersion Length
Thermowell Insertion and Immersion Length
Use of Temperature Transmitters instead of Direct Wiring
Temperature Switch
Temperature Switch Working Principle
PLC Program for Water Level Control
PLC Program for Water Level Control Logic
Control valve characteristics
Valve Characteristics – Quick Opening, Linear & Equal Percentage
Square-Root extraction in DCS or Transmitter
Square-Root in DCS or Flow Transmitter?
Single-Phase Full Wave AC-DC Converter Questions
2 wire transmitter current loops
PLC Sizes and Applications
catalytic-gas-detectors-principle
Catalytic Gas Detectors Principle
Temperature Transmitter Foundation Fieldbus Configuration
Foundation Fieldbus Temperature Transmitter Configuration
