Reading: Cable Trays Glossary
Inst Tools > Blog > Erection & Commissioning > Cable Trays Glossary
Last updated: December 9, 2019 12:33 pm
3 Min Read
Accessories. Devices that are used to supplement the function of straight sections and fittings, and include such items as dropouts, covers, conduit adapters, hold-down devices, and dividers.
Cable Tray Connector. A device that joins cable tray straight sections or fittings, or both. The basic types of connectors are:
  • Rigid
  • Expansion
  • Adjustable
  • Reducer
Cable Tray Fitting. A device that is used to change the direction or size of a cable tray system.
Cable Tray Support. A device that provides adequate means for supporting cable tray sections or fittings, or both. The basic types of cable tray supports are:
  • Cantilever bracket
  • Trapeze
  • Individual and suspension.
Channel Cable Tray. A prefabricated metal structure consisting of a one-piece ventilated bottom or solid bottom channel section, or both, not exceeding six inches in width.
Ladder Cable Tray. A prefabricated metal structure consisting of two longitudinal side rails connected by individual transverse members.
Solid Bottom Cable Tray. A prefabricated metal structure consisting of a bottom with no openings within integral or separate longitudinal side rails.
Trough Cable Tray. A prefabricated metal structure greater than four inches in width consisting of a ventilated bottom within integral or separate longitudinal side rails.
Horizontal Cross. A cable tray fitting that is suitable for joining cable trays in four directions at 90-degree intervals in the same plane.
Horizontal Bend. A cable tray fitting that changes the direction in the same plane.
Horizontal Tee. A cable tray fitting that is suitable for joining cable trays in three directions at 90-degree intervals in the same plane.
Cable Tray System. An assembly of cable tray straight sections, fittings, and accessories that forms a rigid structural system to support cables.
Reducer. A cable tray fitting that is suitable for joining cable trays of different widths in the same plane. The basic types of reducers are:
  • Straight – A reducer with two symmetrical offset sides.
  • Right-hand – A reducer, when viewed from the large end, has a straight side on the right.
  • Left-hand – A reducer, when viewed from the large end, has a straight side on the left.
Straight Section. A length of cable tray that has no change in direction or size.
Ventilated Bottom. A cable tray bottom having openings sufficient for the passage of air and utilizing 60 percent or less of the plan area of the surface to support cables.
Vertical Bend. A cable tray fitting that changes direction to a different plane. The basic types of
vertical bends are:
  • Inside vertical – Elbow changes direction upward from the horizontal plane.
  • Outside vertical – Elbow changes direction downward from the horizontal plane.
What are the Mounting Techniques of Diaphragm Seals?
How to Install Thermowell on an Elbow?
Field Instruments Mounting brackets
Basics of Ground Loops
How to Install a Rotameter
  • yps says:
    July 9, 2017 at 8:42 am
    plz attached the picture of each tray .good job done by u.
What is Process Flow Diagram (PFD) ?
Instrument Tube Fitting Installation – Part 3
Impulse Tubing Leak Test Checks
P&ID Guidelines for Centrifugal Compressor Systems
What is Double Block and Bleed Valves?
Pressure Transmitters Installation Tips
Selection Guidelines for Cable Glands
Pipeline Project Management
Cut-outs between Platforms or Grating for Field Instruments
5-valve manifold
Slop Tank Level Transmitter Erection
Wrong Installation of Horn Type Radar Level Transmitter on Sloping Tank
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Monsoon Protection for Field Instruments and Junction Boxes
What is FAT and SAT?
P&ID arrangement for Control Valves
P&ID Guidelines for Control Valves
Programmable Logic Controller (PLC) Questions and Answers – 1
Difference between Feedback, Feedforward, and Cascade Control
Difference between Feedback, Feedforward, and Cascade Control?
Ladder Logic Example of Two Motors
Ladder Logic Example of Two Motors Interlinked with another Motor
Hybrid Solar Power System
energized-to-safe-loop
Basics-of-Gas-Chromatograph-Working-Principle
Working Principle of Gas chromatograph
Control Valves Flow Direction
Control Valve Flow Direction
