Reading: Bourdon Tube Pressure Gauge Advantages and Disadvantages
Inst Tools > Blog > Pressure Measurement > Bourdon Tube Pressure Gauge Advantages and Disadvantages
A Bourdon tube is a pressure measurement gauge device that is used for measuring pressure. Learn the advantages and disadvantages.
Last updated: July 12, 2024 11:48 am
Pressure is a very important parameter in industrial applications. Various types of gauges are used to measure pressure. A gauge is generally mounted on a skid pipeline and shows the current value in scales.
What is a Bourdon tube?Advantages of bourdon tubeDisadvantages of bourdon tube
Out of them, one of the most popular ones is a Bourdon tube pressure gauge. In this post, we will see the concept of the Bourdon tube pressure gauge and find its advantages and disadvantages.
A Bourdon tube is a pressure measurement gauge device that is used for measuring pressure. It is a circular tube which is bent and housed in a metal enclosure.
In this tube, one end is exposed to media pressure and the other end is closed. It is closed so that it can move freely and give us pressure value.
The tube is generally made of phosphor bronze, steel, or beryllium copper. These materials are instantly deflected when a pressure is applied to it. The deflection observed is proportional to the pressure applied. Refer to the below image for it’s working.
The tube is connected to a link, which when moved, also moves the pointer along with it. This pointer is nothing but the scale reading that we see on the meter. So, when a fluid pressure is applied in the tube, it starts to deflect. The more the pressure, the faster it will bend and correspondingly move the pointer quickly.
Bourdon Tube Pressure Gauge Parts
As the pressure reduces or becomes zero (moves away from the tube), the tube again starts to retract to its original position and the pointer too moves towards its original position.
In fact, the working is very clear from the image itself; pressure moves the tube, the tube moves the link along with it, and the link moves the pointer attached to it. Bourdon tube is usually practically filled with high-density media like water to avoid rapid fluctuations in readings, as the water will densely mix with the media to be measured.
This is depending upon the media to be measured. If the media is slow already and has a higher density than water, then no water is filled. Other internal components are mostly lubricated with silicone oil or glycerine for smooth movement and to prevent it from rust.
  1. As the working is pretty simple, bourdon tube pressure gauges are generally preferred in industrial applications for the simplicity they provide in maintenance.
  2. The readings of this scale are very accurate and that is why too, they are more preferred than other types.
  3. They work properly even in high-pressure conditions, so media with high pressure can also be applied in this tube for measurement.
  4. The installation and maintenance cost of this measurement is budget-friendly.
  5. It can also be used to measure vacuum pressure and other types of negative pressure inputs.
  1. They sometimes act slowly in response to pressure.
  2. They are sensitive to temperature changes and tend to malfunction more at lower temperatures.
  3. Shocks and vibrations many times hamper the performance of the gauge, as you get improper readings. It is also not good for the life of the gauge in longer terms.
  4. It is not generally used for low-pressure applications, as the tube requires a good amount of force to move it.
  • Pressure Gauge Problems
  • What is Submersible Pressure Transmitter?
  • Bourdon Tube Pressure Gauge Animation
  • Pneumatic Systems in the Automotive
  • Mounting Techniques of Diaphragm Seals
What are Pressure Sensing Lines? – Causes of Errors in Measurement
How Measurement Span of Pressure Gauge Could be Changed?
DeadWeight Tester Questions
Two-Liquid Manometer Principle
Pressure Gauges with Capsule Sensor Principle
15 HART Communicator Questions
Pressure Gauge Installation at Pump Discharge
How to Prepare Pressure Gauge Datasheet ?
Unbonded Strain Gauge Principle
What is a Submersible Pressure Transmitter? Principle, Advantages
What is Hammer Effect in Gauges ?
Types of Manometers
Troubleshooting Fluid Systems Pressure Changes
Differential Pressure Gauge Principle
Pressure Gauge Calibration Procedure
Pressure Sensor Specifications
Pressure Gauge Calibration according to Standard DKD-R-6-1
Sample Raw DataSheet for Pressure Calibration
Pressure Transmitter Calibration Setup
Pressure Transmitter Preventive Maintenance
Differential Pressure Sensor for Filtration Monitoring
Compression load cell Principle
Types of Load Cells
Stability in Frequency Domain
Realization of Basic Compensators
Filtering and Dynamic Compensation Objective Questions
List of 100 Sensors and Transducers Questions
Control Valves - Repeat Actuator Diaphragm Bursts
Control Valves – Repeat Actuator Diaphragm Bursts
burner management system P&ID
Solenoid Valves Questions & Answers – 1
Control Valve End Connection
Residual Current Circuit Breaker (RCCB)
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
