Reading: How to Blink Lights in Ladder Logic?
Inst Tools > Blog > PLC Tutorials > How to Blink Lights in Ladder Logic?
This article explains how to blink lights in ladder logic with a detailed explanation video for beginners and engineers.
Last updated: April 8, 2024 4:23 pm
This article explains how to blink lights in ladder logic with a detailed explanation video for beginners.
How to Blink Lights?Practical PLC Learning VideosDigital InputsDigital OutputsBlink Lights Ladder LogicProgram DescriptionPLC Program Summary
Note: The ladder logic example is designed for engineering students to practice PLC programming.
Problem Statement:
We are using one toggle switch to control the blinking of light.
Make a light blink with an interval of 2 seconds.
Our practical PLC learning videos help you master PLC programming with real-time examples.
How to Blink Lights in PLC Ladder Logic? - Programming Examples
Digital Inputs
The required inputs are shown below.
Start button: I0.0
Digital Outputs
The required outputs are shown below.
Light: Q0.0
Program Description
We used Normally Open Contact for the Start button.
For Light and memory bit, two Timer Functions Block Type TON and TP are used.
To keep the Light ON for 2 seconds, Timer Function Block type TP is used.
Timer Function Block type TON is used for the Memory bit to turn it ON after a delay of 2 seconds.
PLC Program Summary
How to Blink a Light Bulb with Ladder Language
The signal will flow also through the Normally Closed Contact that is used for memory bit as it is false state when the Start button is turned ON.
Timer functional block type TP (TM0) will allow the signal to flow for 2 seconds only. As a result, the Light will be turned ON.
After 2 seconds, the signal will not flow because of the Timer functional block type TP (TM0). The light will turn OFF after being ON for 2 seconds.
Blinking led ladder diagram
Simultaneously, when the Start button is turned ON and when the Light gets turned OFF after being ON for 1 s, the signal will flow through the Normally Closed contact used for Light. There will be a delay of 2 seconds and after that memory bit gets true.
In those 2 s, the Light will remain OFF. After a delay of 2 seconds, the coil used for the memory bit becomes true, and the Normally Closed Contact used for the Memory Bit will also become true. The Normally Closed Contact in its true state will break the circuit.
As a result, the coil used for the coil memory bit becomes false which in turn makes the Normally Closed Contact used for the memory bit false. The signal will again pass to the Light and it will be turned ON for 2 seconds. After that, it will remain OFF for 2 seconds and then it will repeat the process again and again.
Blinking output with time on and time off
  • PLC Programming Example with Motor
  • InTouch Scada using Scripting Tutorials
  • PLC Code to Start & Stop Motor and Pump
  • Electrical Ladder Diagram Control with Timers
  • PLC Important Questions and Answers
Safety Considerations in PLC System Design
Auto Sugar Bag Filling Station
Getting to Know the LED Indications on GE Make PLC
Difference Between Normal Counters and Fast Counters – Learn PLC
Push button Motor PLC Logic
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
#6 PLC Best Practices – Validate Timers and Counters
D Flip Flop PLC Ladder Logic
Compare Servo Motor and Stepper Motor
LS Electric PLC Program Example: Clothes Washing System
PLC Practice Questions
Top 100+ SCADA Questions
PLC Ladder Logic Design: Control 3 Motors with Toggle Switch
4 TO 20 MA ANALOG CURRENT SIGNALS
Structured Text Selector Machine Logic
Write a PLC Program for Selector Machine using Structured Text
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
Allen-Bradley PLC
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
PLC Ladder Logic Simulator Mobile Apps For Android
Masked Move Instructions
How to use Masked Move Instruction in PLC
Traces in TIA Portal
What is Trace Function in Tia Portal?
Node-RED in PLC Automation
Instrumentation Project Engineers Interview Questions
Instrumentation Project Engineer Interview Questions
Selecting a SIS or SIL Level
Importance of Safety Integrity Level
Turbine to Gearbox Alignment Drifts Caused Pump Transfers Problems
Download Modscan software
How to Use ModScan Software for Testing Modbus Communication?
YouTube Channels About Tech and Engineering
Awesome YouTube Channels About Tech and Engineering
Career Scope in Electronics Engineering
Types of Noise in Electronics
