Reading: Difference between Axial and Radial Diaphragm Seal Connection?
Inst Tools > Blog > Instrumentation Design > Difference between Axial and Radial Diaphragm Seal Connection?
Last updated: January 16, 2020 3:47 pm
Instrumentation Design Pressure Measurement
2 Min Read
The basics:-
Axial Diaphragm Seal ConnectionRadial Diaphragm Seal ConnectionHow this matters?Clearance Space considerationType of Diaphragm Seal
What is the difference between Axial and Radial movement mean?
Axial movement
Imagine a circle and you are in the middle of the circle.
Now you start jumping, this is axial movement.
Radial movement
From the center of the circle, you move to the end of the circle.
This is radial movement.
In other words movement along the radius of the circle is called radial movement.
A Practical example:-
Let’s take a case study of the vendor Badotherm
This vendor has a separate model number code to choose whether we want an axial or radial entry.
(Reference:- GS 06P01Y01-E-E 7th Edition)
Capillary Size
Note:- A majority of the vendor by default provides Radial capillary entry.
Now the difference can be seen from the picture below.
Image Courtesy: Yokogawa
How this matters?
Axial diaphragm seal requires clearance space in the X-Y plane.
While the Radial diaphragm seals clearance space in the Y-Z plane.
The type of diaphragm seal also dictates the connection type.
Example “Pancake” diaphragm seal requires a radial entry diaphragm seal.
Since a pancake diaphragm seal sits between two flanges axial entry is not feasible.
Thus depending on space consideration and type of diaphragm seal, etc appropriate diaphragm seal connection must be used.
In conclusion, the freedom of selecting radial and axial diaphragm seal connection depends on the available options with the vendor, type of diaphragm seal (Pancake type supports only radial connection), Space considerations, etc.
Author: Asad Shaikh
  • Diaphragm Seal Materials
  • Remote Seal Transmitter Errors
  • Temperature Error of Remote Seal
  • Calculation of Remote Seals
  • Applications of DP Transmitter
Top 10 Facts about HART Technology
How to Select a Rotameter? – Parameters and Applications
Level Instruments Design Rules
Why is an Instrument Process Datasheet Required?
Pressure Gauge Water Traps and Pigtail Siphons
  • azetou says:
    January 6, 2020 at 5:24 pm
    Thank you for your efforts.
How Earth Resistance is Measured
Differential Pressure Sensor for Filtration Monitoring
How to Measure Pressure in Inches of Water Column
Pressure Gauges Zero Adjustment
Differential Pressure Sensors Calibration Procedure
What is Marshalling Cabinet?
Normally closed input actuator as stop button.
Normally-Closed Contacts for Stop Buttons
Kv-value of a valve is determined by a standardised test
Calculate Flow Coefficient Kv of Solenoid Valve
Advantages of Pneumatic Systems in the Automotive Industry
Determine the statuses of all lamps and relay coils in the circuit
Determine the Status of Lamps and Relays in the Circuit ?
Basic Requirements of Sizing the Control Valves
Basic Requirements of Control Valves Sizing
DeadWeight Tester
DeadWeight Tester Questions
DIN Valve Connectors
DIN Valve Connectors – Definition, Types
PLC Logic for Water Pumping and Chemical Addition
Developing PLC Logic for Water Pumping and Chemical Addition
PLC Programmer Unknown Do's
Unknown Do’s Need to Know as a PLC Programmer
Automatic bending machine for exhaust pipe
PLC Logic for Automatic Bending Machine for Exhaust Pipe
DOL Starter Testing
DOL Starter – Working, Circuit, Advantages, Disadvantages, Applications
Shift Bit Register in PLC
Typical Switchyard Layout
Electrical Substation – Busbar Arrangements and Layouts
