Reading: Air Cylinder Consumption Calculation for Control Valves
Inst Tools > Blog > Control Valves > Air Cylinder Consumption Calculation for Control Valves
Last updated: September 28, 2022 2:40 pm
R Jagan Mohan Rao
Control Valves Instrumentation Design
The single-acting spring return cylinder:
These are just like the standard single-acting cylinders with the exception that they have a spring inside of them. At the completion of the power stroke, the spring helps to push the piston back to its initial starting position.
The single-acting spring return cylinder:The double-acting cylinder:Basic Calculations:Example 1:Example 2:
It is called double-acting because the cylinder has a power stroke on the push and pull. This type of double-acting cylinder is used primarily for mechanical devices.
Basic Calculations:
The Area is calculated by using basic algebra with regard to the bore.
To get the area we take half the bore and square it after that multiply it by Pi.
Once we know the area we multiply it by the pressure to get the force.
Formula for Force = Area x Pressure Area = (1/2 Bore) ^2 x Pi
The equation to determine how much gas from a tank: P1 x V1 = P2 x V2
Note: This formula is known as Boyle’s Law, which states “The volume of a given mass of gas is inversely proportional to the absolute pressure if the temperature remains constant”.
Let us assume for the moment that the temperature does remain constant.
 P1 = input pressure
V1 = input volume.
P2 i= output pressure
V2 = output volume.
Example 1:
A 88 cubic inch HPA tank with a 2500 psi tank pressure, 250 psi regulated pressure, and a double-acting cylinder with a 4″ bore and a 6″ throw with a 1″ rod to actuate a mechanical device.
Let us find out how much-compressed air is in the tank.
P1 x V1 = P2 x V2
2500 x 88 = 250 x V2
220000   = 250 x V2
220000 / 250 = V2
V2 = 880 cubic inches, at 250 psi
Example 2:
Using the example above, find out how much volume is in the cylinder using the formula
Volume = Area (bore) x Length (throw).
The Push Stroke V = ((1/2 bore)^2 x Pi) x throw
 V = ((1/2 4)^2 x Pi) x 6
V = (2^2 x Pi) x 6
V = 12.56 x 6 V
 = 75.36 cubic inches
The Pull Stroke Vrod = ((.5)^2 x Pi) x 6 Vrod = 4.71 cubic inches
 V = 75.36 (The Push Stroke V) – 4.71(The Pull Stroke Vrod) = 70.65 cubic inches
The total volume for the push, stroke (75.36), pull stroke (70.65)
If we add them together to get 146.01 cubic inches.
If we divide that number into the available volume that the tank has: Force = Area x Pressure
and we know that we have an area = 12.56 square inches on the face of the piston in the ‘push’ stroke
The area is equal to  (12.56 – 0.785) = 11.775 square inches on the face of the piston in the ‘pull stroke.
The Push Force = 12.56 x 250.
The Pull Force = 11.775 x 250
Reference
  • Control Valve Sizing
  • Types of Valve Actuators
  • Relation between Cv and Kv
  • Types of Failures in Valves
  • Control Valve Stroke Test
What is Swing Check Valve ?
Compliance Table Application (for Procurement Service Cycle)
Types of Pilot Operated Diaphragm Solenoid Valve Principle
Rotork Motor Operated Valve Basic Configuration
Control Valve Fail Safe Action
Level Instruments Design Rules
  • ROHITH KUMAR SAINI says:
    May 17, 2020 at 1:28 pm
    I understand that the air consumption for a single pull and a single push stroke is calculated. Adding them we get consumption a single cycle. This article is very helpful for design Engineers.
Control Valve Sequence Methods
Pneumatic Valves and Cylinders Sizing – Part 2
What is a 3-way Solenoid Valve ?
Safety Relief Valve Quiz: Test Your Knowledge
Control Valve Erosion Problems
Valve Seat Leakage Test
Classification of Gate Valves
Thermowell Insertion and Immersion Length
Fail-Close Valve
What is a Fail-Close Valve? – Advantages and Disadvantages
valve trim characteristics
Control Valve Trim Characteristics
Control Valve Positioner Working Principle
Axial Diaphragm Seal Connection
Difference between Axial and Radial Diaphragm Seal Connection?
Control Valve Selection Guide
Earth Meter Working Principle
How Earth Resistance is Measured
Difference between Rotary Shaft and Sliding Stem Control Valves
Difference between Rotary Shaft Valves and Sliding Stem Control Valves
Calibration & Preventative Maintenance Procedures
Calibration and Preventative Maintenance Procedures
Distributed Control System Architecture
shunt-capacitor-advantages-in-power-system
Shunt Capacitor Advantages in Power System
Thermocouples Green Rot Effect
Control Valves Pre-Commissioning Checklist
Power Systems Projects
400+ Power Systems Projects – Best Electrical Project Ideas
What Every Instrument Engineer Should Know
What Every Instrument Engineer Should Know?
Parts of Steam Ejector
Working Principle of Steam Ejector
