Reading: Advantages and Disadvantages of Valve Actuators
Inst Tools > Blog > Control Valves > Advantages and Disadvantages of Valve Actuators
Last updated: September 11, 2020 12:20 pm
Control Valves
A valve actuator is the mechanism for opening and closing a valve. Manually operated valves require someone in attendance to adjust them using a direct or geared mechanism attached to the valve stem. Power-operated actuators, using air pressure, hydraulic pressure, or electricity, allow a valve to be adjusted remotely or allow rapid operation of large valves.
Valve ActuatorsSpring and diaphragm ActuatorsAdvantagesDisadvantagesHigh-pressure spring and diaphragm ActuatorsAdvantagesDisadvantagesPneumatic piston ActuatorsAdvantagesDisadvantagesElectric motor ActuatorsAdvantagesDisadvantagesElectro-Hydraulic ActuatorsDisadvantages
These valve actuators may be the final elements of an automatic control loop which automatically regulates some flow, level, or other processes. Actuators may be only to open and close the valve, or may allow intermediate positioning; some valve actuators include switches or other ways to remotely indicate the position of the valve.
Valve Actuators
Advantages and Disadvantages of Valve Actuators like Spring and diaphragm Actuators, Pneumatic piston Actuators, Electric Actuators, Hydraulic Actuators.
Spring and diaphragm pneumatic actuators can be “direct-acting”, meaning that air to the diaphragm casing pushes the actuator stem downward. This “air-to-close” action compresses the spring, which in turn pushes the actuator stem back up when the supply pressure is decreased or lost.
Additionally, spring and diaphragm pneumatic actuators can be “reverse-acting”, meaning that air to the diaphragm casing causes the actuator stem to move upward. This “air-to-open” action compresses the spring, which in turn causes the actuator stem to move downward when supply pressure is decreased.
Advantages
  • Lowest cost
  • Ability to throttle without positioner Simplicity
  • Inherent failure-mode action
  • Low supply-pressure requirement
  • Adjustability to varying conditions
  • Ease of maintenance
Disadvantages
  • Limited output capability
  • Large size and weight
Spring-based actuators hold back spring. Once the command was sent to the valve or power is lost, the spring is released, then it will operate the valve.
Advantages
  • Compact, lightweight
  • No spring adjustment needed
  • Costly cast components not needed
  • Inherent fail-safe action
  • No dynamic stem seals or traditional stem connector block needed
  • Design can include integral accessories
Disadvantages
  • Requires high supply pressure 40 psig (2.8 bars) or higher
  • Positioner required for throttling
A pneumatic control valve actuator converts energy (typically in the form of compressed air) into mechanical motion. The motion can be rotary or linear, depending on the type of actuator.
A Pneumatic actuator mainly consists of a piston that develops the motive power. It keeps the air in the upper portion of the cylinder, allowing air pressure to force the diaphragm or piston to move the valve stem or rotate the valve control element.
Advantages
  • High force or torque capability
  • Adaptable to high ambient temperatures
  • Fast stroking speed
  • Relatively high actuator stiffness
Disadvantages
  • Fall-safe requires accessories or the addition of a spring
  • Higher cost
  • High supply-pressure requirement
An electric actuator is powered by a motor that converts electrical energy into mechanical torque. The electrical energy is used to actuate equipment such as multi-turn valves.
Advantages
  • Compact
  • Very high stiffness
  • High output capability
  • Supply pressure piping not required
Disadvantages
  • High cost
  • Lack of fail-safe action
  • Limited duty cycle
  • Slow stroking speed
Hydraulic systems work because of Pascal’s law, which states that an increase of pressure in any part of a confined fluid causes an equal increase of pressure throughout the container. If force is applied to one part of a hydraulic system, it travels through the hydraulic fluid to the rest of the system.
Advantages
  • High actuator stiffness
  • Excellent throttling ability
Disadvantages
  • High cost
  • Complexity and maintenance difficulty
  • Fail-safe action only with accessories
Electro Pneumatic Valve Positioner Schematic & Principle
Valves Pressure Loss – Questions and Answers
Why we Measure Control Valve flow coefficient (Cv)?
Types of Valve Leakage Tests
Classification of Solenoid Valves
Compare Relief Valve and Safety Valve
  • Davidson Alert says:
    July 14, 2021 at 12:33 am
    Greetings to all,
    Please can l have books covering all these topics.
Globe Valve Seat and Disk
Control Valve Preventive Maintenance
What is an Unloading Valve? – Types, Principle
Air Filter Regulator Working Principle Animation
Introduction to Types of Valves
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Bellows Seal Valve Working Principle
Difference between Globe Valve and Gate Valve ?
Choked Flow of Control Valve
Choked Flow of Control Valves
cut-away control valve
How Globe Valves Work ?
DIN Valve Connectors
DIN Valve Connectors – Definition, Types
pilot operated relief valves
Pilot-operated Relief Valve Principle
What is Swing Check Valve ?
Blowdown Valve (BDV) and Shutdown Valve (SDV)
Difference between Blowdown Valve (BDV) and Shutdown Valve (SDV) ?
Steam conditioning valves
Concept of Steam Conditioning Valves
Control Valve Packing
proximitor module
Bently Nevada Vibration System Verification Procedure
Power Supply Voltage Regulator Problem
Troubleshooting a Power Supply Circuit
Y Body Globe Valve
Globe Valve Body Design
What is electrical transformer
Transformer Impedance Ratio
Centrifugal Compressor outage reduced
Centrifugal Compressor Outage Reduced – Root Cause Analysis
Rotating Electrical Machines Quiz
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Flow Switch Principle
In-Line Flow Switch Working Principle and Animation
