Reading: 10 Questions on Reforming Furnace Control System
Inst Tools > Blog > Practical Questions > 10 Questions on Reforming Furnace Control System
Last updated: March 16, 2020 7:57 am
Practical Questions
3 Min Read
Reforming furnaces are special process furnaces used to generate pure hydrogen gas from a hydrocarbon feed gas, such as methane.
The balanced chemical reaction for this process is as follows:
CH4 + H2O → 3H2 + CO
Methane gas (CH4) added to steam (H2O) at high temperatures forms hydrogen gas (H2) and carbon monoxide gas (CO), the latter converted into CO2 and more hydrogen gas in subsequent reactions. The chemical reaction is endothermic, meaning that it requires energy input rather than liberating energy (as what happens in an exothermic process such as combustion).
Typically, the reaction takes place in the presence of a catalyst. A simplified control system for a reforming furnace is shown here:
1. What factor or factors determine the setting of the multiplying constant k? Is this factor something that is liable to change much? Why or why not?
Answer: Stoichiometry is the primary determining factor for the value of k: setting the methane and steam mass flow rates such that the proper numbers of molecules of each enter the reaction furnace to produce hydrogen and carbon monoxide gas.
2. Explain what would happen in this process if the methane flow transmitter failed with a low signal.
3. Explain what would happen in this process if the methane flow transmitter failed with a high signal.
4. Explain what would happen in this process if the steam flow transmitter failed with a low signal.
5. Explain what would happen in this process if the steam flow transmitter failed with a high signal.
6. Explain what would happen in this process if the methane control valve failed fully shut.
7. Explain what would happen in this process if the methane control valve failed wide-open.
8. Explain what would happen in this process if the steam control valve failed fully shut.
9. Explain what would happen in this process if the steam control valve failed wide-open.
10. Explain what would happen in this process if some of the catalyst-filled tubes were to become partially plugged with carbon (coke) deposits.
Join the Discussion! Share your answers with us through below comments section.
  • Ratio Controller Example
  • Circular Chart Recorder
  • Flow Measurement Questions
  • Stripper Overhead Temperature
  • Feedforward Control
Electronic Pressure Sensor with Bourdon Tube and LVDT
Sketch a Ladder Diagram for PLC to Energize the Lamp
Simple Pressure Repeater
Programmable Logic Controller (PLC) Questions and Answers – 5
Level Measurement Lab Exercise
Questions on Level Switches
Programmable Logic Controller (PLC) Questions and Answers – 11
Surface-mounted Water Pump
Compressor Emergency Shutdown Root Cause Analysis
How Measurement Span of Pressure Gauge Could be Changed?
Thermocouple Terminal block Questions
Identify High and Low Ports on Pneumatic DP Transmitter
Vertical Tube Liquid Level Equilibrium
DP Transmitter Block and Bleed Valves
Programmable Logic Controller (PLC) Questions and Answers – 7
PLC Program three-phase electric motor
Identify the Problem in the PLC Program
pH Monitoring System Triggers an Alarm
PLC program to control a water pump
PLC Program to Control a Water Pump
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Loop Powered Pressure Transmitter
Drum Level differential pressure transmitter
Calculate Differential Pressure Sensed by Level Transmitter
level control system
Practical Process Control System Questions & Answers – 10
Temperature Calibration Bath
Temperature Calibration Bath Principle
Differential Pressure Transmitter Question
Differential Pressure Transmitter Questions
Instrumentation Thread
Thread Sealant Types and Selection for Instrumentation Applications
PLC Programming Example on Bottle Line Control
Signal Flow Graphs Objective Questions
Hydrogen and Glass Electrodes Questions & Answers
Difference Between Cyclic and Acyclic Communication
Dependent Voltage Source
