This article is about communication between InTouch SCADA and Allen Bradley PLC with a ladder logic example with screenshots.
InTouch Scada and Allen Bradley PLC
Do follow the below steps for establishing the communication process.
Step 1:
Open RSlogix software along with RSlinx and emulator.
Step 2:
Create a new project in RSlogix and established communication with an emulator.
Step 3:
Open InTouch SCADA software.
Step 4:
As you can see in the below window of RSlogix I have created a small example with one input and output.
In branch, I have use memory bit which we will use in SCADA to give a command.
![RSLogix Micro Starter Lite](https://instrumentationtools.com/wp-content/uploads/2015/11/RSLogix-Micro-Starter-Lite.png)
Step 5:
Now, let open RSlinx. Click on option “DDE/OPC” and choose “topic configuration”.
![RSLinx Configuration](https://instrumentationtools.com/wp-content/uploads/2015/11/RSLinx-Configuration.png)
Step 6:
Following window will pop-up. Choose “New” to proceed.
![DDE OPC Configuration](https://instrumentationtools.com/wp-content/uploads/2015/11/DDE-OPC-Configuration.png)
Step 7:
Create a new topic as I have created communication and choose communication protocol. Click “apply” then “done” to proceed.
![MicroLogix 1000](https://instrumentationtools.com/wp-content/uploads/2015/11/MicroLogix-1000.png)
Step 8:
Now open InTouch SCADA. Create a new project.
As we have used one input and output we have to create one input button and output button as shown in the below window.
![InTouch Window Maker](https://instrumentationtools.com/wp-content/uploads/2015/11/InTouch-Window-Maker.png)
Step 9:
Hit double click on a button will open up the following window. Choose “Discrete” will open up a new window.
![Discrete Inputs in InTouch](https://instrumentationtools.com/wp-content/uploads/2015/11/Discrete-Inputs-in-InTouch.png)
Step 10:
Give a name to button and hit “ok” to proceed.
![Tagname in InTouch](https://instrumentationtools.com/wp-content/uploads/2015/11/Tagname-in-InTouch.png)
Step 11:
Choose I/O Discrete in the “Type” option. Then click on “access name”.
Write a bit address in “item” for input which we have used in the programming software (check step no. 4).
![InTouch Access Name](https://instrumentationtools.com/wp-content/uploads/2015/11/InTouch-Access-Name.png)
Step 12:
Clicking on Access name will open another window. Click on “add” as shown in the below window.
![InTouch Tagname Dictionary](https://instrumentationtools.com/wp-content/uploads/2015/11/InTouch-Tagname-Dictionary.png)
Step 13:
This is a very important step to establish communication.
Access: Give any name
Application name: RSlogix
Topic name: communication (the same name we have used in step no. 7)
Choose “DDE” as a communication protocol and hit “ok” to proceed.
![Add Access Name in Scada](https://instrumentationtools.com/wp-content/uploads/2015/11/Add-Access-Name-in-Scada-1.png)
Step 14:
After configuration hit “save” and close the pop-up.
![Save InTouch Scada](https://instrumentationtools.com/wp-content/uploads/2015/11/Save-InTouch-Scada.png)
Step 15:
For output, we have select “fill color” property and choose “Discrete”.
![Fill Color InTouch Scada](https://instrumentationtools.com/wp-content/uploads/2015/11/Fill-Color-InTouch-Scada.png)
Step 16:
Do follow the same procedure for output as shown in the below window.
![Type of IO in InTouch Scada](https://instrumentationtools.com/wp-content/uploads/2015/11/Type-of-IO-in-InTouch-Scada.png)
Step 17:
Communication has established. Test the logic. Keep a window in “runtime” and put CPU in “run” mode.
As you can see in the below window output gets energized if I give the command from SCADA.
![Communication between Intouch Scada and Allen Bradley PLC](https://instrumentationtools.com/wp-content/uploads/2015/11/Communication-between-Intouch-Scada-and-Allen-Bradley-PLC-1.png)
Author: Suhel Patel
- Quiz Questions on Motors
- Modifying PLC Programs
- Field instrument to Control Room
- What is SCADA System?
- Siemens Profinet Configuration
is intouch scada free version is available?
Yes, available
Can I communicate using RSLinx classic lite or gateway is must
