  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Valve Functions and Basic Parts of Valve
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Control Valves > Valve Functions and Basic Parts of Valve
Last updated: November 18, 2019 7:59 pm
Control Valves
3 Comments
13 Min Read
valve is a mechanical device that controls the flow of fluid and pressure within a system or process.
Valve Functions and Basic PartsValve BodyValve BonnetValve TrimDisk and SeatStemValve ActuatorValve PackingTypes of ValvesSummary
A valve controls system or process fluid flow and pressure by performing any of the following functions:
  • Stopping and starting fluid flow
  • Varying (throttling) the amount of fluid flow
  • Controlling the direction of fluid flow
  • Regulating downstream system or process pressure
  • Relieving component or piping over pressure
There are many valve designs and types that satisfy one or more of the functions identified above.
A multitude of valve types and designs safely accommodate a wide variety of industrial applications.
Regardless of type, all valves have the following basic parts:
  • the body,
  • bonnet,
  • trim (internal elements),
  • actuator, and packing.
The basic parts of a valve are illustrated in Figure 1.
Valve Body
The body, sometimes called the shell, is the primary pressure boundary of a valve. It serves as the principal element of a valve assembly because it is the framework that holds everything together.
The body, the first pressure boundary of a valve, resists fluid pressure loads from connecting piping. It receives inlet and outlet piping through threaded, bolted, or welded joints.
Basic Parts of a Valve
Figure 1 : Basic Parts of a Valve
Valve bodies are cast or forged into a variety of shapes. Although a sphere or a cylinder would theoretically be the most economical shape to resist fluid pressure when a valve is open, there are many other considerations.
For example, many valves require a partition across the valve body to support the seat opening, which is the throttling orifice. With the valve closed, loading on the body is difficult to determine.
The valve end connections also distort loads on a simple sphere and more complicated shapes. Ease of manufacture, assembly, and costs are additional important considerations.
Hence, the basic form of a valve body typically is not spherical, but ranges from simple block shapes to highly complex shapes in which the bonnet, a removable piece to make assembly possible, forms part of the pressure resisting body.
Narrowing of the fluid passage (venturi effect) is also a common method for reducing the overall size and cost of a valve. In other instances, large ends are added to the valve for connection into a larger line.
Valve Bonnet
The cover for the opening in the valve body is the bonnet. In some designs, the body itself is split into two sections that bolt together.
Like valve bodies, bonnets vary in design. Some bonnets function simply as valve covers, while others support valve internals and accessories such as the stem, disk, and actuator.
The bonnet is the second principal pressure boundary of a valve. It is cast or forged of the same material as the body and is connected to the body by a threaded, bolted, or welded joint.
In all cases, the attachment of the bonnet to the body is considered a pressure boundary. This means that the weld joint or bolts that connect the bonnet to the body are pressure-retaining parts.
Valve bonnets, although a necessity for most valves, represent a cause for concern. Bonnets can complicate the manufacture of valves, increase valve size, represent a significant cost portion of valve cost, and are a source for potential leakage.
Valve Trim
The internal elements of a valve are collectively referred to as a valve’s trim. The trim typically includes a disk, seat, stem, and sleeves needed to guide the stem.
A valve’s performance is determined by the disk and seat interface and the relation of the disk position to the seat.
Because of the trim, basic motions and flow control are possible. In rotational motion trim designs, the disk slides closely past the seat to produce a change in flow opening.
In linear motion trim designs, the disk lifts perpendicularly away from the seat so that an annular orifice appears.
Disk and Seat
For a valve having a bonnet, the disk is the third primary principal pressure boundary. The disk provides the capability for permitting and prohibiting fluid flow. With the disk closed, full system pressure is applied across the disk if the outlet side is depressurized.
For this reason, the disk is a pressure-retaining part. Disks are typically forged and, in some designs, hard-surfaced to provide good wear characteristics.
A fine surface finish of the seating area of a disk is necessary for good sealing when the valve is closed. Most valves are named, in part, according to the design of their disks.
The seat or seal rings provide the seating surface for the disk. In some designs, the body is machined to serve as the seating surface and seal rings are not used.
In other designs, forged seal rings are threaded or welded to the body to provide the seating surface. To improve the wear-resistance of the seal rings, the surface is often hard-faced by welding and then machining the contact surface of the seal ring.
A fine surface finish of the seating area is necessary for good sealing when the valve is closed. Seal rings are not usually considered pressure boundary parts because the body has sufficient wall thickness to withstand design pressure without relying upon the thickness of the seal rings.
Stem
The stem, which connects the actuator and disk, is responsible for positioning the disk. Stems are typically forged and connected to the disk by threaded or welded joints.
For valve designs requiring stem packing or sealing to prevent leakage, a fine surface finish of the stem in the area of the seal is necessary. Typically, a stem is not considered a pressure boundary part.
Connection of the disk to the stem can allow some rocking or rotation to ease the positioning of the disk on the seat.
Alternately, the stem may be flexible enough to let the disk position itself against the seat. However, constant fluttering or rotation of a flexible or loosely connected disk can destroy the disk or its connection to the stem.
Two types of valve stems are rising stems and non-rising stems. Illustrated in Figures 2 and 3, these two types of stems are easily distinguished by observation.
For a rising stem valve, the stem will rise above the actuator as the valve is opened. This occurs because the stem is threaded and mated with the bushing threads of a yoke that is an integral part of, or is mounted to, the bonnet.
Valve Rising Stems
Figure 2 : Rising Stems
Valve Non-rising Stems
Figure 3 : Non-rising Stems
There is no upward stem movement from outside the valve for a non-rising stem design. For the non-rising stem design, the valve disk is threaded internally and mates with the stem threads.
Valve Actuator
The actuator operates the stem and disk assembly. An actuator may be a manually operated handwheel, manual lever, motor operator, solenoid operator, pneumatic operator, or hydraulic ram.
In some designs, the actuator is supported by the bonnet. In other designs, a yoke mounted to the bonnet supports the actuator.
Except for certain hydraulically controlled valves, actuators are outside of the pressure boundary. Yokes, when used, are always outside of the pressure boundary.
Valve Packing
Most valves use some form of packing to prevent leakage from the space between the stem and the bonnet.
Packing is commonly a fibrous material (such as flax) or another compound (such as teflon) that forms a seal between the internal parts of a valve and the outside where the stem extends through the body.
Valve packing must be properly compressed to prevent fluid loss and damage to the valve’s stem. If a valve’s packing is too loose, the valve will leak, which is a safety hazard. If the packing is too tight, it will impair the movement and possibly damage the stem.
Types of Valves
Because of the diversity of the types of systems, fluids, and environments in which valves must operate, a vast array of valve types have been developed.
Examples of the common types are the globe valve, gate valve, ball valve, plug valve, butterfly valve, diaphragm valve, check valve, pinch valve, and safety valve.
Each type of valve has been designed to meet specific needs. Some valves are capable of throttling flow, other valve types can only stop flow, others work well in corrosive systems, and others handle high pressure fluids.
Each valve type has certain inherent advantages and disadvantages.
Understanding these differences and how they effect the valve’s application or operation is necessary for the successful operation of a facility.
Although all valves have the same basic components and function to control flow in some fashion, the method of controlling the flow can vary dramatically.
In general, there are four methods of controlling flow through a valve.
  1. Move a disc, or plug into or against an orifice (for example, globe or needle type valve).
  2. Slide a flat, cylindrical, or spherical surface across an orifice (for example, gate and plug valves).
  3. Rotate a disc or ellipse about a shaft extending across the diameter of an orifice (for example, a butterfly or ball valve).
  4. Move a flexible material into the flow passage (for example, diaphragm and pinch valves).
Each method of controlling flow has characteristics that makes it the best choice for a given application of function.
Summary
The following important information in this article is summarized below:
There are four basic types of flow control elements employed in valve design.
  • Move a disc, or plug into or against an orifice (for example, globe or needle type valve).
  • Slide a flat, cylindrical, or spherical surface across an orifice (for example, gate and plug valves).
  • Rotate a disc or ellipse about a shaft extending across the diameter of an orifice (for example, a butterfly or ball valve).
  • Move a flexible material into the flow passage (for example, diaphragm and pinch valves).
Valve stem leakage is usually controlled by properly compressing the packing around the valve stem.
There are seven basic parts common to most valves.
Spring and Diaphragm Pneumatic Actuators
Working Principle of Pneumatic Actuators
Types of Pneumatic Actuators Animation
Control Valve Volume Booster Working Principle
3 Comments
  • azetou says:
    May 14, 2018 at 6:58 pm
    Hi,
    Thanks for the article.
    Please note that in section 3, the title is missing a word , the title should be “Valve bonnet” instead of “Valve”.
    Regards.
  • S Bharadwaj Reddy says:
    May 14, 2018 at 8:59 pm
    Updated. Thanks for the continuous support.
  • Samson says:
    August 12, 2021 at 9:28 am
    Thanks for the revelation. Am grateful.
208kSubscribersSubscribe
Recent Comments
Related Articles
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Shaft and Coupling Bore Tapers Repair Caused Frequent Shutdowns
Globe Valve Disk and Stem Connections
Globe Valve Seat and Disk
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
valve plug and seat damage
Control Valve Erosion Problems
Speed of Power Actuators
Speed of Actuators
electric valve actuator
Electrical Actuators
More Articles
Shunt-Wound DC Motor
Shunt-Wound Motor Operation
Current Transformer Operation
Current Transformer Selection, Operation & Maintenance
Moving Iron Vane Meter Movement
Industrial Internet of Things Projects
Top 100 Industrial Internet of Things Projects (IIoT)
Calibrating Transmitter System One Seal with suppressed Zero
Calibrating Level Transmitter with Remote Seals
Weir Diaphragm Valve
Diaphragm Valves Construction, Types, Stem & Bonnet Assembly
What is a Process Alarm
What is a Process Alarm? Types of Alarms
