Reading: Workstation Healthiness Checks
Inst Tools > Blog > PLC Tutorials > Workstation Healthiness Checks
Last updated: March 4, 2021 12:31 pm
PLC Tutorials Control Systems
2 Min Read
The below-mentioned healthiness checks are carried out for the control room workstation which will help you to improve the life span of the DCS and PLC HMI systems.
Steps to be followed to check the healthiness of WORKSTATION:
1. Collect the corresponding Work permit.
2. Note down the HIS (Human Interface Station, also called workstation) tag name which will be available on both sides of the console. or as follow your system details.
3. Login into administrator user on a particular workstation.
4. Note down the drive memory details of that particular system by clicking My Computer icon.
5. Note down the antivirus status by placing the cursor on the antivirus icon in the taskbar. If you have the latest version then update the antivirus software using the CD.
6. Right-click on the taskbar select start task manager, click on performance, note down the CPU and RAM usage. It must be within the limits. ( As per the limits defined in your plant system philosophy).
7. Check the console cooling fans running status.
8. Measure the utility supply voltage from MCB which will be on the backside of the console.
9. Check the workstation, mouse, keyboard, monitor condition (clean the system from the dust).
10. Clean up any unwanted data files.
11. Check the network status ( Lights will blink at Ethernet ports backside of CPU)
12. Logoff the administrator user then log in to the operator user.
13. Check the sealing of spare cable entry slots at bottom of the panel.
14. Check for any loose connections in the panel.
15. Clean all the filters of the panel using a vacuum cleaner (outside).
16. Check and ensure cables are properly dressed and cable ducts are covered.
Examples of PLC Programming using Boolean Functions
Why 4-20 mA Current Signal is used instead of Voltage Signal?
#9 PLC Best Practices – Validate indirections
  • R.JAGAN MOHAN RAO says:
    May 3, 2020 at 1:26 pm
    Very good information on the health check procedure.
How-to Create Instrument Loop Diagram (ILD)?
One Shot Rising and One Shot Falling Instructions in PLC
Network Operating System
What is Instrumentation Control System ?
Rack Type PLC
PLC Input Output Modules
Learn PLC in Hindi
Learn PLC in Hindi
PLC Program for Counting Objects on Conveyor
PLC Program for Counting Moving Objects on Conveyor
Design & Construction of Process Plant
Difference Between Single Pair Ethernet and Traditional Ethernet
Compile Project in Tia Portal
Communication between Wincc and Tia Portal
Level Loop Troubleshooting
Identify Faults in PID Control Loop
Top 100 PLC Projects List
Seebeck Effect
Seebeck Effect Theory
Control of the Effects of Disturbance Signals by Use of Feedback
RSlogix 500 to communicate with Excel
How to Communicate with Excel from RsLinx?
MCB vs Fuse
MCB vs Fuse – Basic Questions and Answers for Engineers
Interview Questions on Industrial Wireless
Industrial Automation and Control Interview Questions
Flow Switch Principle
In-Line Flow Switch Working Principle and Animation
