Reading: Wiring Diagram
Inst Tools > Blog > Electrical Theory > Wiring Diagram
Wiring Diagram
Last updated: July 23, 2018 10:12 am
Electrical Theory
1 Min Read
 A wiring diagram is a very simple way to show wiring connections in an easy-to-follow manner. These types of diagrams are normally found with home appliances and automobile electrical systems (Figure 12).
Wiring diagrams show the component parts in pictorial form, and the components are identified by name. Most wiring diagrams also show the relative location of component parts and color coding of conductors or leads.
Wiring Diagram
Figure 12 Wiring Diagram
DC Motor Connections
Resistivity
How to Measure Specific Gravity of Battery
Low Voltage Air Circuit Breaker Principle
Three Phase Systems
Three Phase Transformer Connections
Power in Balanced 3 Phase Loads
Parallel Short Circuit Faults
Calculate Power in Series RCL Circuit
Types of Capacitors
DC Motor Theory
Voltage Divider
Calculate Power in Series RC Circuit
Capacitance
Electrical Symbols
Electrical Symbols
Generator Action in a Motor
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Transformer Coil Polarity
Using Kirchhoff’s Voltage Law to find Current with Multiple Battery Sources
Kirchhoff’s Laws
Squirrel-Cage Induction Rotor
Induction Motor
Thermocouples
Thermocouples
DC Generator
DC Generator
Bellow Principle
Bellows
Burnout Function in Temperature Transmitter
Capillary Remote Seal Leave Measurement
Siemens Pressure Transmitter with Remote Seals Calculations
PWM based Inverters in Power Electronics Quiz
3 Way Circuit Animation
Three Way Electrical Switch Working Animation
difference between invasive and non-invasive and intrusive and non-intrusive
Connect the Differential Pressure Gauge at the Filter
How Do You Connect the Differential Pressure Gauge at the Filter?
Relay Principle
Advantages & Disadvantages Electromagnetic Relays
