Reading: What is a Four-wire RTD ?
Inst Tools > Blog > Temperature Measurement > What is a Four-wire RTD ?
Last updated: November 20, 2019 11:12 am
3 Min Read
A very old electrical measurement technique known as the Kelvin or four-wire method is a practical solution to the problem of wire resistance.
Commonly employed to make precise resistance measurements for scientific experiments in laboratory conditions, the four-wire technique uses four wires to connect the resistance under test (in this case, the RTD) to the measuring instrument, which consists of a voltmeter and a precision current source.
Two wires carry “excitation” current to the RTD from the current source while the other two wires merely “sense” voltage drop across the RTD resistor element and carry that voltage signal to the voltmeter.
RTD resistance is calculated using Ohm’s Law: taking the measured voltage displayed by the voltmeter and dividing that figure by the regulated current value of the current source.
A simple 4-wire RTD circuit is shown here for illustration:
Four Wire RTD Circuit
Wire resistances are completely inconsequential in this circuit. The two “excitation” wires carrying current to the RTD will drop some voltage along their length, but this voltage drop is only “seen” by the current source and not the voltmeter.
The two “sense” wires connecting the voltmeter to the RTD also possess resistance, but they drop negligible voltage because the voltmeter draws so little current through them.
Thus, the resistances of the current-carrying wires are of no effect because the voltmeter never senses their voltage drops, and the resistances of the voltmeter’s sensing wires are of no effect because they carry practically zero current.
Note how wire colors (white and red) indicate which wires are common pairs at the RTD. The RTD is polarity-insensitive because it is nothing more than a resistor, which is why it doesn’t matter which color is positive and which color is negative.
The only disadvantage of the four-wire method is the sheer number of wires necessary. Four wires per RTD can add up to a sizeable wire count when many different RTDs are installed in a process area.
Also Read : RTD Standards
How to Install Thermowell on an Elbow?
What is a Temperature Controller? – How to Choose?
Thermocouple Questions and Answers
Temperature Calibration Bath Principle
Installation Precautions of Thermocouple and RTD
Thermowell Problems
  • Siddhartha Kumar Maiti says:
    December 20, 2017 at 9:15 am
    Sir, a pressure transmitter of Honeywell shows error Pu comm failed. Sir I can’t understand what is the problem?
Seebeck Effect Theory
Temperature Sensor Accessories
Testing thermocouples and RTDs using Multi-function Calibrators
Non-contact Pyrometers Characteristics
Temperature Sensor calibration procedure
Ambient Temperature Effects on RTD
Thermocouple Calculations
General Specification of Thermowell
RTD lead resistances Wiring
Resistance Temperature Detectors Working Principle
Single Position Calibration of Temperature Bath
Thermowell Outer Diameter larger than Nozzle Inside Diameter
Thermowell Outer Diameter Larger than Nozzle Inside Diameter?
Temperature Gauges and Elements Specifications
Temperature Gauges and Elements : Detailed Specifications
RTD Measuring with three leads
How 3 Wire RTD Lead Wire Resistance Eliminated?
Temperature Scanner
Applications of Temperature Scanner
Relationship between Temperature Scales
Transmission and Distribution Interview Questions
SIS Failures and Reliability - Safety Instrumented Systems
SIS Failures and Reliability – Safety Instrumented Systems
Why do Teenagers want to be Entrepreneurs
Why do Teenagers want to be Entrepreneurs?
Hydrostatic level transmitter Formula
Hydrostatic Level Transmitter Questions
Pump and Mixer Operations Example PLC Timer-Based Control
Pump and Mixer Operations Example: PLC Timer-Based Control
Programmable Logic Controller (PLC) PLC Maintenance Check Points
Programmable Logic Controller Maintenance Check Points
Analog Electronics Objective Questions – Set 5
Cybersecurity Projects for Engineering Students
