Reading: What is a Barometer?
Inst Tools > Blog > Pressure Measurement > What is a Barometer?
Last updated: December 15, 2019 4:03 pm
3 Min Read
A barometer is a scientific instrument used in meteorology to measure atmospheric pressure. Pressure tendency can forecast short term changes in the weather.
Barometers and pressure altimeters (the most basic and common type of altimeter) are essentially the same instrument, but used for different purposes.
An altimeter is intended to be transported from place to place matching the atmospheric pressure to the corresponding altitude, while a barometer is kept stationary and measures subtle pressure changes caused by weather.
A mercury barometer has a glass tube closed at one end with an open mercury-filled reservoir at the base. The weight of the mercury creates a vacuum in the top of the tube known as Torricellian vacuum.
Mercury in the tube adjusts until the weight of the mercury column balances the atmospheric force exerted on the reservoir. High atmospheric pressure places more force on the reservoir, forcing mercury higher in the column.
Low pressure allows the mercury to drop to a lower level in the column by lowering the force placed on the reservoir. Since higher temperature levels around the instrument will reduce the density of the mercury, the scale for reading the height of the mercury is adjusted to compensate for this effect.
The tube has to be at least as long as the amount dipping in the mercury + head space + the maximum length of the column.
The pressure is shown on your barometer’s dial, usually expressed in “inches” referring to “inches of mercury” (inch Hg).
The early barometers measured the pressure by the rise or fall of a column of mercury. This mercury barometer was invented back in 1643 by a pupil of Galileo named Evangelista Toricelli.
This is the basic instrument use for detecting atmospheric pressure. A simple diagram of a barometer is given in the figure below.
Barometer Principle
With the column at equilibrium at point (stationary), at Point A;
  • Forces Up = Forces Down
  • Weight of the column = Atmospheric Pressure × Area
  • Density × Area × Height = Atmospheric Pressure × Area
  • Atmospheric pressure = ρhg
Image Credits : N Asyiddin
Basics of Differential Pressure Transmitters
Pressure Gauges : Remote and Chemical Seals
Electronic Pressure Sensors Principle
Scaling Sensor Output to Engineering Units
Difference between Axial and Radial Diaphragm Seal Connection?
Differential Pressure Switch Calibration Procedure
Pressure Gauge Selection
Remote Diaphragm Seal Transmitter for Vacuum Application
Pressure Gauge Calibration according to Standard DKD-R-6-1
Strain Gauge Pressure Sensor Principle
Pressure Gauges with Bourdon Tube Principle
Capillary Tubing Pressure Sensor Temperature & Elevation Problems
Inferential Measurement based on Pressure
U-tube Water Manometer
How much Pressure applied to U-tube Water Manometer?
pressure transmitter calibration setup
Questions on Pressure Transmitter Calibration Setup
Pressure Unit Conversion Practical Example
DeadWeight Tester
DeadWeight Tester Questions
Pressure gauge mechanism
How Measurement Span of Pressure Gauge Could be Changed?
Pressure Gauge Calibration Procedure
Differential Pressure Transmitter with 5 Way Manifold Valve
Digital Electronics MCQ
Sum of Products & Products of Sum Objective Questions
Analog Electronics Objective Questions – Set 9
Top 100 555 Timer Projects for Engineering Students
Troubleshooting PLC Current Loops
Troubleshooting Current Loops with Voltage Measurement
Double Excited Magnetic System Quiz
Filled-bulb Temperature Measurement
Filled-bulb Temperature Sensors
Move function block
Move Instruction in Tia Portal
Displacer Level Measurement Formula
Displacer Level Measurement Calculations
