Reading: Venturi Flow Meter – Working Principle, Advantages, Animation
Inst Tools > Blog > Animation > Venturi Flow Meter – Working Principle, Advantages, Animation
When venturi flow meter is placed in a pipe carrying the fluid whose flow rate is to be measured, a pressure drop occurs across venturi meter.
Last updated: October 31, 2023 4:59 pm
Animation Flow Measurement
When a venturi flow meter is placed in a pipe carrying the fluid whose flow rate is to be measured, a pressure drop occurs between the entrance and throat of the venturi meter.
Venturi Flow MeterConstruction of Venturi meterOperation of Venturi MeterApplications of Venturi MetersAdvantages of Venturi MetersLimitations of Venturi Meters
This pressure drop is measured using a differential pressure sensor and when calibrated this pressure drop becomes a measure of flow rate.
Venturi Flow Meter
The below animations shows the working of venturi flow meter.
Venturi Flow Meter Working Animation
The following are the main parts and areas of the venturi meter:
The entry of the venture is cylindrical in shape to match the size of the pipe through which fluid flows. This enables the venture to be fitted to the pipe.
After the entry, there is a converging conical section with an included angle of 19’ to 23’.
Following the converging section, there is a cylindrical section with a minimum area called as the throat.
After the throat, there is a diverging conical section with an included angle of 5’ to 15’.
Openings are provided at the entry and throat (at sections 1 and 2 in the diagram) of the venture meter for attaching a differential pressure sensor (u-tube manometer, differential pressure gauge, etc) as shown in the diagram.
The fluid whose flow rate is to be measured enters the entry section of the venturi meter with a pressure P1.
As the fluid from the entry section of venturi meter flows into the converging section, its pressure keeps on reducing and attains a minimum value P2 when it enters the throat. That is, in the throat, the fluid pressure P2 will be minimal.
Venturi Flow Meter
The differential pressure sensor attached between the entry and throat section of the venturi meter records the pressure difference(P1-P2) which becomes an indication of the flow rate of the fluid through the pipe when calibrated.
The diverging section has been provided to enable the fluid to regain its pressure and hence its kinetic energy. The lower the angle of the diverging section, the greater the recovery.
  • It is used where high-pressure recovery is required.
  • Can be used for measuring flow rates of water, gases, suspended solids, slurries, and dirty liquids.
  • Can be used to measure high flow rates in pipes having diameters in a few meters.
  • Fewer changes of getting clogged with sediments
  • The coefficient of discharge is high.
  • Its behavior can be predicted perfectly.
  • Can be installed vertically, horizontally, or inclined.
  • Low-pressure drop (around 10% of Δp)
  • Lower sensitivity to installation effects than orifice plates
  • Less susceptibility to damage
  • More suitable for gas flows with entrained liquid
  • Comprehensive standards (ISO 5167)
  • They are large in size and hence where space is limited, they cannot be used.
  • Expensive initial cost, installation, and maintenance.
  • Require long laying length. That is, the venturi meter has to be proceeded by a straight pipe which is free from fittings and misalignments to avoid turbulence in flow, for satisfactory operation. Therefore, straightening vanes is a must.
  • Low turndown (can be improved with dual range Δp cells)
  • Greater cost to manufacture
  • Greater susceptibility to “tapping errors” in high Reynolds number gas flows owing to the high-velocity fluid passing the pressure tapping at the throat.
  • Less experimental data than orifice plates
  • Basics of Venturi Flow Meter
  • What is Averaging Pitot Tube
  • Strain Gauge Pressure Sensor
  • How Orifice Measures Flow
  • 3-15 psi to 4-20mA Convert
What are Multiphase Flow Meters? – Working Principle, Advantages
Prover Tank Calibration and Mass Flow Meter Verification Procedure
Importance of Flow Meter Turndown Ratio
Reasons to Calibrate Different Types of Flow Meters
Online Simulation
Ultrasonic Sludge Blanket Level Meter Animation
  • George Achakpo says:
    June 3, 2023 at 8:05 am
    Its educative.
    Thanks,
    From Emgr G.C. Achakpo
Different Flow Measurement Technologies
Troubleshooting Ultrasonic Flow Meter Common Problems
Orifice Sizing Guidelines and Thumb Rules with Flowchart
Laminar Flow Meter Working Principle
Working Principle of Vortex Flow Meter
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
What is Seal-in Circuit ?
Ultrasonic Flow meters Working Animation
Ultrasonic Flow Meters Animation
flow-meter-accuracy-calculation
Impact of Flow Meter Accuracy
microwave flow detector applications
Microwave Flow Sensor – Working Principle and Applications
Bi-metal Temperature Gauge
Bi-metal Temperature Sensors
circuit-breaker-working-principle-animation
Circuit Breaker Working Principle Animation
Deluge Valve Operation
Deluge Valve Working Principle
Servo Operated Electro Magnetic Flowmeter Objective Questions
Pressure Temperature Compensation Flow Measurement
HMI book
HMI Handbook
Specific-Conductance-Calibration-Procedure
Specific Conductance Calibration Procedure
Potentiometer Animation
Potentiometer Working Principle Animation
Measuring Circuit Voltage
Voltmeters
Type E thermocouple
Type E thermocouple Calculations
Liquid In Glass Thermometers
Liquid In Glass Thermometer Principle
PLC Programming Limit Switch
Converter Instruction in Siemens PLC Programming
