Reading: Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Inst Tools > Blog > Flow Measurement > Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Ultrasonic Doppler flow meter transmits an acoustic signal into the flow stream at a specific frequency to measure the flow rate.
Last updated: November 2, 2023 10:40 am
Flow Measurement
3 Min Read
An Ultrasonic Doppler flow meter transmits an acoustic signal into the flow stream at a specific frequency.
Ultrasonic Doppler Flow MeterAdvantages of Doppler Flow MeterDisadvantages of Doppler Flow MeterApplications of Doppler Flow Meter
This signal reflects off particulates, either solids or gas bubbles.
The reflected signal is detected by the receive transducer. The flow meter compares the transmit & receive frequencies & computes the frequency shift. This frequency shift is proportional to the liquid’s flow velocity & is known as the Doppler’s effect.
Doppler Flow Meters are only used for liquids containing gas bubbles or particulates.
Some of the applications where Doppler has an advantage over Transmit time are Treated Waste Water, Raw Water, Slurries, Sewage, Viscous Liquids, Acid, Pulp Stock, Food Products, Aerated Water, Cooling Water, etc.
The main advantage of Doppler flow meter is its non-intrusive design.
An acoustic-coupling compound is used on the surface of the pipe and the sensors are simply held in place to take a measurement or, for a more permanent installation, they are strapped around the pipe.
Some manufacturers offer a special clamp-on probe that allows connection to smaller pipe sizes.
Other advantages include:
  1. Easy installation and removal.
  2. No process downtime during installation.
  3. No moving parts to wear out.
  4. No process contamination.
  5. Works well with dirty or corrosive fluids.
  6. No leakage potential.
  7. Insensitive to liquid temperature, viscosity, density or pressure variations.
The main disadvantage of the doppler flow meter is the fact that the liquid stream must have particulates, bubbles, or other types of solids in order to reflect the ultrasonic signal. This means that the doppler flow meter is not a good choice for the water and very clean fluids.
The another disadvantage is that the accuracy can depend on particle-size distribution and concentration and also on any relative velocity that may exist between the particulates and the fluid. if there are not enough particulates available, the repeatability will degrade.
The other potential problem of this technology is that it can have trouble operating at very low flow velocities.
Being non-intrusive, Doppler flow meters have a wide variety of applications.
Some of them include:
  1. Influent and effluent water flow.
  2. Digester feed control.
  3. Waste water.
  4. Crude oil flow.
  5. Mining slurries.
  6. Acids.
  7. Liquified gases.
  • Flow Totalizer PLC Program
  • Ultrasonic Sludge Blanket Level Meter
  • Coriolis Mass Flow meter
  • Questions on Flow Measurement
  • Oscillating Piston Flow Meters
What is a Magnetic Flow Meter?
Difference between Different Types of Flow Meters
Venturi Flow Meter – Working Principle, Advantages, Animation
All About Vortex Flow Meters
What is an Insertion Flow Meter? – Types, Principle, Advantages
Electromagnetic Flow Meters Working Principle
How does an Orifice Measures Flow?
Types of Orifice Plates & Orifice Plate Tappings
Particle Image Velocimetry (PIV) Principle
What is a Square Root Extractor? – DP Flow Measurement
Variable Area Flow Meters – Principle, Advantages, Disadvantages
Laminar Flow Meter Working Principle
Mass Flow Calculations
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Thermal Dispersion Flow Switch Working Principle
Orifice Flow Meter With DP Transmitter
What is an Orifice Meter?
Bernoulli's Principle and Flow Meters
Vortex Flow Meter Principle
Vortex Flow meter Animation
Impulse line - Purpose & Tapping Point Location
Impulse Line – Purpose & Tapping Point Location
Spring Loaded Variable Area Flowmeter Working Principle
Spring Loaded Variable Area Flow Meter Working Principle
Flow Switch Symbol
Principle of Flow Switch
Difference-between-pneumatic-electric-hydraulic-actuators
Difference between Pneumatic, Electrical & Hydraulic Actuators
Cobot - Collaborative Robot
What is Cobot? – Collaborative Robot
Furnace Draft Control System
Pressure Control Valve
What is Pressure Control Valve?
Displacement Level Transmitter in situ calibration
Displacer (buoyancy) Level Transmitter Principle, Limitations, Design, Installation & Calibration
Temperature Balance System Objective Questions
Bimetallic strip thermostat
Mechanical Temperature Measuring Sensors
