Reading: Types of Renewable Energy Sources
Inst Tools > Blog > Common > Types of Renewable Energy Sources
In this article, we will understand the types of renewable energy sources which are solar, wind, hydro, biogas, and geothermal.
Last updated: October 17, 2023 3:06 pm
Common
Wind EnergySolar EnergyBiogas EnergyHydro EnergyGeothermal Energy
There are two types of energy resources – non-renewable and .renewable. Non-renewable means that these sources will become extinct from the world after a certain amount of years; because it is limited and not endless.
Renewable energy sources mean that these sources will not become extinct as they are endless and cannot run out of source.
In this post, we will see the types of renewable energy sources. They are the future of energy as they are unlimited and people know as non-renewable will become extinct after some years. So, they have developed means of utilizing this properly and efficiently.
This also ensures that as both the types of energy sources are used in balance, non-renewable sources will survive a few more years and support the renewable types of sources.
Wind Energy
Wind energy is one of the widely used sources in the world. Large wind turbine fans are used in areas where air flows in a rapid and large way; that is enough to move these fans due to it.
Wind Energy
Simply, imagine your fan at the home. It runs on electricity; but if a wind of large force comes, it sometimes moves the flips of the fan through its power and without electricity. It’s not to a large extent, but it just indicates that wind or large powerful air can move the fan.
So, large fans of heights as large as a 10-floor tower are arranged in series in a large plain area or mountainous area. Wind moves the fan flips and as the fan is connected to generators, it generates electricity and is then fed to power distribution units.
Solar Energy
Sun is the largest source of energy in the world. So, solar panels are mounted on building terraces or open areas where sun rays come strongly on them.
Solar Energy
Solar cells are used inside it which gets charged on receiving solar power and the electricity thus generated is used for domestic and industrial purposes.
Solar power is one of the most widely used power sources in most of the countries and is fast replacing other non-renewable energy sources.
Biogas Energy
In this type, biomass is burned to generate electricity. By burning organic materials, power is generated. Biogas is a clean, pollution-free type and produces a good amount of power.
As waste is abundant and never-ending, biomass energy is a good option used nowadays for power generation.
The various agricultural, domestic, and industrial waste can be burned to produce solid, liquid, and gaseous fuels. Power is thus produced at much lower rates and with greater efficiency.
Hydro Energy
Water is abundantly available in this world. Dams are created to control the flow of rivers and lakes. This control allows the proper flow of water to hydroelectric power plants.
Hydro Energy
The flow of water moves the turbines in it and thus, generates electricity. If the flow of water is very good and large in quantity, it is enough to produce a large amount of electricity daily.
Geothermal Energy
Heat is trapped below the earth’s crust; which was formed billion years ago. This heat escapes naturally and is captured to produce energy by generating steam. The steam is used to move turbines and generate electricity.
It is used less as compared to other renewable energy sources.
These are some of the most available renewable energy resources. It is of great use in the future as they are the best option available for non-renewable energy sources,
Urea Bagging Plant – Process Flow
Types of Angular Velocity Measurement
Custom CNC Machining – A Complete Guide You Cannot Miss
List of 100 Sensors and Transducers Questions
Simple Three Digital Electronic Project Ideas
Pneumatic Counter for Counting the Strokes of a Cylinder
Vision Camera Systems in Industrial Automation
HVAC Questions & Answers
D’Arsonval Movement
Digital Measuring Instruments – Types, Functions, Advantages, Disadvantages
Data Preparation for AI: For Successful Machine Learning
Imbibition Water Flow Control System – Sugar Factory
What is a Flange Gasket ?
How Does Starlink Work
How Does Starlink Work?
CNC Milling versus CNC Turning
CNC Milling versus CNC Turning – Which is the Best Option?
Types of Sensors used in the Dairy Industry
Electrification in Mining Industry
Test Automation in Production Environment
Test Automation in Production Environment – Everything You Should Know
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
How Does a Touch Sensor Work
How Does a Touch Sensor Work?
Emerson ASCO Solenoid valve references
SIS Solenoid Valves – Safety PLC
working-of-pnp-transistor
Working of NPN Transistor
4-Wire, Three-Phase Delta Wiring System
proximitor module
Bently Nevada Vibration System Verification Procedure
Radiation based Level Sensor Principle
Actuator Sensor Interface (ASi) Protocol in PLC
car parking example logic
Up Down Counter Instruction in PLC
Phase Failure Relay
Why is Phase Failure Relay Required in LV Panels?
