Reading: Types of Relays used in an Air Circuit Breaker (ACB)
Inst Tools > Blog > Electrical Basics > Types of Relays used in an Air Circuit Breaker (ACB)
In this post, we will learn the various types of relays used in an air circuit breaker (ACB).
Last updated: November 17, 2022 4:26 pm
Electrical Basics
What is an Air Circuit Breaker?Relays used in Air Circuit Breaker (ACB)Shunt Coil RelayUnder Voltage (UV) RelayClosing Relay
Circuit breakers are an essential part of an electrical circuit. It is a device that is used as a protective switch for passing electrical current with tripping conditions checked.
When it detects a trip condition, the breaker opens its contact and isolates the input and output voltage from contacting each other.
So, its basic function is to interrupt current flow after a fault is detected. It then remains open as long as the user does not reset the trip. There are many types of circuit breakers available.
One such commonly used type is the Air Circuit Breaker (ACB). It is important to note that there are many relays used in an ACB.
Circuit breakers are all about extinguishing the arc generated during high-tripping currents or power off condition.
When the fixed and moving contacts in a circuit breaker move apart from each other during the trip or off condition, then a large amount of arc is generated. So, when air is used to extinguish arc, then it is called an air circuit breaker.
Air circuit breakers use compressed air to blow out the arc, or alternatively, the contacts are rapidly swung into a small sealed chamber, the escaping of the displaced air, thus blowing out the arc. But, it should be known that the air used is working at normal atmospheric pressure.
It is important to note that for internal safety and tripping applications, relays are used internally in the air circuit breaker to make it more advanced in operation.
Let us have a look at the three most general types of relays used in an ACB:
Shunt Coil Relay
This relay can also be termed as the power relay for the ACB. A shunt coil relay is an automatically controlled relay, which can be operated remotely, to open or close the circuit breaker.
Like a PLC operates a relay, this shunt coil relay too can be operated (turned on or off) by it. The operation of this relay directly opens or closes the circuit breaker.
This relay is used to detect under voltage in incoming power supply. Overvoltage is an easy natural problem that the circuit breaker will detect and trip the path.
When the incoming voltage is less (usually less than 380 V), the load connected in the circuit breaker will perform in less efficiency and also get damaged after a prolonged period of time.
So, an under-voltage relay is used to detect under-voltage problems and trip the circuit immediately for it. You can set the under-voltage threshold in the circuit breaker, which will then perform this safety function automatically.
Closing Relay
It is very similar to a shunt coil relay. It can also be remotely controlled via PLC, and this will automatically open or close the circuit breaker.
In this way, we understand the types of relays used in an air circuit breaker.
  • Importance of Neutral Wire
  • Power and Instrument Cables
  • Compare AA and AAA Batteries
  • One Grid One Frequency
  • What Happens Pump Runs Dry?
Electrical Switches Principle & Types
Motor Protection Circuits
Difference Between Flame Resistant and Flame Retardant Cables
What are Switchgear Interlocks?
Download Electrical Enclosure Book
Siemens Standard Drives Application Handbook (PDF)
Formula of AMP, KW, KVA, HP for AC and DC Voltages
What is a Ground Rod?
What are Inverse Time and Instantaneous Trip Circuit Breakers?
Variable Motor Speed Control
Top 100 Electrical Machines Projects for Electrical Engineers
Types of Electrical Wiring
What is an Intelligent Motor Control Center? – IMCC
Rotary UPS or Dynamic UPS
DOL Starter Testing
DOL Starter – Working, Circuit, Advantages, Disadvantages, Applications
Automatic Motor Forward and Reverse Control using Timer
Garage Door Roller Shutter
What is a Core Type Transformer
Difference Between Core and Shell Transformers
Motor Slip Calculation
Electrical Motor Terms and Concepts
Motor STAR - DELTA Working principle
Motor STAR – DELTA Starter Working Principle
Lightning Arrester Basics and Terminology
Vortex Flow Meter Principle
Vortex Flow meter Animation
Top 100 Biomedical Instrumentation Engineering Projects for Students
Motors Inrush Currents
Motor Inrush Current Measurements
SCL Language in Siemens Tia Portal
Electronics and Communication Engineering Projects
175 Electronics and Communication Engineering Projects
PLC Logic for Stairway Lighting
Smart Automation Solutions: PLC Logic for Stairway Lighting
Two Transistor Model of Thyristor
Thyristors – Switching, Two Transistor Model, Advantage, Applications
Valve Diaphragm Actuator
Spring and Diaphragm Pneumatic Actuators
