Reading: Types of Industrial Storage Batteries
Inst Tools > Blog > Electrical Basics > Types of Industrial Storage Batteries
In this post, we will understand the types of industrial storage batteries like Lead-Acid, Lithium-Ion, & Alkaline Batteries.
Last updated: October 17, 2023 3:09 pm
Electrical Basics
In this post, we will understand the types of industrial storage batteries.
Types of Industrial Storage BatteriesAlkaline Storage BatteriesLithium-Ion BatteriesLead Acid BatteriesSummary
Batteries play an important role in industrial activities. Unlike primary batteries or domestic batteries that are used and thrown (which are discarded once the battery is over), storage batteries can be charged once their battery is over.
They store energy and release electrical energy once put to use again.
Storage batteries are a group of cells that store chemical energy and convert it into electrical energy when it is used.
In a reverse direction, that means to recharge it, the current is passed through it in opposite direction and it converts electrical energy into chemical energy.
Ions can be transferred to and fro between electrodes, which makes it possible to charge and discharge. Such stable energy application makes it suitable for various industrial purposes.
We will consider some general types of industrial storage batteries.
As discussed earlier, due to the primary use of chemical energy, one of the types used is alkaline chemical solutions.
One of the most used types of these batteries is nickel-cadmium batteries. They are heavy-duty ones and are more reliable than other alkaline batteries.
They are best suitable in harsh environmental conditions or high currents. But, they are more expensive and difficult to maintain than other alkaline batteries.
Some other types of alkaline batteries are nickel-zinc, nickel-hydrogen, nickel-iron, silver (oxide)-zinc, etc.
Of these, the one which is nowadays a tough competitor to nickel-cadmium is nickel-hydrogen batteries. This is due to the non-usage of toxic cadmium, high level of tolerance, high capacity per unit volume, etc.
Apart from alkaline ion batteries, lithium-ion batteries are much widely used in industrial activities. They are very lightweight and charge rapidly.
Though they are costlier than alkaline storage batteries, they last longer and are more durable than them.
Some of the commonly used lithium-ion batteries are lithium-cobalt oxide, lithium-manganese dioxide, and lithium-nickel oxide.
Lead Acid Batteries
Of all the three types discussed, lead-acid is the most widely and successfully used one.
They have the highest level of reliability and are extremely useful in low melting temperatures.
They are low-cost and easy to fabricate. Due to their big and heavy size, they take a longer time to recharge. But, they are the most reliable and accurate of all three types.
Summary
In this way, we studied some general types of industrial storage batteries. Though we are naming industrial here, it is not only used in industries but also in other applications like defense, domestic, hospitals, UPS, telephone exchange, etc.
  • Static and Rotary UPS
  • What is a Link Box?
  • Batteries in Series and Parallel
  • Battery Interview Questions
  • Battery Construction
Geothermal Energy Power Plants
Motor Maintenance, Troubles, Regular Checks, Performance
How to Check the Continuity of Protective Conductors?
What is Arc Protective Clothing? – Importance, Features, Materials
Electric Motors Noises – Types, Possible Sources, Reasons
Difference between Current Transformer and Potential Transformer
Why is Motor Control Required in Control Systems?
Types of Tripping Protection in MCCB
What is a VFD? – Theory, Advantages, Disadvantages
What is a Time Delay Relay? Principle, Advantages, Disadvantages
Motor Control Circuit Wiring
What is an Intelligent Motor Control Center? – IMCC
Types of Earth Leakage Circuit Breaker
What is a Buchholz Relay
What is a Buchholz Relay? Working Principle
Introduction to Protective Systems
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
Earth Fault
What are Ground Fault and Earth Fault?
What is a Line Choke or Reactor in a VFD
What is a Line Choke or Reactor in a VFD?
PLC and MCC Panel Interface Design
Auto Changeover Switch
What is an Auto Changeover Switch?
Motors Inrush Currents
Motor Inrush Current Measurements
Displacer Operated Level Switch Working Principle
Displacer Level Switch Working Principle
Nano Instrumentation Objective Questions
4-20 mA Conversion Formulas
Standard 4 to 20 mA Conversion Formula
Control Loop
What is a Control Loop ?
Safety Instrumented System Interview Questions Answers
PLC Interlock Example
PLC Interlock Logic with First Input Priority
Top 10 Common Mistakes on Electrical Systems
LED Stumps in Cricket
How do LED Stumps in Cricket Work?
