Reading: Types of Earth Leakage Circuit Breaker
Inst Tools > Blog > Electrical Basics > Types of Earth Leakage Circuit Breaker
In this post, we will learn the types (voltage & current) and working principles of the earth leakage circuit breaker (ELCB).
Last updated: September 28, 2022 4:12 pm
Electrical Basics
In this post, we will learn the types and working principles of the earth leakage circuit breaker (ELCB).
Voltage Earth Leakage Circuit Breaker (ELCB)Current Earth Leakage Circuit Breaker
ELCB stands for Earth Leakage Circuit Breaker. Its role is to detect earth leakage or insulation error on the load equipment and trip the current-carrying circuit.
This prevents electric shock and protects the nearby personnel and equipment from damage. It is a type of circuit breaker and is widely used for various domestic and industrial purposes.
Basically, ELCB is classified into two categories –
  1. Voltage type ELCB
  2. Current type ELCB
This is a relatively simple type of ELCB. As seen in the image, the circuit breaker is connected to the current circuit shown as a small box.
A relay is used in the circuit breaker (CB) circuit. One end of the supply of relay is connected to the metal body of the load where the current is to be passed.
The other end of the supply of relay is connected to the earth point. The auxiliary contact of the relay is connected to the circuit of CB.
In normal conditions, without any earth leakage or insulation fault, the relay will not be energized as there will be no potential from the load side. If there is an earth short circuit or leakage, a small voltage will be induced in that potential side.
If this voltage is above a limit where the relay will be energized, the relay turns on. This will turn on the auxiliary contact and as it is connected as NC contact, it will cut off the current circuit of the CB and thus, prevent the equipment from damage or protect any human from shock if he touches the equipment by mistake.
This type is the more widely used one. It is also called RCCB (Residual Current Circuit Breaker).
As seen in the image, it is similar to the voltage one used above. The only difference is of the current transformer used in the circuit.
In the current path, two primary windings are wound on that as shown by a thin line (one on the phase and the other on the neutral).
A secondary current transformer is wound on the primary windings; shown by the thick line. The transformer is connected to the relay potential for energizing it, and its auxiliary contact is connected to the CB circuit.
In normal conditions, if there is no earth leakage, the current flowing through both the phase and neutral lines will be the same. The resultant MMF produced will be zero (the difference between phase and neutral currents).
Now, suppose there is earth leakage. A small amount of leakage current will be added to the phase current. Due to this, a difference will be generated between both the currents and the resultant MMF produced will energize the relay.
This will cut off the circuit of CB and protect the equipment and personnel from damage.
In this type, there are two types of RCCB.
  1. Single phase RCCB and
  2. Three phase RCCB.
  • Servo Motor Drives
  • Electrical Wiring Diagram
  • Overload Relay Principle
  • Single Phase Preventer Relay
  • Compare Static and Rotary UPS
Worldwide Voltage & Frequency Values
Why is the Humming Sound Produced in Transformer?
Electrical Switches Principle & Types
Testing and Inspection of Bonding and Grounding Systems
Difference Between Flame Resistant and Flame Retardant Cables
Difference between Signal Cables and Control Cables
Types of Motor Enclosures
Induction Motor Over and Under Voltage Problems
Introduction to Protective Systems
Difference Between Wattmeter and Energy Meter
What is Arc Protective Clothing? – Importance, Features, Materials
Basic Electrical Engineering Questions & Answers
How to Protect Electrical Terminal Blocks From Tampering?
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
LCS Configuration equipped with LOTO Facility
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
Safety Tips When Working With Electricity
What is a Power Transformer
What is a Power Transformer? – Components and Types
Dahlander Motor Control Circuit
Dahlander Motor Control Circuit and Power Circuit
Download Electrical Enclosure Book
Why Three-phase Voltage is 440 Volts
Why Three-phase Voltage is 440 Volts?
Difference Between Isolator and Circuit Breaker
Free Allen Bradley PLC Training Course
Free Allen Bradley PLC Ladder Logic Training Course
Orifice Beta
Feedback Accelerometer System Objective Questions
Turbidity Sensor Calibration Procedure
why-lel-important-in-gas-detection
Why LEL important in Gas Detection?
Electronic Devices & Circuits Quiz – Set 14
CODESYS open source PLC software
What is CODESYS? Why Do You Need to Learn it?
Electric Stress Control in Cables, Joints and Terminations
Electric Stress Control in Cables, Joints, and Terminations
