Reading: What is a transformer tap changer?
Inst Tools > Blog > Electrical Machines > What is a transformer tap changer?
Last updated: December 22, 2018 1:20 am
Electrical Machines
The transformer voltage at the load side desired to be constant or as close to the design value. But the load voltage may vary according to current drawn by the load or supply voltage.
Secondary voltage = (supply voltage or primary voltage) / Turns ratio.
Based on the above equation to maintain constant secondary voltage/load voltage or as close to the desired value it is needed to change the turn’s ratio. The tap changer of the transformer performs this task to change the turn’s ratio. The tap changer basic function is that it removes or connects some portion of the winding to the load side or source side. Tap changer can be located on primary side or secondary side. However it will be placed on high voltage winding side.
Why tap changer is placed on high voltage side?
The tap changer is placed on high voltage side because:
1.The HV winding generally wound over LV winding hence it is easier to access the HV winding turns instead of LV winding.
2.Because of high voltage the current through the HV winding is less compared to LV windings, hence there is less “wear” on the tap changer contacts. Due this low current, in on load tap changer the change over spark will be less.
Transformer Tap changer
Tap changer Primary side:
In this type the tap changer circuit is placed in primary side or supply side. As we know;
Turns ratio = secondary winding turns (Ns)/ primary winding turns (Np).
By the above formulas it is stated that if the primary turns decreases the turn’s ratio increases hence then secondary voltage decreases. Opposite for the reverse case i.e. primary turns increase leads to turns ratio decrease which increases the secondary voltage.
Figure shows the tap changer on primary winding with tap changing interval of 2.5 % per tap. With this we can understand three conditions:
Transformer Tap changer on Primary Side1)In normal operation the tap changer will be at 0% position to provide required designed secondary voltage.
2)If the supply voltage increases or load current decreases there will be an increase in supply voltage which is not desirable. At this case the tap position in the primary winding will rise towards positive direction i.e. +2.5%, and hence decreases the Np. This will increases the turns ratio (Ns/Np) further decreases the secondary voltage.
Consider the load voltage decreased then the tap changer shift towards negative side to increase the primary turns and hence decreases the turn’s ratio. The secondary voltage will increase to compensate the change.
Tap changer Secondary side:
In this the tap changer is placed in secondary side of the transformer. This type of taping is used in step-up transformer where low voltage winding is in primary side and high voltage winding is in secondary side. Figure shows the tap changer circuit on secondary side with tap interval of 2.5 %. In some distribution transformers the tap changer resolution can be up to 1% for fine adjustments.
Transformer Tap changer on secondary Side
In this the case is reverse compared to primary tap changer. To increase the secondary voltage the tap changer will move towards positive direction and it moves in negative direction to decrease the secondary voltage.
Star to Delta and Delta to Star Conversion Formula
Why Armature is placed on Stator for Synchronous machines
AC Motor Speed Control
Electrical Motor Starter Circuits
Faults in a Transformer
Losses of Transformer
Squirrel Cage Induction Motor vs Slip Ring Induction Motor
Synchronous Motor Working Principle
BLDC Motor Vs AC Induction Motor
What is a Transformer Tap Changer
Synchronous Motor Starting Methods
What is Auto Reclosing?
Difference Between Squirrel Cage and Slip Ring Motors
Types of Transfomer Cooling Methods
Difference between Induction motor and Synchronous motor
Why rating of Synchronous Generators and Alternators in MVA or KVA
Parallel Operation of Alternators
Types of Generators
Why Starting Current of Induction Motor is High
Distribution transformer
Different Types of Transformers
Classification of valves
Losses in a DC Generator
Advantages of Hydrogen cooling in Synchronous Generators
PID Controller
Proportional Integral Derivative Controllers – PID MCQ
Differential Pressure Transmitter Zero Suppression
Basics of DP Transmitter Suppression and Elevation
p-type-semiconductor
N Type and P Type Semiconductors
PLC Program for Automatic Bottle Rejection System
Program to implement T Flip Flop logic
T Flip Flop PLC Ladder Diagram
Sensors and Transducers Objective Questions
Boiler Protection System
Burner Management System Logic and Interlock
Vortex flow meter Bluff Body
Types of Vortex Flow Meter Sensors
