Reading: Transformer Mutual Induction
Inst Tools > Blog > Electrical Theory > Transformer Mutual Induction
Last updated: August 6, 2018 9:52 pm
Electrical Theory
0 Min Read
If flux lines from the expanding and contracting magnetic field of one coil cut the windings of another nearby coil, a voltage will be induced in that coil.
The inducing of an EMF in a coil by magnetic flux lines generated in another coil is called mutual induction.
The amount of electromotive force (EMF) that is induced depends on the relative positions of the two coils.
Impedance in RL Circuits
Calculate Power in Parallel RC Circuit
Voltage Polarity and Current Direction
Three Phase Transformer Connections
Parallel Circuit Current Calculations
Battery Hazards
Low Voltage Protection (LVP) and Low Voltage Release (LVR)
Series and Parallel Inductors
Impedance
Parallel Short Circuit Faults
Voltage Divider
Reading Electrical Schematics
Batteries
Discharge and Charging of Lead-Acid Battery
Phase angle
AC Generation Analysis : Effective Values, Phase Angle and Frequency
Circuit Breaker Control Circuit Wiring
Compounded DC Generator
Parallel AC Generators
Total Resistance in a Parallel Circuit
Resistance in Parallel Circuits
Ground Detector Lamp Method Principle
Ground Detector Principle
4-Wire, Three-Phase Delta Wiring System
Block Diagram
Block Diagram
Simple RC Circuit
Impedance in RC Circuits
Switches, Repeaters, Bridges, Routers, Firewalls
Difference between KW and KVA
Automatic Coffee Machine
Automatic Coffee Vending Machine – PLC Logic Programming
Difference Between Squirrel Cage and Slip Ring Motors
Pneumatic Valves Questions & Answers
How to use Scale and Normalize Instructions in PLC
How to Create DFB in Schneider PLC? – Derived Function Block
How to troubleshoot the PLC Hardware faults
