🔥 Free Foundation Fieldbus Course → REGISTER NOW 🚀 Automation Training
Series and Parallel Capacitors
You are here:
When capacitors are connected in series, the total capacitance is less than anyone of the series capacitors’ individual capacitances.
Series Capacitors
If two or more capacitors are connected in series, the overall effect is that of a single (equivalent) capacitor having the sum total of the plate spacings of the individual capacitors.
As we’ve just seen, an increase in plate spacing, with all other factors unchanged, results in decreased capacitance.
Thus, the total capacitance is less than any one of the individual capacitors’ capacitances. The formula for calculating the series total capacitance is the same form as for calculating parallel resistances:
Formula
Series Capacitance Formula
Parallel Capacitors
When capacitors are connected in parallel, the total capacitance is the sum of the individual capacitors’ capacitances.
If two or more capacitors are connected in parallel, the overall effect is that of a single equivalent capacitor having the sum total of the plate areas of the individual capacitors.
As we’ve just seen, an increase in plate area, with all other factors unchanged, results in increased capacitance.
Parallel Capacitance
Thus, the total capacitance is more than any one of the individual capacitors’ capacitances. The formula for calculating the parallel total capacitance is the same form as for calculating series resistances:
Formula
Parallel Capacitances Formula
As you will no doubt notice, this is exactly opposite of the phenomenon exhibited by resistors. With resistors, series connections result in additive values while parallel connections result in diminished values.
With capacitors, its the reverse: parallel connections result in additive values while series connections result in diminished values.
Review
  • Capacitances diminish in series.
  • Capacitances add in parallel.
Previous: Factors Affecting Capacitance
Next: Practical Considerations of Capacitors
Share via
Send this to a friend
