Reading: Top 100 Power Electronics Projects for Engineering Students
Inst Tools > Blog > Projects > Top 100 Power Electronics Projects for Engineering Students
Here is a detailed list of 100 Power Electronics projects prepared for final-year electrical engineering students.
Last updated: July 12, 2024 11:09 am
Projects Power Electronics
12 Min Read
Here is a detailed list of 100 Power Electronics projects prepared for final-year engineering students. Each project comes with a brief description to provide context and set the stage for research and implementation.
The below power electronics projects are helpful for electrical engineers to choose as a mini-project or as a final-degree project.
  1. Single-Phase Inverter
    • Design and implement a single-phase inverter circuit with features like frequency and voltage control.
  2. Three-Phase Inverter
    • Construct a three-phase inverter for industrial applications with overcurrent and overvoltage protection.
  3. DC-DC Boost Converter
    • Build a boost converter to step up a DC input voltage.
  4. DC-DC Buck Converter
    • Design a buck converter to step down DC voltage efficiently.
  5. Flyback Converter
    • Develop a flyback converter for applications like SMPS or battery charging.
  6. Forward Converter
    • Design and implement a forward converter with applications in isolated DC-DC conversion.
  7. Active Power Factor Correction
    • Create a circuit that adjusts the power factor in AC-DC converters to near unity.
  8. PWM-based Motor Control
    • Utilize Pulse Width Modulation to control the speed of a DC motor.
  9. AC Voltage Regulator
    • Design an AC voltage regulator using triacs, SCRs, or other semiconductor devices.
  10. Zero Voltage Switching
    • Implement a zero voltage switching circuit to reduce switching losses in converters.
  11. Resonant Converter
    • Build a resonant converter with high efficiency for applications like induction heating.
  12. Phase Shifted Full Bridge Converter
    • Create a phase-shifted full bridge DC-DC converter for high-power applications.
  13. Matrix Converter
    • Build a matrix converter to directly convert AC to AC without a DC link.
  14. Uninterruptible Power Supply (UPS)
    • Design and construct an UPS system with fast-switching capabilities during power failures.
  15. Synchronous Buck Converter
    • Develop a synchronous buck converter to achieve high efficiency.
  16. Interleaved Buck Converter
    • Design an interleaved buck converter to reduce input current ripple.
  17. Voltage Doubler
    • Create a voltage doubler circuit for applications like CRT displays or high-voltage generation.
  18. High-Frequency Transformer Design
    • Design a high-frequency transformer for switch-mode power supplies.
  19. Soft-Switching Techniques
    • Implement soft-switching techniques to reduce the switching losses in a converter.
  20. Induction Motor V/F Control
    • Control the speed of an induction motor using V/F control techniques.
  21. Thyristor-Based Cycloconverter
    • Design a cycloconverter to convert AC to lower-frequency AC using thyristors.
  22. IGBT-Based Inverter
    • Design an inverter using Insulated Gate Bipolar Transistors (IGBTs) for improved performance.
  23. Battery Management System
    • Develop a battery management system to monitor and maintain rechargeable batteries.
  24. Solar MPPT System
    • Implement a Maximum Power Point Tracking system for optimizing solar power extraction.
  25. Switched Reluctance Motor Drive
    • Create a drive system for switched reluctance motors, focusing on variable speed control.
  26. Induction Heater
    • Build an induction heater using high-frequency inverters.
  27. Active Rectifier
    • Design and implement an active rectifier for better efficiency compared to passive rectifiers.
  28. Fault Detection in Converters
    • Develop a fault detection system for converters using microcontrollers or DSPs.
  29. Wireless Power Transfer
    • Design a wireless power transfer system using resonant inductive coupling.
  30. Piezoelectric Energy Harvesting
    • Build a system to harvest energy from piezoelectric materials.
  31. Load Sharing in Microgrids
    • Implement a load-sharing algorithm in a microgrid setup.
  32. Digital Control of Converters
    • Develop a digital control loop for DC-DC converters using microcontrollers.
  33. Dual Active Bridge Converter
    • Design a dual active bridge converter for applications like bi-directional DC-DC conversion.
  34. Non-Inverting Buck-Boost Converter
    • Build a non-inverting buck-boost converter for variable output voltage.
  35. Sensorless Motor Control
    • Implement sensorless control algorithms for BLDC or PMSM motors.
  36. Dynamic Voltage Restorer
    • Design a dynamic voltage restorer to mitigate voltage sags in power systems.
  37. Electric Vehicle Battery Charger
    • Develop a fast-charging station with efficient power conversion for electric vehicles.
  38. Quasi Z-Source Inverter
    • Implement a quasi Z-source inverter for improved voltage boosting capabilities.
  39. LLC Resonant Converter
    • Design an LLC resonant converter for applications like flat-panel display power supplies.
  40. Power Line Communication
    • Implement a basic power line communication system to send data over existing power cables.
  1. Grid-Tied Solar Inverter
    • Design a grid-tied inverter to connect a solar power system to the electrical grid.
  2. Microgrid Controller
    • Develop a controller to manage energy sources and loads in a microgrid environment.
  3. Class-D Audio Amplifier
    • Build a high-efficiency Class-D audio amplifier using power transistors.
  4. Step-Up/Down Transformer Design
    • Design a step-up and step-down transformer focusing on core material, windings, and other parameters.
  5. LED Driver Circuit
    • Develop an efficient LED driver circuit with dimming features.
  6. Hybrid Energy Storage System
    • Design a system combining different types of energy storage devices like batteries and supercapacitors.
  7. Bidirectional DC-DC Converter
    • Create a bidirectional DC-DC converter for applications like energy storage systems.
  8. Thermal Management in Converters
    • Investigate and implement thermal management techniques in power electronics converters.
  9. Smart Battery Charging
    • Develop a smart charging algorithm to optimize battery life and charging speed.
  10. High-Voltage DC Transmission
    • Study and implement basic components of a high-voltage DC transmission system.
  11. Phase-Controlled Rectifiers
    • Design a phase-controlled rectifier using SCRs for controlled AC-to-DC conversion.
  12. Variable Frequency Drive (VFD)
    • Create a VFD to control AC motor speed and torque.
  13. Power Electronics in Renewable Energy
    • Implement a project showcasing the role of power electronics in renewable energy systems like wind or solar.
  14. Custom Switching Device
    • Design a custom semiconductor switching device for a specialized application.
  15. Sine Wave Inverter
    • Build a pure sine wave inverter for applications like sensitive electronics or medical devices.
  16. Cascaded H-Bridge Multilevel Inverter
    • Design a multilevel inverter using cascaded H-bridges for high-voltage applications.
  17. Voltage Sag Compensation
    • Create a system to detect and compensate for voltage sags in industrial plants.
  18. Power Quality Monitoring
    • Develop a power quality monitoring system using IoT or other data collection methods.
  19. Snubber Circuit Design
    • Create specialized snubber circuits to protect power electronics devices from voltage spikes.
  20. Active Harmonic Filtering
    • Build an active harmonic filter to improve the power quality in an electrical system.
  21. Pulse Charging for Batteries
    • Develop a pulse charging method to improve battery lifespan and reduce charging time.
  22. Modular Multilevel Converter
    • Create a modular multilevel converter for high-voltage and high-power applications.
  23. Low Drop-Out Voltage Regulator
    • Design a low drop-out voltage regulator for portable electronics.
  24. High-Frequency Inverter Design
    • Build a high-frequency inverter for applications like induction cooking or wireless power transfer.
  25. Power Electronics for Electric Railways
    • Design a specialized power electronics system for electric railway applications.
  26. Wind Turbine Converter
    • Develop a power converter for wind turbine applications.
  27. Synchronous Rectification
    • Implement synchronous rectification techniques in DC-DC converters for better efficiency.
  28. Adaptive Voltage Positioning
    • Develop an adaptive voltage positioning technique for voltage regulators.
  29. Multi-Input Converter
    • Design a multi-input power converter for hybrid energy systems.
  30. Switched-Capacitor Converters
    • Build a switched-capacitor converter for high-efficiency, low-power applications.
  31. DC Power Supply with Variable Output
    • Develop a DC power supply with variable voltage and current output.
  32. Lighting Control Systems
    • Implement a lighting control system with dimming and color-changing features using power electronics.
  33. Digital PID Controller for Converter
    • Design a digital PID controller for better stability and performance of converters.
  34. Power Electronics for HVAC Systems
    • Develop a power electronics-based control system for HVAC applications.
  35. Power Electronics in Robotics
    • Design a power electronics system to control robotic movements and functionalities.
  36. Fast Battery-Swapping System
    • Create a fast battery-swapping mechanism for electric vehicles.
  37. High-Efficiency Class-E Amplifier
    • Design a Class-E RF amplifier for high-efficiency wireless communication.
  38. Power Electronics for Data Centers
    • Develop a specialized power electronics system to improve power quality and efficiency in data centers.
  39. Regenerative Braking System
    • Create a regenerative braking system for electric vehicles using power electronics.
  40. Reliability Analysis of Converters
    • Study and analyze the reliability of different types of power electronics converters.
  1. Vehicle-to-Grid (V2G) Systems
    • Design a Vehicle-to-Grid system that enables electric vehicles to supply power back to the grid during peak demand.
  2. Wireless Power Transfer
    • Create a wireless power transfer system using resonant inductive coupling for applications like electric vehicle charging.
  3. Dynamic Voltage Restorer
    • Design a Dynamic Voltage Restorer (DVR) to mitigate voltage sags in power distribution systems.
  4. Active Power Filter
    • Create an Active Power Filter (APF) for harmonic and reactive power compensation in industrial systems.
  5. Buck-Boost Converter with MPPT
    • Develop a buck-boost converter with Maximum Power Point Tracking (MPPT) for solar applications.
  6. IGBT-based Induction Heating
    • Design an IGBT-based induction heating system for applications in materials science or cooking.
  7. Energy-Efficient Ceiling Fan Controller
    • Create an energy-efficient ceiling fan controller using a BLDC motor and corresponding power electronics.
  8. Matrix Converter
    • Design a Matrix Converter for AC-to-AC conversion without an intermediate DC stage.
  9. Power Factor Correction in SMPS
    • Implement power factor correction in a Switched-Mode Power Supply (SMPS) to improve efficiency.
  10. Automotive DC-DC Converter
    • Develop a high-efficiency DC-DC converter for automotive applications, focusing on reliability and compact size.
  11. Solid-State Transformer
    • Build a solid-state transformer for applications that require compact size and high efficiency.
  12. Distributed Power Generation Controller
    • Design a controller for managing distributed power generation resources like solar panels and wind turbines.
  13. Resonant LLC Converter
    • Implement a resonant LLC converter for high-frequency and high-efficiency applications.
  14. Remote Power Monitoring
    • Develop a system for remote monitoring of electrical parameters in a power distribution network.
  15. Solid-State Breaker
    • Design a solid-state circuit breaker to replace traditional mechanical breakers for faster response and higher reliability.
  16. Programmable Gain Amplifier
    • Build a programmable gain amplifier for variable input ranges in measurement systems.
  17. Current Source Inverter
    • Design a current source inverter for applications like induction motors or renewable energy systems.
  18. Fault Detection in Power Converters
    • Implement fault detection and protection mechanisms in power converters to improve system reliability.
  19. Dynamic Control of Power Grids
    • Develop algorithms and corresponding hardware to dynamically control power grids for improved stability.
  20. Home Energy Management System – Create a home energy management system that intelligently manages power electronics devices to reduce energy consumption and cost.
Each of these power electronic projects offers opportunities for in-depth study and practical application of power electronics principles. They can serve as excellent foundations for final-year electrical projects, providing both theoretical and practical knowledge.
Real-time PLC Projects – Industrial Automation
Crowbar fault protection circuit
MCT (MOS Controlled Thyristor) – Symbol, Working, Characteristics, Advantages
Image Processing Projects for Engineering Students
Top 100 Proteus Design Suite Projects for Engineering Students
500 Electronics Projects for Engineering Students
How Snubber Circuit works ?
Top 100 Robotic Projects for Engineering Students
Thyristors – Working, VI Characteristics, Turn ON Methods
314 Mechanical Mini Projects List
Top 100 PLC Projects List
Analog Electronic Projects for Final Year Engineering Students
Electronics Mini Projects
300+ Best Electronics Mini Projects
Top 100 Zigbee Projects for Engineering Students
Final Year Engineering Projects
Final Year Engineering Projects for ECE, EEE and EIE Students
Top 300 Digital Signal Processing Projects (DSP)
Top 300 Digital Signal Processing Projects – DSP Project Ideas
Zigbee Projects
Zigbee Based Project Ideas and List
SCR Switching Characteristics
Mechanical Engineering Design and Fabrication Projects
300+ Mechanical Engineering Design and Fabrication Projects
Top 100 Electrical Machines Projects for Electrical Engineers
Allen Bradley PLC Example with Sub routines
How to use Sub Routines with Allen Bradley PLC
Volume Booster Working Principle
Control Valve Volume Booster Working Principle
Top 100 Control Systems Objective Questions & Answers
Partial Discharge in Power Lines and its Detection through Sensors
Circular Chart Recorder
How to Read Circular Chart Recorder for Flow Measurement?
Cathode Ray Tube (CRT)
Flow Transmitter Output Current Calculation
Calculate Flow Transmitter Output Current
Trip Valve Shown Tripped
Trip Valve Principle
