Reading: Test and Process Modes in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Test and Process Modes in Siemens PLC
In this article, we will learn about a term test and process modes reside in the TIA PORTAL software of Siemens PLC.
Last updated: March 4, 2021 11:21 am
3 Min Read
In this article, we will learn about a term test and process mode reside in the TIA PORTAL software.
Test and Process ModesTest Mode:Process Mode:
These two options you may find in some PLC and not in every PLC. It depends on the type of PLC you choose.
Let’s find out where these functions are residing in the PLC software.
Open TIA PORTAL. Go to “Device and Network”.
Siemens PLC Device and Network
Now, select the CPU and go to the “properties tab”. This is a safety CPU which contains operating mode.
Here, in the “general” tab section you can find “operating mode” as you can see in the below window.
Siemens Test Mode
Inside operating mode, you can find two options
1. Process mode
2. Test mode
Selection by default comes in test mode.
Test Mode:
As you can see in the above window that selection is at by default test mode.
In test mode you can perform test functions means you can modify and monitor variables.
In the test function, you can perform every function without any restrictions.
But it requires greater scan time. So, if a user program is in test mode then it must have a larger scan time.
In case you find trouble using modify and monitoring that means selection is made to process mode.
Process Mode:
As you can see in the below window that selection is now made to Process mode.
Siemens Process Mode
Here, you can change the cycle time. You can set a cycle time between 5 and 65535 ms.
It restricts modify and monitor function to reduce cycle time.
Step by step programming execution can’t be performed.
No call condition is permitted to make sure that scan time can’t exceed the set cycle time.
It won’t allow changes to be made in the programming environment.
Author: Suhel Patel
  • Siemens CPU Execution
  • Factory Acceptance Test
  • Run Motors in Sequential
  • Allen Bradley Architecture
  • Save PLC Project to Card
How to Communicate with Excel from Intouch SCADA?
How to Take Program Backup from Physical PLC? – Siemens PLC
Top Free PLC Software
Timer during Motor Direction Change PLC Program
PLC Programming to Control Lights in a Sequence
Multi-Tank Liquid Level Control System with Fill Priority [PLC]
Establishing a Modbus Driver for SCADA Indusoft Web Studio
Programmable Logic Controller Questions and Answers
How to use Converters in PLC
PLC Automatic Control of Two Outputs with one Input
Process Interlocks and Trips
Real-time PLC Projects
Real-time PLC Projects – Industrial Automation
Communication between Factory IO and Siemens Tia Portal
The STAR-DELTA Auto And Manual Program
PLC program pushbutton switches
Features of Scada Which are Must in an IoT System
Simatic S7 PLC Backup Steps
How to take Backup from Siemens S7-300 PLC?
PLC Program to Control Motor Speed using VFD Drive
Motor Speed Control using VFD and PLC Programming
PLC Tutorials - Timers and Counters
Difference between Timer and Counter – PLC Basics
Top 200 Electrical Engineers Objective Questions and Answers
What is Star Topology
Network Topologies Selection Factors and Comparison
Vortex Flow Meter Animation
Difference Between Batch Process and Continuous Process
Best Software to Use to Improve Your Business
Best Software to Use in 2023 to Help Improve the Effectiveness of Your Business
How to Test a Pressure Switch ?
RTD with Thermowell
Temperature Sensor Accessories
Pneumatic Control Mechanisms Objective Questions
