Reading: Tank Filling and Emptying using Intouch Scada Script
Inst Tools > Blog > PLC Tutorials > Tank Filling and Emptying using Intouch Scada Script
Last updated: March 4, 2021 12:02 pm
This article is about how to write a script for tank filling and emptying using a script in InTouch SCADA software.
Follow the below step to see the script to fill and empty the level of the tank.
Step 1:
Open InTouch SCADA.
Create a new project and enter an animation environment.
To add a tank, click on “wizard” then click on “symbol factory” and hit “ok” to proceed.
Intouch Scada Symbol Factory
Step 2:
Search tank and add a tank that you want to use.
Search tank in Intouch Scada
Step 3:
After adding a tank to the screen, add one switch to provide the condition to fill the tank.
InTouch Scada Switch Graphics
Step 4:
Double click on tank to add properties and to give a tag name.
Click on “animation” and then choose “vertical”.
Animation in InTouch Scada
Step 5:
Clicking on a vertical will open up a new pop-up window as shown in the below window.
InTouch Scada Expression
Step 6:
Give a tag name and choose the range you want to add. Hit “ok” to proceed.
Assign Tag name in Scada
Step 7:
New pop-up as shown in the below window will open up.
In type choose memory integer. Choose maximum and minimum value. Hit “save” then close the pop-up.
InTouch Scada Program
Step 8:
Give a tag name to switch too. Hit ok ton proceed.
Discrete Switch Wizard
Step 9:
Now I will write the script. As I am using a single-window script I will use windows script.
Do a right-click and choose windows script.
InTouch Window Scripts
Step 10:
Here I have added a script to fill and empty the tank with the help of the switch.
In the first line of a script, you can see that to fill the tank I have used condition (==) and result (=).
Condition: If my switch is “1” means ON and tank level is less than 100 then the tank is going to fill (T = T + 2) with a rate of “2”. If you want to fill the tank in less time you can use any number from 1 (Low) to 10 (High).
In the tank emptying process, I simply have used OFF switch means when I put off the switch and level of the tank is greater than 0 (zero) then the tank is going to empty (T = T – 2).
So, “+” to fill the tank and “-“ to empty the tank is used.
Click on “validate” than “convert” and “ok” to load the script.
Step 11:
Check the process by clicking on the “runtime” button.
Tank Scada Script
Author: Suhel Patel
  • Quiz Questions on Motors
  • Statement List (STL)
  • Field instrument to Control Room
  • What is SCADA System?
  • Configure an Alarm in InTouch
PLC Ladder Logic for Opposite Acting Control Valves Application
SCADA for Substation Automation
Ferrules and Cross Ferruling
PLC Ladder Logic Example based on Set Coil and Reset Coil
PLC based Drink Dispenser System
PLC System Site Acceptance Test (SAT)
Allen Bradley Powerflex VFD
PLC SCADA Engineers Interview Questions and Answers
#9 PLC Best Practices – Validate indirections
Types of Allen Bradley PLC
How to Communicate with Excel from Intouch SCADA?
Download Free HMI software – CODESYS
Schneider PLC Programming Example
Schneider PLC Programming Example for Beginners
Machine Indicator Lights PLC Programming Solution
Difference Between Microcontroller and PLC
Data Types in PLC
Data Types in PLC – Bit, Byte, Integer, Real, String
Conveyor Sorting Machine PLC Program
Conveyor Sorting Machine PLC Program with Calculation Function
PLC Temperature Control using Pulse Width Modulation
PLC Temperature Control using Pulse Width Modulation (PWM)
How to choose between PLC and DCS Systems
Establish Communication Between Two PLC Via PROFIBUS Protocol
WinCC data logging
How to Export Data from WinCC Runtime Advanced into Excel using VB Script
Ladder Logic Vs. Other Programming Languages - PLC Basics
Ladder Logic Vs. Other Programming Languages – PLC Basics
Basic Temperature Sensors MCQ
Basic Temperature Sensors MCQ Questions Answers
MOSFET Objective Questions
Basics of Thermistors, Thermocouples and RTD's
Basics of Thermistors, Thermocouples and RTD’s
Advantages and Disadvantages of Air Blast Circuit Breakers
Pressurizer
Pressurizer
