Reading: What is a Submersible Pressure Transmitter? Principle, Advantages
Inst Tools > Blog > Level Measurement > What is a Submersible Pressure Transmitter? Principle, Advantages
The submersible pressure transmitter principle based on the static pressure of sensor which is proportional to the level of liquid.
Last updated: September 28, 2022 2:33 pm
R Jagan Mohan Rao
Level Measurement Pressure Measurement
The submersible unit senses the hydrostatic pressure at the bottom of the liquid. It is designed for continuous level measurement and transmits a current signal proportional to the water column to the upstream instrumentation.
Submersible Pressure TransmitterWhere Submersible measurement is preferred?Working PrincipleCage protected Submersible Level TransmitterAdvantagesApplications
They use the piezo-resistive effect of diffuse silicon-sensitive elements to convert the static pressure into an electrical signal.
The sensor part of the liquid level transmitter can be directly placed into the liquid. The transmitter unit can be fixed at a safe working place with a flange or bracket.
The sensor is highly convenient to install and use. With a special vented cable to equalize atmospheric pressure changes, it accurately transmits the measured liquid level. The length of the cable, which depends on the application.
The height from the end of the water level transmitter to the water surface can be accurately measured by placing it directly into the container or body of water, and the water level signal can be sent to the outside through a standard current signal of 4-20 mA after temperature compensation and linearity correction.
It is called by various names such as static pressure level transmitter, submersible level sensor, submersible water level meter, etc.
A submersible probe is nothing more than a pressure sensor encapsulated in a way special so that liquid does not enter into the same, damaging the circuit of sense.
Submersible probes are used when it is not possible to place the level sensor by the side of the tank or container. There are applications where this is impossible, being a typical example of measuring levels in wells.
Working Principle
The submersible liquid level transmitter works based on the principle that the static pressure on the sensor is proportional to the height of the liquid.
When the liquid level transmitter is placed at a certain depth in the liquid level to be measured, the pressure is applied on the front face of the sensor and is
Ρ = ρ. g. H + Po
Where:
P = Pressure applied on the face of the transmitter
ρ = Density of the measured liquid
g = Acceleration of gravity
Po = Atmospheric pressure on the surface of the liquid
H = the depth of the transmitter in the liquid
At the same time, the pressure of the liquid is introduced into the positive pressure cavity of the sensor through the gas conductive stainless steel.
Then, the atmospheric pressure Po on the surface of the liquid is connected to the negative pressure cavity of the sensor to compensate the Po at the back of the sensor so that the pressure measured by the submersible sensor is ρ.g.H.
It is clear from the above description that by measuring the pressure P, the depth of the liquid level can be obtained.
The below figure is the Submersible level transmitter with cage protected.
Image Courtesy: Noshok
Ideal for slurry tanks, sewage, also in waste-water tank level measurements.
Most suitable for slurry tanks where sludge or turbulence may be present.
Advantages
The following are the advantages of submersible transmitters.
  • Liquid level can be sensed directly and the effects of foaming and deposition of process medium do not affect the measurement.
  • Precision measurement.
  • Good stability.
  • Flexible installation and easy to use.
  • Small size, lightweight,
  • Sensors with anti-vibration construction.
  • Easy submersible installation.
  • The sensor works based on the most advanced microprocessor technology.
Applications
Depth or level of measurement of wells.
Submersible liquid level measurement is widely used in wells, mines, waterworks, sewage treatment plants, urban water supply, high-rise swimming pools, oil pools, industrial water tanks, hydrogeology, reservoirs, rivers, oceans, etc.
PLC Raw Count Calculation for Pressure Transmitter
Level Gauges Objective Questions and Answers – Instrumentation
Magnetostrictive Level Transmitter Calibration Procedure
Types of Tank Gauging Level Measurement Systems
Pressure Detection Circuit
  • Sulaeman says:
    April 25, 2023 at 7:43 am
    hi there,
    i use submersible pressure for measure evaporation, i get something wrong with data output, data level evaporation change by pressure an water temperatur, how to calculate the level water with corection of water temperatur?
Magnetic Level Indicator Principle, Limitations, Installation and Calibration
Top 30 Interview Questions on Pressure Measuring Devices
Diaphragm Pressure Sensors
Piston Type Differential Pressure Gauge Principle
Basics of Pressure
Pressure Transmitters Heat-traced impulse lines
Pressure Transmitters Purged impulse lines
Closed tank DP Level Transmitter with wet leg elevation zero direct mount Calibration
Boiler Level Switch
Float level switch Principle
Gauge Display Scale
How to Read Gauge Analog Scales
Differential Pressure Sensor for Filtration Monitoring
Scaling Sensor Output to Engineering Units
Displacer Level Sensor Working Animation
Differential Pressure Level Transmitter Errors
RF-Capacitance Level Switch Principle
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Electrical Drives and Controls Interview Questions
Y Body Globe Valve
Globe Valve Body Design
Network topologies
Different Types of Network Topologies
Production Planning Software
Safety Relief Valve Material Selection
Common Mistakes in Dead Weight Tester
Common Mistakes to Avoid When Using Dead Weight Tester
What Every Instrument Engineer Should Know
What Every Instrument Engineer Should Know?
What is Hot Water Recirculation Loop
What is Hot Water Recirculation Loop? Advantages & Design
