Reading: How to use Sub Routines with Allen Bradley PLC
Inst Tools > Blog > PLC Tutorials > How to use Sub Routines with Allen Bradley PLC
Last updated: March 4, 2021 3:48 pm
3 Min Read
Sub routines are sub programs in a PLC project. We can split the whole program by its function or sequence. We can call the sub programs from main page using instructions.
Sub Routines with Allen Bradley PLCPLC Instruction DescriptionJSR-Jump to Sub routineRET: Return to Main PagePLC ProgramProgram Description:
AB PLC Sub Routines
In the above picture, there are totally 8 files listed. In that SYS 0 and SYS 1 are default files.
  • LAD 2-Main is the main page of the program, that means PLC starts executing IO’s from this page only.
  • LAD-3-IO MAPPING, LAD 4-SCALING, LAD 5-PID, LAD 6-PLANT 1 and LAD 7 PLANT 2 are sub programs categorized by project function and sequence.
  1. JSR-Jump to Sub routine
JSR-Jump Instruction in Allen Bradley PLC
We can use this instruction using condition by adding some input before the instruction like,
JSR-Jump Instruction Ladder Logic
In the SBR File number, we should give the ladder number i.e. which sub routine we should call at this place as shown in below figure.
Jump Instruction Address in PLC
  1. RET: Return to Main Page
RET Instruction in Allen Bradley PLC
Return instruction should add at the end of the sub routine program.
Return instruction AB PLC Logic
PLC Program
In this program, Sub routine instructions are explained using simple example.
 LAD 2-MAIN PAGE:
Allen Bradley PLC Example with Sub routines
LAD 3–IO MAPPING
AB PLC IO Mapping Logic
Note: Since its for example, LAD 4, LAD 5,LAD 6,LAD 7 pages are not included in this program
Case 1 :
If Sw2 is not turned on, In LAD 3-IO Mapping, no operations will be happen.
LAD 2-MAIN PAGE:
Ladder Logic example for JSR Instruction
LAD 3–IO MAPPING:
Even though, sw6 is turned ON, Move block is not doing any operation because in main page, JSR instruction is not activated
Move block in PLC
Case 2 :
If Sw2 is turned on, In LAD 3-IO Mapping, operations will be happen.
LAD 2-MAIN PAGE:
AB PLC Logic Mapping
LAD 3–IO MAPPING:
sw6 is turned ON, Move block is doing it s operation because in main page, JSR instruction is activated
AB PLC Example Ladder
Conclusion:
The above explained concept for subroutine is for example only. We can use this example program to understand the working of JSR and RET function in AB PLC ladder logic programming.
Author : Hema Sundaresan
Allen Bradley PLC Subroutines
PLC Training Software Download
Allen Bradley Interview Questions
RSLogix 5000 PLC Programming
PLC Car Parking Ladder Logic
Lamp Control using PLC Logic Condition
What is a Tag? Types of Tags in SCADA
How to use PLC with SQL Database? – Basics & Tutorials
Free Schneider PLC Training – Automation Course
Programmable Logic Controller (PLC) Scan Time – Types, Theory
Step-by-Step Guide to Choose Right Fuse for a Panel
Difference Between PNP and NPN Sensors
What is SCADA ? How does SCADA Works ?
SCADA Systems
Difference between Timer and Counter – PLC Basics
Single-Acting Cylinder Control Operation using Proximity Sensor
Single-Acting Cylinder Control using Proximity Sensor
Shift Bit Register in PLC
PLC Program for Automatic Heating and Mixing of Products
Heating and Mixing of Products using PLC Example Tutorial
Simulating Level Sensor and the Pump Logic in PLC
PLC Basics – Manual Control, Closed Loop, ON-OFF with Hysteresis
Basics of PID Controllers
PID Controllers in Closed Loop Control Systems – PLC Basics
Site Commissioning Steps for PLC Programmers
PLC ON DELAY TIMER FUNCTION
#6 PLC Best Practices – Validate Timers and Counters
PLC FBD Programming for Burglar Alarm Security System
Induction Machines Quiz Questions
PLC Timer Application in Security Camera Recording
Process Control & Instrumentation Objective Questions – Set 6
How a Δp flow meters works
What is Differential Pressure Flow Meter?
Variable Area Flow Meters
All About Variable Area Flow Meters
Temperature Scanner
Applications of Temperature Scanner
Displacer Level Transmitter weight calibration
Displacer Level Transmitter Dry Calibration with Weights
Instrumentation and Control Engineer Subject
Competency Factors of Instrument & Control Engineer (Design Engineering)
