Reading: Start the Counting from a Preset Value in PLC
Inst Tools > Blog > PLC Tutorials > Start the Counting from a Preset Value in PLC
Write a plc program such that the counter start counting from a preset value for the packaging application.
Last updated: March 4, 2021 11:06 am
2 Min Read
Write a plc program where there are boxes running by start-stop pushbuttons (PB) and there is a photocell sensor to count the number of boxes and there is a set pushbutton (PB) whenever it’s pressed the counter start counting from a preset value.
Start the Counting from a Preset Value in PLCPLC Logic ExplanationNetwork 01Network 02
Note the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
 Inputs & outputs:
I0.0: Start Push Button (Normally Open contact)
I0.1: Stop Push Button (Normally Closed Contact)
I0.1: Set Push Button (Normally Open Contact)
Q0.0: conveyor
C1: Counter
Network 01
When the Start PB has pressed the set coil of the SR flip flop is energized and the conveyor will run.
If the stop PB is pressed the reset coil of the SR flip flop is energized and the conveyor will stop.
Network 02
When the carton box passes by the photocell the count up coil of the counter C01 is energized and 1 count to the counter’s counts.
When the set PB has pressed the count value in the preset value PV will be moved to the counter’s counts.
When the stop PB is pressed the counter’s counts will be reset to 0.
Author: Karim Ali Anwar
  • VFD Ladder Logic
  • Up Down Counter
  • Motor PLC program
  • PLC Permissive Inputs
  • Problems in the PLC
Automate Batch Mixing with Repeated Cycles in Omron PLC
Batch Simulator PLC Example Program using LogixPro Simulator
Up Counter PLC Program
Proper Earthing Practices Used for PLC Control Panel
PLC Scan Time
Scaling with Parameters (SCP) Instruction in PLC
Control Algorithms in PLC Programming
PLC Program with 2 Toggle Switches and 4 Motors
PLC Analog Input Scaling
Programmable Logic Controller Maintenance Check Points
Types of Script in Intouch Scada
Electrical Circuit Breaker Quiz
100 Electrical Circuit Breaker Quiz
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
Parking Lights PLC Program Explained with Video
PLC Program for Water filling and Discharging Process
Use Cryptographic checks for PLC
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
Ladder Logic of Motor Forward and Reverse
PLC Programming Example for Motor Forward and Reverse Control
Electrostatic Precipitator
Principle of Operation of an Electrostatic Precipitator
Bubble Tube Level measurement
Bubble Tube Level Measurement Principle
PLC Ladder Logic Example based on Set Coil and Reset Coil
Random Access Memory Objective Questions – Part 4
Power Supply Unit with Diode Protection
Why we use Diode Protection Modules ?
Mitsubishi PLC Programming Tutorials
Software Troubleshooting Errors and Faults in Siemens PLC
Transistor Stabilisation
