Learn the PLC programming basics in the Siemens Tia portal PLC software from this training course.
The TIA stands for Totally Integrated Automation Portal. The Tia Portal is a complete software package for configuring the Siemens automation products like Simatic Step 7, WinCC, Sinamics startdrive, Simocode ES, and TIA Portal Multiuser Engineering and SIMATIC Energy Suite. You can easily access all these in a single interface.
Instrumentation Tools provides courses on PLC, SCADA, HMI, and industrial automation via online training to enhance your technical skills and help you to find your dream job in the core industry.
Our Youtube Channel: Subscribe Now!
Siemens Tia Portal Course
The below table shows the list of all topics in this Siemens Tia Portal training course.
| S.No. | Siemens Tia Portal | Videos |
| 1 | What is Industrial Automation? | Video |
| 2 | Programmable Logic Controllers Explained | Video |
| 3 | Components of the PLC System | Video |
| 4 | PLC Scan Cycle Explained | Video |
| 5 | Sinking and Sourcing Concept in PLC | Video |
| 6 | Basics of Siemens Tia Portal | Video |
| 7 | What is Tia Portal? – Siemens PLC Software Packages | Video |
| 8 | How to Download Siemens Tia Portal? | Video |
| 9 | How to Install Siemens Tia Portal? | Video |
| 10 | How to Create New Project in Tia Portal? | Video |
| 11 | Siemens PLC Input and Output Addressing | Video |
| 12 | Siemens PLC Memory Addressing | Video |
| 13 | Introduction to NO NC contacts and ladder logic | Video |
| 14 | How to do PLC Simulation in Siemens Tia Portal? | Video |
| 15 | PLC NO and NC contacts | Video |
| 16 | AND, OR, NOT Logic Gates in PLC | Video |
| 17 | NAND, NOR, XOR, XNOR Logic Gates in PLC | Video |
| 18 | Siemens PLC Programming Tutorial for Beginners | Video |
| 19 | PLC Holding and Breaking Concept | Video |
| 20 | PLC Example Program with Holding and Latching | Video |
| 21 | PLC Interlock Program | Video |
| 22 | Siemens PLC Memory Concept | Video |
| 23 | Timer in Siemens PLC Programming | Video |
| 24 | Generate Pulse Timer – TP Timer Instruction | Video |
| 25 | Generate On Delay Timer – TON Instruction | Video |
| 26 | Generate Off Delay Timer – TOF Instruction | Video |
| 27 | Retentive Timer – TONR Instruction | Video |
| 28 | Pump Logic Example in Siemens PLC | Video |
| 29 | Blinking Indicator Lights PLC Ladder Logic | Video |
| 30 | Up Counter – CTU Instruction Explained | Video |
| 31 | Down Counter – CTD Instruction | Video |
| 32 | Up and Down Counter – CTUD Instruction | Video |
| 33 | Bit Logic – NOT, SET & RESET Instructions | Video |
| 34 | Positive and Negative Edge Signals | Video |
| 35 | Siemens Tia Portal Comparator Instructions | Video |
| 36 | Greater-than or Equal-to and Less-than or Equal-to in PLC | Video |
| 37 | Greater-than and Less-than Instructions | Video |
| 38 | In Range Instruction in Tia Portal | Video |
| 39 | Out Range Instruction in Tia Portal | Video |
| 40 | OK and NOT OK Instructions | Video |
| 41 | Math Instructions in Siemens Tia Portal | Video |
| 42 | MOD NEG ABS Instructions | Video |
| 43 | INC and DEC Instructions | Video |
| 44 | Get Minimum (MIN), Get Maximum (MAX), LIMIT | Video |
| 45 | Square, Square Root, Natural Logarithm, Exponential Value | Video |
| 46 | Trigonometric Function in S7 1200 PLC | Video |
| 47 | Return fraction (FRAC), General Exponential (EXPT) | Video |
| 48 | Move Instruction in Siemens PLC | Video |
| 49 | PLC Convert and Round Instructions | Video |
| 50 | CEIL, FLOOR, TRUNC Instructions in Siemens PLC | Video |
| 51 | What is Scaling in PLC? – How to Scale the 4 to 20 mA Current Signal? | Video |
| 52 | Norm X and Scale X in Siemens Tia Portal | Video |
| 53 | Jump, Label, Jump if not | Video |
| 54 | Jump list and Return in Siemens PLC Programming | Video |
| 55 | Function block in Siemens PLC TIA Portal | Video |
| 56 | PLC Programming Examples and Solutions using Timers | Video |
| 57 | Single Push button ON and OFF PLC Program | Video |
| 58 | PLC Problem Make a Toggle Switch using Double Counters | Video |
We are updating this course with more topics, exercises, and example ladder logic.
Subscribe to our Youtube Channel and receive more updates. Click Here.
Automation Community Platform
Also, check our free PLC and SCADA course videos on our Automation Community website.
We recommend you register on the Automation Community website and enroll in the Siemens PLC Course.
Siemens Tia Portal Course: Register Now
The Benefits are
- Resume at last lesson
- Discussion group
- Assignments
- Quizzes
- Certificate
We are planning to make more courses which are free of charge as our main motto is to make the learnings reachable to as many people as possible and get it utilized for their best. Donate Now.
PLC Automation Courses
- Learn PLC in Hindi
- Omron PLC Training Course
- PLC and HMI Examples
- Allen Bradley PLC Course
- Siemens SCADA Course
I wanna learn full Tia portal
