Reading: Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
Inst Tools > Blog > PLC Tutorials > Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
This article provide step-by-step programming tutorials for Siemens S7 300 and STEP 7 PLC program using SIMATIC Software application.
Last updated: November 2, 2023 2:03 pm
15 Comments
6 Min Read
1.Open SIMATIC Manager. SIMATIC Manager is a program which manages subprograms of STEP 7.
2.To start our programming first we need to create a new project by clicking on the “new” icon on the toolbar to open the “new project” window.
In this window we enter a name for our project in the “name” field.The path to our saved project is shown in the “storage location.”
However we can use the browse button to navigate to a different location other than the default.
Siemens S7 300 Program
3.After creating the project we click on its name to highlight it.then from the “insert”   menu we select one of these “stations”dependent upon the control system that we intend to use.
4.After selecting “Station 300” we see that a subgroup named “SIMATIC 300” has been added to our project.
STEP 7 PLC program
STEP 7 PLC program
5.Next we click on this “hardware” icon which takes us to the hardware.
so that we can configure the modules we need for the PLC.Our PLC is an “S7 300″.
so we need to select the relevant modules from “SIMATIC 300” subgroup here.
SIMATIC Software
SIMATIC Software
6.First of all we need a rack into which we will mount the modules.
To insert the rack, open the “rack 300” and double click on the “rail” to add it to the left window.As you can see this rack has 11 slots.
7.We need to install a “power supply” in the first slot to power our PLC modules and turn them on.
To do this we open this “PS 300” folder and double click on this two-ampere power supply to insert it into the first slot of the rack
S7 300 PLC Programming
8.In the second slot of the rack we always insert the “CPU” module.To select the desired module we open this “CPU 300” folder, which opens to show us all types of “300 CPUs.”
We want to select a “316 CPU”, so we need to open this “CPU 316” folder and click on the relevant part number to insert it into the second slot in the rack.We can add rest of the modules in similar way.
9.The addresses of the digital input module range from byte zero to byte number one means that the addresses we can use in this module for our program start at “I 0.0”for the first input and continue through to“I 1.7” for the last input.
Similarly you can see the addresses of our digital output module range from byte number 4 through to byte number 5 so there are 16 addresses that we can use for this module starting at “Q 4.0” continuing through to “Q 5.7. Finish the configuration and download it to PLC
10.Before downloading Click on save and compile icon to save it.then we click on this download icon.This brings up a window where we need to select the CPU to which we want to download the configuration and then click “OK”.
In the next window click on “view” and then select the appropriate “MPI” address, and after clicking “OK” the configuration will download to the CPU.
Now, having completed the configuration we can check the project tree and see that a subgroup with the same name as the CPU has been added there.
PLC Programming using Siemens S7
11.Now we can write our program in a block named “OB 1″We can find the “OB 1” by opening the “S7 Program” folder and looking in the “block”folder.
Siemens S7 300 Application
12.open the “OB 1” by double clicking on it; as it’s the first time we have opened it this “properties” window opens.We simply OK the window to get into the programming environment.
Siemens PLC S7 300 Logic
13.Open symbol table from option menu to give a representative name for each I/O and save symbol table.
Siemens PLC S7 300 Screenshot
14.Make the PLC program as per project requirement.
15.Click on Download button to download the program in to PLC.
  • Siemens S7 1200 PLC configuration in TIA Portal
  • Siemens S7 300 CPU Status and LED Errors Explanation
  • PLC Input Output Modules
  • What is Interface Module in Siemens PLC?
  • How to Create New Project Using Simatic Manager
Latched and Momentary Operation of Motor PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
PID with Practical Example
HMI Handbook
15 Comments
  • Shahnawaz khan says:
    February 15, 2016 at 7:15 am
    Mr. Bharadwaj please improve user interface of this app
    February 15, 2016 at 7:17 am
    You done awesome work your all articals are very helpful i am engineer in cement plant where we use abb compact builder and siemens simatic can u post topic related to siemens simatic stl programming.
    • S Bharadwaj Reddy says:
      February 15, 2016 at 1:06 pm
      Hello Shahnawaz khan, Noted Down your requests. Thanks
  • Tarun says:
    March 15, 2016 at 7:21 pm
    Sir, Awesome blog for instrumentation guys..
    I also work in Oil & Gas sector. Plz add something related to Bentley Nevada vibration Monitoring and also some focus on Honeywell TDC300
  • maha says:
    May 23, 2016 at 11:56 am
    Please give difference between volumetric flow & Mass flow?
  • pr patil says:
    January 17, 2017 at 7:41 am
    plz…added plc programming related Queation and answers…..
  • Sohail k says:
    February 2, 2017 at 10:49 am
    Sir, your articles are very useful and informative for instrumentation people, I work in cement plant where we use Allen Bradley controllogix PLC, Can u post steps on Node scheduling for ControlNet using RSNetworx S/w.
  • nazim says:
    May 23, 2018 at 11:50 pm
    i need this software simatic manager if some one have kindly help me
  • Gnanamurthy says:
    February 1, 2019 at 10:09 pm
    sir please share s7.300 profibus dp configuration articles.
  • Soumen says:
    March 31, 2019 at 11:42 am
    Sir tell me why gap between 2 and 4 in hardware configuration??? Why we not used 3rd no slot.
  • Bibek Mondal says:
    June 26, 2019 at 9:56 pm
    where is the download option to download this SIMATIC MANAGER software ?
  • mansingh rathore says:
    July 3, 2021 at 11:50 am
    how to download Simatic manager software
      July 3, 2021 at 9:31 pm
      Follow this video:
      https://www.youtube.com/watch?v=FFKAaHsj-88&list=PLI78ZBihrkE1yvv_jpdsF24RpDF1Pye-z&index=4
  • Nabasa Stephen says:
    February 11, 2023 at 12:39 am
    Hello sir am Nabasa Stephen Student at Mbarara University of Science and Technology in Uganda doing Electrical Engineering
    as I tried to creat my first project and after saving and compiling so As I was trying to write my first programm in simetic7 and when I went a head to download the module it constantly tells me “unable to reach the module CPU316 via online interface”
    Kindly help me sir to solve this challenge and how can I fix
    Thanks
    • Jaydeep Lathiya says:
      June 11, 2023 at 4:11 am
      Go to Simatic manager> Go to Option> Go to “Set PG/PC interface” >>> Here you need to select option “PLCSIM MPI.1”
      Then it will work.
How to use JUMP Instruction in PLC Ladder Logic?
Principle of Operation of PLC
Doll Claw Machine using Omron PLC Programming
PLC Program to Count Running Hours of any Equipment
Tanks Draining Control in PLC using Functional Block Diagram
How Could FB and FC Make Me Professional PLC Programmer?
PLC Ladder Program for Automatic Car Wash using Siemens TIA Portal
Dry Contact in PLC
What is a Dry Contact? – Basics of PLC Wiring
Online time of the PLC
System and Local Time in PLC
Allen Bradley PLC communication is established
Procedure for Connecting Allen Bradley PLC and PC – RS Logix 500
How to use PLC With SQL Database
How to use PLC with SQL Database? – Basics & Tutorials
PLC Question Bank
PLC Question Bank
PLC Programming Best Practices and Tips
Pre-Engineering Design Documents
PLC Latched Circuit Example
PLC Latching Function
Advanced Skills Required for a PLC Programmer to Get a Job
Level Sensors
Advantages & Disadvantages of Level Measurement Systems
Job Skills Required for Industrial Electrical Maintenance
port-guided globe valve plug
What is Port-guided Globe Valve ?
relay-safety-in-plc
How to Reduce Relay Noise in PLC Systems?
Remote User Authentication
Security of Industrial Automation Systems
Flip Flops Objective Questions – Part 1
Flow Switch Symbol
Principle of Flow Switch
