Reading: Siemens PLC Organization Blocks (OB)
Inst Tools > Blog > PLC Tutorials > Siemens PLC Organization Blocks (OB)
Learn the Siemens PLC programming with a detailed understanding of Organization Blocks (OB) for beginners and freshers.
Last updated: September 30, 2024 4:52 pm
8 Min Read
Siemens PLC Organization BlocksWhat is the purpose of OB1 in Siemens PLCs?Which Siemens PLC organization block is triggered during a cold restart?What happens when OB3 is triggered in a Siemens PLC?Which OB is responsible for handling a hot restart in Siemens PLCs?What is the role of OB5 in Siemens PLC systems?When is OB6 triggered in a Siemens PLC?Which OB handles time-of-day-based operations in Siemens PLCs?What is the purpose of OB8 in Siemens PLC systems?Which Siemens PLC OB is responsible for time error interruptions?When is OB20 triggered in Siemens PLCs?What is the role of OB30 in Siemens PLCs?What is the significance of OB35 in Siemens PLCs?When does OB40 execute in Siemens PLCs?What condition triggers OB80 in Siemens PLC?What does OB81 handle in Siemens PLCs?What is the purpose of OB82 in Siemens PLC?What happens when OB83 is triggered in Siemens PLC?What condition activates OB85 in Siemens PLC?What does OB86 manage in Siemens PLCs?What kind of error triggers OB87 in Siemens PLC systems?When is OB88 executed in Siemens PLCs?What is the function of OB100 in Siemens PLC?Which OB is responsible for programming errors in Siemens PLCs?What happens when OB122 is triggered in Siemens PLC?What is the function of OB41 in Siemens PLC systems?What happens when OB42 is triggered in a Siemens PLC?When is OB55 executed in Siemens PLC systems?What is the purpose of OB56 in Siemens PLCs?What does OB84 handle in Siemens PLC systems?What is the role of OB72 in Siemens PLC systems?
Test your knowledge of Siemens PLC OB blocks.
Question 1
A. Manages cold restart
B. Handles power supply faults
C. Executes the main program cycle
D. Monitors communication errors
Show the Answer
Question 2
A. OB4
B. OB100
C. OB2
D. OB3
Show the Answer
OB2
Question 3
A. Time of day interrupt
B. Cold restart
C. Startup block execution
D. Warm restart
Show the Answer
Warm restart
Question 4
A. OB4
B. OB2
C. OB35
D. OB3
Show the Answer
OB4
Question 5
A. Power supply management
B. Manages rack failures
C. Startup organization block
D. Handles time delay interrupts
Show the Answer
Question 6
A. On time delay
B. On cyclic interrupt
C. On diagnostic interrupt
D. On delay interrupt
Show the Answer
On delay interrupt
Question 7
A. OB87
B. OB7
C. OB6
D. OB80
Show the Answer
OB7
Question 8
A. Manages hardware interrupts
B. Monitors communication errors
C. Deals with power supply faults
D. Handles cyclic interrupts
Show the Answer
Question 9
A. OB35
B. OB40
C. OB121
D. OB10
Show the Answer
OB10
Question 10
A. On module insertion/removal
B. During diagnostic data monitoring
C. When a time delay interrupt occurs
D. When there is a communication error
Show the Answer
Question 11
A. Handles diagnostic interrupts
B. Handles cyclic interrupts
C. Monitors I/O access errors
D. Manages hardware failure
Show the Answer
Question 12
A. Time delay interrupt
B. Configurable time for cyclic interrupts
C. Manages rack failures
D. Power supply error handling
Show the Answer
Question 13
A. During a hardware interrupt
B. During a power supply failure
C. After a cold restart
D. During a programming error
Show the Answer
Question 14
A. I/O access error
B. Time error
C. Power supply failure
D. Diagnostic data failure
Show the Answer
Time error
Question 15
A. Time delay interrupts
B. Communication errors
C. Cyclic interrupts
D. Power supply faults
Show the Answer
Power supply faults
Question 16
A. Tracks rack failures
B. Monitors diagnostic errors
C. Handles module insertion/removal
D. Manages I/O access errors
Show the Answer
Question 17
A. Communication error detected
B. Power supply fault
C. Time error handling
D. Module insertion/removal detected
Show the Answer
Question 18
A. Program cycle error
B. Diagnostic data failure
C. I/O access error
D. Hardware interrupt
Show the Answer
Program cycle error
Question 19
A. Programming errors
B. Time delay interrupts
C. Rack failures
Show the Answer
Rack failures
Question 20
C. I/O access error
Show the Answer
Communication error
Question 21
A. After a module is inserted or removed
B. When diagnostic data is collected
C. During a warm restart
D. When a time error occurs
Show the Answer
Question 22
B. Executes during startup
C. Monitors diagnostic data
D. Handles warm restarts
Show the Answer
Question 23
A. OB121
B. OB10
C. OB80
D. OB85
Show the Answer
OB121
Question 24
A. I/O access error occurs
B. Program cycle completes
D. Diagnostic data is collected
Show the Answer
Question 25
B. Handles time delay interrupts
D. Monitors cyclic interrupts
Show the Answer
Question 26
B. Isochronous mode execution begins
C. Diagnostic interrupt occurs
D. Power failure detected
Show the Answer
Question 27
A. When a time delay occurs
B. For time-of-day synchronization
C. On communication failure
D. During hardware interrupt
Show the Answer
Question 28
A. Handles isochronous mode synchronization
B. Manages warm restart
C. Monitors cyclic interrupts
D. Deals with I/O redundancy errors
Show the Answer
Question 29
A. Communication synchronization
B. I/O redundancy errors
C. Isochronous mode execution
D. Time-of-day synchronization
Show the Answer
Question 30
A. Detects time delay interrupts
B. Handles communication errors
C. Manages CPU redundancy errors
D. Monitors I/O access failures
Show the Answer
Modbus Communication between Delta PLC with VFD
Motor Feedback Fail Logic in PLC
How Weigh Feeder Works ?
Tia Portal – Different Instances of Calling a Function Block
Comparator in PLC Programming
Difference between PLC and HMI
Step-by-Step Guide to Choose Right Fuse for a Panel
Tanks Draining Control in PLC using Functional Block Diagram
What is the OPC Server?
Which Language is Best for PLC Programming?
PLC Program for Stage Control: Curtains and Stage Elevation
Micro PLC
Micro PLC Hardware Configuration
ON DELAY TIMER AS OFF DELAY TIMER
PLC Programming Example with Pushbutton and Motor
PLC Automatic Control of Two Outputs with one Input
Offline UPS
UPS Working Principle and Types – Offline and Online UPS Systems
Example of Controlling the PLC Output using Push Buttons
What is PID Controller
What is PID Controller?
PLC Program for Burglar Alarm Security System
PLC Program for Alarm Security System
Plug Valve Parts
What is Plug Valve ?
resistor-color-coding-example
IEC labelling for Resistors Color Code
PN Junction Questions & Answers
Measurement and Instrumentation Objective Questions – Part 5
9 Best E-Book Apps for Students
Liquefied Petroleum Gas (LPG)
Properties of Liquefied Petroleum Gas (LPG)
ACSR (All Aluminium Conductor Steel Reinforced)
What is an Overhead Cable? Types of Overhead Conductors
Difference Between Static and Temp Memory in Siemens TIA Portal
Ground Rod
What is a Ground Rod?
