Reading: Shift Bit Register in PLC
Inst Tools > Blog > PLC Tutorials > Shift Bit Register in PLC
In this article, we will learn the concept of shift bit register in PLC programming including shift and rotate Instructions.
Last updated: May 17, 2023 12:00 pm
6 Min Read
There are many instructions in PLC that help in executing the logic in a simplified way. Instructions come in various categories like arithmetic, comparison, logical, controller, etc. For example, a simple addition instruction for adding two variables comes in the arithmetic category. So, similarly, many types of instructions are available in a PLC logic.
Shift Bit Register in PLCShift InstructionRotate Instruction
One such instruction which is widely used in PLC programming is shift instruction. It comes in the category of numerical processing.
In this article, we will learn the concept of shift bit register instruction in PLC programming.
As the name implies, a shift instruction is a command for shifting bits of a word by some predefined position.
For example, you have a word of 16 bits. You want to move bit number 3 from its current fourth position to the seventh position. So, whenever a shift command pulse is given, the bit will shift in each trigger from the fourth position to the seventh position.
In that continuity, the bit in the fifth position will move to the eighth position; and the bit in the third position will move to the sixth position. So, here, you are shifting the bits in a group by the number of positions you define.
Shift Instruction
Shift instructions come in two types – shift and rotate. Let us have a look at the rotate instruction. Consider a syntax – %MW10:= SHL (%MW12, 4). %MW10 is the destination memory word and %MW12 is the source memory word.
Refer to the below image. In %MW10, when a first trigger for shift left is given, bit0 shifts to bit1, and so on. This result is stored in %MW12. When such triggers are given four times, ultimately, bit 0 will shift finally to bit 4, and so on.
The end result is stored in %MW12 anyways and you get a final answer of the bits shifted by four positions from the source word. But, one thing to remember is, with each shift, the preceding bit is filled with value 0. This you can see clearly in the image.
After the first shift, the first bit in %MW12 is 0. So, after four shifts, the end result will be – 0000 1101 1100 0000. This shift can thus be either right or left.
One more type of shift comes in PLC; the earlier one added zeroes from the preceding position, but this second type keeps the value of the first bit (MSB for right and LSB for left) as it is. This is called arithmetic shifting.
So, if the value of the first bit (MSB for right and LSB for left) initially before the shift was 1, then the last bit will remain as 1 only and the zeroes will be added from the second preceding bit up to how many times the shift command is given. It is to be noted that the last bit which is shifted is always stored in a carry bit.
Rotate Instruction
The second type is rotate instruction. Consider the syntax – %MW10:= ROL (%MW12, 4). %MW10 is the destination memory word and %MW12 is the source memory word. We will use the same above image for reference. Rotate instruction, as the name defines, just rotates the bits by how many positions you define.
Compared to shift instruction where zero was added after every preceding bit; here, the bits are just shifted in the same sequence as it is in the left direction. So, suppose you have a source word of – 1100 1010 1100 0101; then, after a trigger of 4 positions, the end result will be – 1010 1100 0101 1100. The same logic works in the right direction. The last bit shifted is also stored in a carry bit.
One more type comes in the rotate category. Here, instead of shifting only 16 bits, the carry bit to is rolled over. This means, the last bit is shifted to the carry bit, and the carry bit will then be shifted to the first bit, and so on. In the earlier type, the last bit was only stored in the carry bit.
  • Find the Best PLC for Your Project
  • HMI Screens on a Mobile or Tablet
  • Top Automation Vendors in World
  • Tia Portal Interrupt Organization Block
  • Types of Sensors Used in Automobiles
PLC Program – Controls Conveyors ON and OFF Sequence
#2 PLC Best Practices – Track Operating Modes
Inside the PLC Control Panel: How Much Do You Know?
PLC Program to Count Running Hours of any Equipment
Open User Communication in Siemens Tia Portal – PLC to PLC
Difference between DCS, PLC, and RTU ?
SCADA Systems
How to Create New Project in Studio 5000?
Five Types of PLC Programming languages
How to Select a SCADA for New PLC Project?
What are FIFO and LIFO Sequences in PLC?
How Could FB and FC Make Me Professional PLC Programmer
How Could FB and FC Make Me Professional PLC Programmer?
PLC Program for Automatic Oil and Water Separation Process
Oil and Water Separation Process using PLC Programming
Why Baud Rate is Important in Modbus Network
80+ PLC MCQ
80+ PLC MCQ Questions
PLC attendance system design
PLC Program for Automatic Mixing Controlling in a Tank
Safety PLC Programming steps
Safety Door Interlock PLC Program
PLC Programming Example on Bottle Line Control
Sulphur Di-oxide Monitoring Questions & Answers
Fail Safe Switch Circuit
Basics of Fail-safe Circuits
Thermal Conductivity Analyzers Questions & Answers
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
Frequency Division Multiplexers Objective Questions
Difference Between Robotics and Automation
Stainless Steel CNC Machined Parts
Everything You Need to Know About Stainless Steel CNC Machined Parts
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
