Fuse is an electrical device that is used to protect an electrical circuit by burning itself in case of overcurrent and overheating.
As we know, the temperature increases and decreases with an increase or decrease in current. When the current exceeds a certain limit, the temperature rises to such an extent that the metal strip of the fuse blows out.
As this strip is connecting the circuit, it is now broken in this case and the circuit is thus protected. There are many types of fuses available, but one of the most famously used ones is a semiconductor fuse.
In this post, we will learn the concept of a semiconductor fuse.
What is a Semiconductor Fuse?
Semiconductors are high-speed operation power electronics devices. They act so fast, that the switching speed is very high and they can thus, instantly perform their operation.
As the name implies, a semiconductor fuse uses semiconductors in its construction. The most common components used in making it are diodes, thyristors, and SCRs.
But, it will also be a fact to know that the semiconductor fuses are used to protect semiconductor applications like MOSFET, IGBT, power supplies, rectifiers, diodes, etc.
The working of a semiconductor fuse is the same as the standard fuse. It has a thin metal strip that is connected to the main electrical circuit. When the current starts to flow through the strip, and if it exceeds its rating, then it will blow up.
This will disconnect the circuit. Semiconductor fuses generally range from 125 to 2,100 volts and are available in a wide variety of shapes and sizes.
The main difference in its working is that it can also identify voltage overshoots and break the circuit. You must be knowing that a normal standard fuse is defined by its current rating. It will trip based on overcurrent. But, a semiconductor fuse has a distinct identity in that it can also detect overvoltage and blow itself.
A semiconductor fuse consists of a body that is made with thermally stable aluminum oxide ceramic. Between the fuse element (metal strip) and body lies a filler that is made with oxidant-resistant fine silver. The silver material has a melting point of 960°C which can resist the maximum operating temperature of the limiter.
Characteristics of Semiconductor Fuses
Let us understand some general characteristics which differentiate it from a normal fuse.
- The main difference is the operation speed. It is very quick in operation, which means that as soon as some fault condition is detected, the fuse will blow up immediately. The response time is very fast and thus, it protects the circuit from any further damage.
- Though it is fast in operation due to the use of semiconductors, it cannot be used for high-voltage rating devices like motors and heavy-duty loads. So, this fuse is best suitable for semiconductor devices which are low-current operation devices.
- These fuses are used in different applications like protection of short circuits, overvoltage, overcurrent, slew rate control, TSD (thermal shutdown) & RCB (reverse current blocking).
In this way, we saw the concept of a semiconductor fuse.
| Title: | Protecting Semiconductors with high-speed fuses |
| Author: | EATON |
| Format: | |
| Size: | 1.39 MB |
| Pages: | 36 |
| Download: | Click Here |
- Motor Maintenance
- Buchholz Relay Principle
- How do AC Drives Work?
- Electric Motors Noises
- Why is IGBT used in VFD?
