Reading: Rockwell PLCs for Large Scale Applications
Inst Tools > Blog > PLC Tutorials > Rockwell PLCs for Large Scale Applications
In this article, we will discuss about the Rockwell PLCs and ControlLogix Controllers for large scale applications.
Last updated: September 28, 2022 4:07 pm
3 Min Read
In the first part, we overviewed the PLCs used for smaller and medium applications. The second part overviews the PLCs used for higher-level applications.
ControlLogix 5580 ControllersControl Logix 5570
This PLC is one of the fastest range of devices in the Rockwell family. It is highly optimized and provides very good productivity. It is a good PLC for motion applications, as it manages integrated motion over Ethernet/IP for high-speed applications.
It’s Guard Logix 5580 range has SIL2 and SIL3 layers of safety solutions in it. It has an onboard display and a 2GB SD card slot facility.
One of the standby features of this PLC is its exceptional level of tolerance toward high temperatures and its convection-cooled design.
The software used for programming is Studio 5000.
Control Logix 5570
Control Logix 5570
It has integrated Sercos motion. It has many communication protocols – like Ethernet/IP, Control Net, Device Net, Data Highway Plus, Remote I/O, Sync Link, etc. Its Guard Logix 5580 range has SIL2 and SIL3 layers of safety solutions in it.
One of the standby features of this PLC is its exceptional level of tolerance toward high temperatures and its convection-cooled design. The software used for programming is Studio 5000.
Rockwell’s range of controllers also has a vast range of distributed IO and racks and modules for fail-safe, efficient, and hybrid types of communication and programming. It has other controllers and devices too, but we will not cover all the types in this post.\
I have attempted to cover the most and generally used types of PLCs in Rockwell.
In this way, we had an overview of the various types of Rockwell PLCs in both the posts; ranging from small-scale to large-scale applications.
  • SCADA Software Comparison
  • Function Blocks in Studio 5000
  • Industrial Automation Cables
  • Electrical Earthing Calculations
  • Smart Spray System using PLC
Types of Noise in Electronics
PLC based Automatic Packaging System
Raw Counts to Engineering Units : Conversion Formula
System and Local Time in PLC
Real-time PLC Projects – Industrial Automation
SCADA Engineer Job Responsibilities and Skills
Alarm Acknowledge using PLC
Timers using Statement List (STL) PLC Programming
Structured Text PLC Programming for Automatic Gate Control
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Ladder Diagram Example using Memory Bits and Set Coils
Types of Allen Bradley PLC
Up Counter PLC Program
Factory IO PLC Course
Factory I/O PLC Automation Training Course (Free)
Save and BR Memory in Siemens PLC Programming
SAVE and BR Memory Instructions in Siemens PLC Programming
Ethernet IP Commissioning Tool software
How to Configure IP Address in Rockwell PLC?
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
PLC Program using Bitwise Instructions
Allen Bradley Bitwise Logical Operations
High-Speed and Fast Counters in PLC
What are High-Speed Counters and Fast Counters in PLC?
Short Notes on Rectifiers & Filters
The Importance of Engineering Surface Plates
Electrical Machines MCQ Series 3
Single Phase Voltage Source Inverter (VSI) Objective Questions
Bubbler level measurement
what is a Bubbler System?
Motor Controls
Design and Implement Motor Control – Electrical Engineering
Piston No-Diaphragm Seal Instrument
Seal Pressure Instruments Root Cause Analysis
gauge’s bourdon tube
Pressure Gauges : Remote and Chemical Seals
