Reading: Purge Type Level Transmitter Questions
Inst Tools > Blog > Practical Questions > Purge Type Level Transmitter Questions
Purge type level transmitter used to detect hydrostatic pressure in a vessel for the liquid level measurement applications.
Last updated: November 16, 2020 10:09 am
Practical Questions
2 Min Read
Purge systems may be used to detect hydrostatic pressure in a vessel even when there is no dip tube.
For example, in this level measurement system, compressed air is used as a purge medium directly into the vessel where the transmitter tubing connects:
First, calculate the appropriate calibration range for the DP transmitter in this application.
Next, explain what would happen to the transmitter’s output if the lower connection to the process vessel became plugged by debris (despite the cleaning action of the compressed air flowing through it). Alternatively, what if only the upper connection became plugged?
Answer:
DP range = 0 to 308.8 ”WC = 0 to 11.15 PSID
If the lower process connection were blocked by debris, the transmitter’s output signal would increase, quite possibly to a magnitude greater than 100%. Just the opposite would happen if the upper process connection plugged.
Also Read: Purge Level Measurement Principle
More Questions:
1. Why would anyone choose to continuously purge the nozzles of a hydrostatic level transmitter when they could have easily chosen remote seals (diaphragms)?
2. Is air always a safe purge fluid to use? If not, what are some valid alternatives?
3. Suppose a slug of process liquid were to find its way into the “H” side impulse line leading up to the DP transmitter. How would this bit of liquid affect the transmitter’s accuracy?
4. Suppose a slug of process liquid were to find its way into the “L” side impulse line leading down to the DP transmitter. How would this bit of liquid affect the transmitter’s accuracy?
  • Instrument Hook Up Diagram
  • Instrumentation and Control MCQ
  • Pressure Gauge Datasheet
  • Temperature Controller Problem
  • Pressure Measurement MCQ
Credits: Tony R. Kuphaldt
Draw Limit Switch Symbol ?
How Measurement Span of Pressure Gauge Could be Changed?
Type E thermocouple Calculations
Calculate the Magnitude of Hydrostatic Pressure
Questions on Pneumatic Transmitter and Repeater
Which Instrument is at Fault in this System?
Identify the Purpose of Flow Ratio Controller
Calculate Process Temperature using a Thermocouple
Three-valve Manifold on Remote Seal DP Transmitter
Problem with Sump Tank Level Transmitter
Level Measuring Instruments Velocities of Propagation
Programmable Logic Controller (PLC) Questions and Answers – 8
Thermocouple Terminal block Questions
What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
Heat Exchanger Differential Pressure Transmitter
simple motor start-stop circuit
Liquid Level Switch Control Logic
Pneumatic Level Transmitter Calibration Table
Calculate Incident Power in Radar Level Measurement
compressor emergency shutdown system
Compressor Emergency Shutdown Root Cause Analysis
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
liquid level Measurement
Hydrostatic Level Measurement – Temperature related Density Change Effects
Basics of Amplifiers Interview Questions
Amplifiers Questions & Answers
PLC Example on Switch Program with Timers
Internet of Things (IOT)
History of Internet of Things (IOT)
Engineers Interview Android App
What is Pump Cavitation
What is Pump Cavitation? How to Avoid Cavitation?
Independent-Voltage-Source-circuit-ideal-battery
Circuit Elements and Types of Circuits
Fluorescent Screen of CRT
CRT Fluorescent Screen
Reflex Level Gauge Parts
What is Reflex Level Gauge?
