Reading: How to Use Production Line Failures for Your Gains?
Inst Tools > Blog > Common > How to Use Production Line Failures for Your Gains?
In this article, we will learn how to use the maintenance time during production line failures to our gains and benefits.
Last updated: January 23, 2023 10:31 am
Mahmoud Salama
Common
9 Min Read
Industrial process failures and production downtime are inevitable at any facility. Production lines face many challenges in the pursuit of keeping it running and producing with the required criteria.
Production FailuresMechanical FailureElectrical FailuresAuxiliary System FailuresProduction Parameters failuresMaintenance PlanExample Maintenance Plan for a Production ProcessMaintenance Plan StructureConclusion
And a big challenge for any maintenance engineer is to minimize the downtime of the product line and also the number of stops due to failures. But that is not achievable all the time, and you’re bound to have some setbacks that cause line stops and production downtime.
Production Failures
In this article we will try to find another way of viewing the production stops and how can we gain some benefits from it. It might sound strange, but let’s try.
First, let’s classify different reasons for production line downtime.
Production line stops due to failures can be classified as follow:
  • Mechanical failures.
  • Electrical failure.
  • Auxiliary systems failures.
  • Production parameters failures which lead to a plant trip.
Mechanical Failure
Some mechanical failures in a production line
  • Physical Wear and Tear
  • bearing failure
  • metal fatigue
  • corrosion
  • misalignment
  • general surface degradation
  • Oil leakages
  • Gearboxes overheating or blocks,
  • Belts or chains failures.
Electrical Failures
Some electrical failures in a production line
  • Electrical Motors failures ( overheating, overloading, blocks/jams)
  • Defected sensors
  • Defected actuators
  • Power Cut-Offs
  • Electric drives failures
  • Communication failures between different sections of your process.
  •  Compressors  (Pressured air )
  • Chillers  ( chilled water )
  • Water treatment systems
This happens when the production line is running, but the production criteria required cannot be achieved, which requires some changes in the process parameters, and sometimes that can lead to production stopping for a while to figure out the actual cause of deviating from the needed criteria.
Any failure in one of the previous systems can cause line stops and production downtime. And in this article, we will talk about how to make use of time used to resolve these issues.
In this article, we are not talking about how to reduce downtime or minimize line stops which is a very important topic as well, here we will focus on how to use the inevitable downtime for our gain.
Maintenance Plan
As a maintenance engineer, you should have a plan for planned maintenance, which is usually done at a specific time, for example, every 3 months, 6 months, or yearly.
This planned maintenance usually is executed all together at the same time which needs a lot of production time stop.
Following is a sample table giving an example of a maintenance plan for a production process.
sample table of a standard maintenance plan
Figure 1 – sample table of a standard maintenance plan
As you can see from the above table Asset 1 is planned for 3M maintenance in Jan. and the next time will be in April.
The maintenance scheduled time for each asset is shown in the next picture.
Assets maintenance time
Figure 2 – Assets maintenance time
The maintenance plan as shown before will need the 5 assets a production stop for at least 1610 minutes. That means more than a whole day – 26 hours – of production downtime for only 3M planned maintenance.
Why this way of maintenance structure takes a long time?
Let’s discuss these with detailed explanations.
  • Limited manpower:
You can reduce maintenance time with more manpower executing the maintenance, but that is not an option for many facilities. So you have to plan your maintenance according to how many personnel you have.
  • Conflicted maintenance between different departments:
 Sometimes you need to wait for other departments to finish their work before you can start yours. Conflicts between mechanical and electrical maintenance are the very common reason why you need more time to finish.
A simple example of that is when the mechanical team needs an electrical team to disconnect the power cable of a motor so they can change its bearing. And all manpower of electrical team is doing other tasks at the moment.
  •  Lots of maintenance points at the same time:
Trying to finish all 3M maintenance for all assets at one production stop means you need to do a lot of works and maintenance points.
Now, check the following maintenance plan structure.
improved maintenance plan
Figure 3 – improved maintenance plan
 You see how now Asset 1 is divided into 5 different sections, each section has its 3M maintenance, and by executing all 5 sections you will finish the 3M for Asset 1.
The next picture shows how the maintenance times are affected.
Improved maintenance plan execution times
Figure 4 – Improved maintenance plan execution times
As you can see, Asset 1 maintenance time is still 400 minutes, so how is this structure any different?
As mentioned before, production downtime due to failures is inevitable, so you can expect to have some hours of production downtime due to different failures, and here is where the new maintenance structure can be of benefit to you.
Check the following sample of production downtime due to failures in January.
Sample of a production Downtime
Figure 5 – Sample of a production Downtime
See, how we lost about 760 minutes of production time in January. With the old maintenance structure, all this downtime is completely wasted. But with the new maintenance structure you can benefit from some of the Downtime presented because when there is a mechanical failure in the line, you would expect the mechanical team to respond to that failure, with all other teams having nothing to do.
But now, when the production stopped for 100 minutes on the 3rd of Jan because of an electrical failure, the mechanical team can use this time to finish some of the planned maintenance for this month.
All following maintenance can be done within the downtime period:
maintenance within the downtime period
So in the 100 minutes of downtime, there are 6 items that can be executed within the stoppage time, it all depends now on the manpower available and how much it can finish within this time.
Another example is when a mechanical failure caused production to stop for 250 minutes on the 15th of Jan, the Maintenance department can use this time to try and finish some of the other maintenance tasks for this month.
They can finish one of the following:
Asset 3120 minutes
Asset 5170 minutes
So, you can see how now the inevitable downtime of your production line will be of benefit to you in reducing overall maintenance time. So when the production stops for the planned maintenance, you will not use as much time as you needed before.
This simple change in your maintenance structure is helpful as long as you can divide your assets into smaller sections. The more sections you can divide your assets, the more likely you would be able to use failures downtime for your benefit.
Conclusion
  • There are too many variables that could go wrong in a process, which is why production line downtime failures are inevitable.
  • You can use these downtimes for your benefit if you can use this time for other tasks besides fixing the failure.
  • With a simple change in your maintenance plan, you could be able to use failures downtime.
  • The more you divide your assets, the more likely you could benefit from downtimes.
Top 100 Microcontrollers Project Ideas
Strain Gauge Accelerometer
D’Arsonval Movement
Modern Engineering Solutions for Rotary Equipment
Five Types of PCB Assembly that You Should Know
Hydraulic Motor Forward and Reverse Control with Simulation
How is Electricity Generated From Wind Energy?
Smart Transmitters Advanced Diagnostics
What is a Vent Filter? – Water Treatment Plant
Top US Universities that Offer Online Education
Classification of HVAC Chillers
Most Commonly Used Raw Materials in a CNC Machine Shop
What is Reproducibility?
Essential Safety Tips for Glass Workers
Best Online Courses to Learn Electrical Engineering
Difference Between Adhesion and Cohesion
Power Tool Maintenance
Power Tool Maintenance – When And How To Replace Carbon Brushes
Different Types of HVAC Applications
Hydraulic Systems
Two Wire Transmitter Working Principle
Basics of Two, Three & Four Wire Transmitters
D.C Tachogenerator Principle
Diaphragm Pump
What is a Diaphragm Pump?
Difference between Accuracy, Tolerance, Uncertainty, and Error
Smart Sensors Objective Questions
pH Analyzers Interview Questions Answers
pH Analyzer Interview Questions and Answers
Ammonia Analyzer Working
Ammonia Analyzer Principle
What is a Condensate Pot? How to Install it?
Data Instance in PLC
Tia Portal – Different Instances of Calling a Function Block
Single-Phase Half Wave AC-DC Converter Questions
Industrial IoT Job Roles and Responsibilities
IoT Engineer Job Roles and Responsibilities
