Reading: Procedure for Reading or Searching the Tag number in Siemens PLC
Inst Tools > Blog > PLC Tutorials > Procedure for Reading or Searching the Tag number in Siemens PLC
In this article, we will learn the procedure for reading or searching the tag number in Siemens PLC using Simatic Manager software.
Last updated: October 14, 2021 9:05 am
3 Min Read
Siemens PLC: Simatic Manager Training Course
The below step-by-step procedure will help you to locate the required instrument or tag in the Simatic manager program.
Step 1:
Open Siemens Simatic Manager Software
Step 2:
Search for the Required PLC Program and then Press OK.
Step 3:
Click on S7 Program and then Click on Symbols as shown in below figure.
S7 Program and Symbols
Step 4:
A new window will open and Press Okay.
A new PLC window will open and Press Okay.
Step 5:
Go to the menu and open “Find and Replace”.
Enter the required tag. Say we need a temperature transmitter, so enter “temp” text.
Then click the “Find Next” option as shown in the below image.
Search for required tag in Simatic Manager
Step 6:
Now the list of tags will be displayed.
Say we need “first stage discharge temperature” of equipment.
Scroll down and check for the tag description.
Then note down the respective tag address as shown in the below image.
Find the Tag and note down the address in plc
Step 7:
Select “S7 Program” and expand the folder.
Select “Blocks” in the left sidebar.
Then click on the “OB1” from the new window as shown in the below image.
Blocks and OB1 in Simatic Manager
Step 8:
A new window will open and press OK.
LAD STL FBD Program Blocks
Step 9:
Click on the variable in the rung and right-click on it.
Then select the “Go to” option and then select “Location”.
Step 10:
Now a new window will open. Enter the Tag address. Then click the “Go To” button.
Then it will display all the tags.
Now again select the respective rungs and click the “Go To” button and find the required tag.
Search for the block rung, select it and then click the “Go To” button again.
Procedure For reading or searching the tag number in Siemens PLC
Step 11:
Then it will display where the tag is further connected in the logic.
Search Tag in Siemens PLC
Credits: PLQP Instrumentation Team
  • Top 100 PLC Projects List
  • Download Allen Bradley RSLogix PLC Software
  • Configuration of Input and Output Tags
  • What is Human Machine Interface?
  • Tagging Philosophy for Junction Box, Cable
Studio 5000: Programming Three Motors with Fixed Priorities
Types of Interrupt OB in Siemens Tia Portal
One-Shot Rising and Falling Edge Instructions in Rockwell PLC
Compare Servo Motor and Stepper Motor
T Flip Flop PLC Ladder Diagram
PLC Program for Automatic Parameter Initialization When Power UP
PLC Ladder Logic Example
PLC Functional Block Diagram for Logic Gates
PLC System Site Acceptance Test (SAT)
What is a Wet Contact? – Basics of PLC Wiring
PLC Handbook
Various Control Methods in Servo Motor Drives
SCADA Standards
SCADA for Substation Automation
Push button Motor PLC Logic
PLC Control for Baking Machines Logic
PLC Programming for Baking with Auto and Manual Modes
Pulse Generation using Timer in Siemens PLC
Multi-Tank Liquid Level Control System with Fill Priority [PLC]
PLC engineering software
How to Download GX Works? Mitsubishi PLC Software
What is Poppet Valve?
What is Poppet Valve? When we Use a Poppet Valve?
Resistance Temperature Detectors Troubleshooting Tips
Digital Electronics Objective Questions – Set 10
Programmable Read Only Memory Objective Questions – Part 2
NH3 Plant Turbo-compressor Sudden Rise in Temperature
stepper motors Animation
Fundamentals of DC Motor Animation
Steam Letdown Station Problems
Steam Letdown Station Problems and their Solutions
Applications of Synchronous Motors
