Reading: Pressure and Instrumentation MCQ – Questions & Answers
Inst Tools > Blog > Instrumentation MCQ > Pressure and Instrumentation MCQ – Questions & Answers
In this article, we shared the pressure and instrumentation objective questions (MCQ) and answers for instrumentation & electrical engineers.
Last updated: February 10, 2022 11:33 am
Instrumentation MCQ
11 Min Read
In this article, we shared the pressure and instrumentation objective questions and answers for instrumentation, electrical, and electronics engineers.
Pressure and Instrumentation MCQ - Questions & Answers
The below list provides all the multiple-choice questions (MCQ) related to the pressure measurement.
1. Considering the cost of instruments, which is a better choice, active or passive?
A)Passive instruments
B)None of these answers
C)Cost of both active and passive instruments are approximately same
D)Active instruments
2. Accuracy of a measuring instrument indicates the
A)Ratio of output value to the input value
B)Degree of freedom from random errors
C)Change in output with each change in input
D)Closeness of the output reading to the true value
3. For the measurement of high pressure with high accuracy the device used is
A)Ionization gauge
B)Bourdon tubes
C)Dead weight gauge
D)Manganin wire pressure
4. In light-emitting diode, the available light-emitting region is
A)Greater than 25 mm
B)From 2.5 to 25 mm
C)Greater than 50 mm
D)Less than 2.5 mm
5. The accuracy of the deflection type instruments and of the null type instruments depends on
A)Linearity, calibration of spring
B)Linearity and calibration of spring, calibration of weights
C)Calibration of spring, linearity and calibration of weights
D)Both depends on calibration of weight
6. If a pressure gauge of range 0-10 bar has a quoted inaccuracy of ±1.0 % of full-scale reading, then it means
A)Maximum expected error in any reading is 1 bar
B)Minimum expected error in any reading is 1 bar
C)Maximum expected error in any reading is 0.1 bar
D)Minimum expected error in any reading is 0.1 bar
7. Q meter is used to measure the properties of
A)Both Inductive coils and Capacitive coils
B)Non inductive coils
C)Inductive coils
D)Capacitive coils
8. The basic difference between square wave and pulse generators is their
A)Waveforms shape
B)Cost
C)Duty cycles
D)Frequency range
9. The full range of audibility in audio frequency oscillator is
A)20 Hz to 20 MHz
B)0 to 20 Hz
C)20 Hz to 2 kHz
D)20 Hz to 20 kHz
10. In a ramp type DVM, the multivibrator determines the rate at which the
A)Clock pulses are generated
B)Measurement cycles are initiated
C)Its amplitude varies
D)It oscillates
11. To increase the current sensitivity below 10 mV, an electronic instrument uses
A)Modulator
B)Transducer
C)Amplifiers
D)Oscillator
12. In the beginning, all the outputs of the successive approximation type register is at
A)Logic one
C)Toggling
D)Logic zero
13. To read and record a measurement, the indicating type instrument
A)Does not requires human intervention
B)Always requires human intervention
C)Requires human intervention only when the instrument consists of a rotating scale moving against a pointer
D)Requires human intervention only when the instrument consists of a rotating pointer moving against a scale
14. Instruments are subdivided into active and passive based on whether the output of the instrument is produced by the quantity being measured simply changes the magnitude of some external power source.​
The pressure measuring device and the float-type petrol tank level indicator are example of
A)Former is active instrument and later is passive instrument
B)Passive instruments
C)Former is passive instrument and later is active instrument
15. Dead weight gauge is used for the measurement of pressure of
A)About 7000 bar
B)About 1000 bar
C)About 5000 bar
D)About 2000 bar
16. An RMS reading voltmeter can accurately measure voltages of
A)Sine waveforms
B)Saw tooth waveforms
C)Square waveforms
D)All of these answers
17. In a deadweight gauge, weights are added on the top of piston until the piston reaches a datum level.​
The datum level is known as
A)Lowest point of the container
C)Highest level of fluid in the container
D)Null point, where the downward force balances the fluid pressure
18. The ionization gauge is an instrument used for the measurement of
A)High pressure
B)Very low pressure
C)Medium pressure
D)Very high pressure
19. Electronic voltmeters can be designed to measure
A)Only very small voltages
B)Only very high voltages
C)None of these answers
D)Both very small and very high voltages
20. The measurement range of the digital voltmeter is
A)1V to 1MV
B)1kV to 1MV
C)100 kV to 100MV
D)1V to 1kV
21. The microcomputer performs its computations in
A)Digital form
C)Either analogue form or digital form depending on their applications
D)Analogue form
22. In potentiometric type DVM, the adjustment of sliding contact is done by
A)A single phase servomotor
B)Two phase servomotor
C)Three phase servomotor
23. In electronic voltmeter, the range of input voltages can be extended by using
A)Input attenuator
B)Balanced bridge dc amplifier
C)Rectifier
D)Functional switch
24. In McLeod gauge,
A)High pressure fluid is expanded to a low pressure which is read by the monometer technique
B)High pressure fluid is expanded to a low pressure which is read by the bourdon technique
C)Low pressure fluid is compressed to a high pressure which is read by the bourdon technique
D)Low pressure fluid is compressed to a high pressure which is read by the monometer technique
25. The instrument used for the measurement of pressure is/are
A)All of these answers
B)Bellows
C)Diaphragms
D)Fiber optic pressure sensors
26. In the function generator, the output waveform of the integrator is
A)Triangular
B)Sinusoidal
C)Saw-tooth
D)Square
27. When the visual indication of pressure level is required then the instrument generally used is
A)Diaphragm sensors
B)Resonant wire device
C)Monometers
D)Bourdon tube
28. In liquid crystal displays, the liquid crystal exhibits properties of
A)Both Liquid and Solids
B)Liquid
C)Solids
D)Gases
29. Advantage of passive instrument is
A)It does not need power supply
B)Sensitive
C)Cheap
D)Accurate
30. In terms of usage, deflection type instruments are
A)More convenient than null type instrument
B)Less convenient than null type instruments
D)Both are equally convenient
31. The output of an analogue instrument varies
A)Continuously and can have an infinite number of values within its range of instruments
B)In discrete steps and can have an infinite number of values within its range of instruments
C)In discrete steps and can have an infinite number of values within its range of instruments
D)Continuously and can have an finite number of values within its range of instruments
32. If the displacement is measured with strain gauge then the number of strain gauge normally required are
A)Two
B)Three
C)Four
D)One
33. Depending on whether the display is numeric or alphanumeric, the segmental display is
A)Either 7 segmental or 14 segmental
B)21 segmental
C)7 segmental
D)14 segmental
34. A liquid crystal display requires
A)None of these answers
B)Both ac and dc drive
C)An ac drive
D)A dc drive
35. Which among the following is not the type of digital voltmeters?
A)Potentiometric type
B)Integrating
D)Ramp type
36. A capacitive pressure sensor has a typical measurement uncertainty of
A)± 0.4%
B)± 0.8%
C)± 0.2%
D)± 0.1%
37. Bourdon tube is used for the measurement of gauge pressure of
A)Solid
B)Both Gas and Liquid fluid
C)Gas
D)Liquid fluid
38. The measurements which can be simplifies by using X-Y recorders is /are
A)Regulation curves of power supplies
B)All of these answers
C)Hysteresis curves
D)Speed-torque characteristics of motors
Click Here for Answers
Next Quiz:
  • Control Valves Quiz
  • Measuring Instruments Quiz
  • Industrial Instrumentation Quiz
  • Distributed Control System Quiz
  • Thermocouple Questions & Answers
Circuit Protection Devices Objective Questions and Answers
Control Loop Multiple Choice Questions
Standard Test Signals Objective Questions
150+ Measuring Instruments Questions and Answers
Analysis Instrumentation Objective Questions
Semiconductor Sensors Objective Questions
100+ Questions and Answers on Industrial Automation and Control
100 Test and Electrical Measurement Objective Questions and Answers
Measurements & Instrumentation Quiz – Set 7
Ultrasonic Sensors Objective Questions
Bio Sensors Objective Questions
Instrument Technicians Tools – Instrumentation Test
Analog Modulators Objective Questions
Measurement and Calibration Objective Questions and Answers
Level Measurement Objective Questions
Control Valves Multiple Choice Questions
Circuit Measurement Objective Questions
Electrical and Electronics Circuit Measurement Objective Questions
Induction Motor Interview Questions Answers
Electrical Measurements and Instrumentation Objective Questions & Answers
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
How to Start Writing SCL in Siemens PLC
Rules for Writing SCL Language in Tia Portal
Multiphase Flow Meter Calibration Procedure
Power Flow Through an Inductive Impedance Questions
Free Industrial Control System (ICS) Cyber Security Training Course
Pole Placement by State Feedback
Electrical Torsion Meter
Electrical Torsion Meter Principle
Classic Control Circuits
Air Compressor Control Circuit has a Problem
Air Compressor Control Circuit Problem
