Reading: Identify Level Control Loop Tuning Problems
Inst Tools > Blog > Control Systems > Identify Level Control Loop Tuning Problems
Last updated: July 28, 2019 11:43 am
Control Systems Practical Questions
2 Min Read
A level control loop is supposed to maintain a constant level of liquid at the bottom of the stripping tower where considerable amount of vibration exists, but it seems to have a problem:
Level Control LoopAnswer :
Here is what the trend recording from Level Transmitter looks like during the time an operator placed the controller in manual mode and then back to automatic mode:
Level Control Loop
A fellow engineer tells you he thinks the controller is over-tuned (having too much gain). The operator, who just did the manual-mode test, disagrees.
Based on the information seen in the trend, what do you think the source of the oscillation is, and how would you go about testing your hypothesis?
Answer :
This oscillation is clearly not the result of an over-tuned controller, because it persists even when the controller is in manual mode. The source must be coming from somewhere else in the process.
At this point in time, it would be a good thing to note the frequency of this oscillation, and begin searching for anything that could cause the level to go up and down at this frequency, or perhaps something that could “fool” level transmitter (LT) into thinking the level is oscillating at this frequency. If the frequency is relatively high, local machine vibration could be the cause of it.
This hypothesis makes a lot of sense, based on the fact that the controller’s action in automatic mode doesn’t seem to be correcting the oscillations at all: the oscillation amplitude seems to remain unchanged between automatic and manual modes.
This is what we might expect from a vibration-induced oscillation, where the frequency of the oscillation is much faster than the liquid level can possible change, and therefore faster than the level control system can physically compensate.
Share Your Comments …
Articles You May Like :
Control Loop Questions
Safety Instrumented Systems
4-20mA Loop Power Supply
Feedback Control Loop
PLC Automatic Irrigation
What is Instrument Hook Up Diagram ?
Package Control and Safety Systems Implementation Methods
Programmable Logic Controller (PLC) Questions and Answers – 2
Identify Problem with Oily Water Filter Instrumentation
Ziegler-Nichols Open-Loop Method
  • Undefined says:
    April 9, 2019 at 12:11 pm
    how does the vibration can change the PV. @ i am having a flow transmitter which goes for 24 tph for 3 min and then comes to 21 tph , what could be the reason
What is DeviceNet?
Difference between DCS, PLC, and RTU ?
Solenoid Valves Questions & Answers – 4
Overview of Split Range Control
Layer-2 and Layer-3 Network Switches
How to Draw a Schematic Diagram ?
Simple Pressure Transmitter Circuit
Pressure Transmitter using Potentiometer and Diaphragm
Foundation Fieldbus
Foundation Fieldbus – Advantages, Limitations, Architecture
Proportional Band example
Why Offset in Proportional Controller ?
Problem on Solar Hot Air Collector and Variable Speed Fan
Programmable Logic Controller (PLC) Questions and Answers – 5
Internet of Things (IOT)
History of Internet of Things (IOT)
de-energized-to-safe-mode
Analytical Process Control Question
Distributed Control System Architecture for Profibus Field Instruments
H1 FF Physical layer
Electrical Motor Failures
Most General Reasons for the Electrical Motor Failures
Pneumatic Control Mechanisms Objective Questions
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
How to Locate Faults in Cables? - Fault Analysis and Location
How to Locate Faults in Cables? – Fault Analysis & Location
Valves Legend P&ID
Comparison of Gate Valves and Globe Valves
Sequential Operation of Output Bits using Two Push buttons
Level Measurement using DP Transmitters - Open Tank
Open Tank Level Measurement using DP Transmitters Animation
