Reading: Analytical Process Control Question
Inst Tools > Blog > Practical Questions > Analytical Process Control Question
Describe in detail the effect this calibration error will have on the performance of the analytical process control system.
Last updated: April 2, 2021 6:09 pm
Practical Questions
2 Min Read
In this process, maple syrup is heated as it passes through a steam heat exchanger, then enters an evaporator where the water boils off. The purpose of this is to raise the sugar concentration of the syrup, making it suitable for use as a food topping.
A level control system (LT, LIC, and LV) maintains constant syrup level inside the evaporator, while an analytical control system (AT, AIR, AC, and AV) monitors the sugar concentration of the syrup and adjusts steam flow to the heat exchanger accordingly.
Suppose the syrup analyzer (AT) suffers a sudden calibration problem, causing it to register too low (telling the analytical controller that the sugar concentration of the syrup is less than it actually is).
Describe in detail the effect this calibration error will have on the performance of the analytical control system.
More Questions
  1. What economic effect will this mis-calibration have on the process? In other words, does the process become more or less profitable as a result of this change?
  2. Suppose someone shuts the manual block valve on the steam line just a little bit, so that it is about 80% open instead of 100% open. How will this process change affect the control systems in this process?
Answer
The syrup’s sugar concentration will eventually become excessive as the analytical controller (AC) attempts to maintain setpoint.
Share Your Answers via Comments
Investigate High Level Alarm of Distillation Process
What is the Purpose of Chemical Seals Pressure Transmitter?
Level Measuring Instruments Velocities of Propagation
Practical Process Control System Questions & Answers – 11
Programmable Logic Controller (PLC) Questions and Answers – 2
Galileo Thermometer
Questions on Level Switches
What Affect the Pressure Measurement Accuracy of a Manometer?
Calculate the Magnitude of Hydrostatic Pressure
How Overload Heaters used to Automatically Shut the Motor OFF ?
A Series of False Pressure Alarms
Practical Process Control System Questions & Answers – 3
Hydrostatic Level Transmitter Questions
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Thermocouple Questions
Thermocouple Terminal block Questions
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
Calculate Total Hydrostatic Pressure at Bottom of Vessel
Suppose the lamp refuses to light up
Indentify Faults in Simple Lamp Circuit including Failed Wires
displacer level transmitter configuration
Displacer Level Transmitter Questions
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
Differential Capacitance Pressure Sensor Circuit
PLC Controlling a Motor
PLC Motor Control Ladder Logic Programming
Gas Filter Correlation (GFC) spectrometer
Gas Filter Correlation (GFC) Spectroscopy
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Digital Electronics MCQ
Digital Integrated Circuits Objective Questions – Part 3
ICS System Design
Level-Transmitters-Animation
Level Transmitter Animation
Heavy Equipment Transport
4 Tips For Shipping Large Construction Equipment
Pyrometer Principle
Optical Pyrometer Working Principle Animation
