Reading: PLC Sinking and Sourcing Explanation
Inst Tools > Blog > Animation > PLC Sinking and Sourcing Explanation
PLC Sinking and Sourcing describes a current signal flow relationship between field input and output devices in a control system and their power supply.
Last updated: November 2, 2023 2:41 pm
Animation PLC Tutorials
2 Comments
1 Min Read
“Sinking and Sourcing – describes a current signal flow relationship between field input and output devices in a control system and their power supply.
Sourcing I/O modules supply (or source) current to sinking field devices.
Sinking I/O modules receive (or sink) current from sourcing field devices.”
Sinking and Sourcing Devices Operation
PLC Sourcing & Sinking Concepts Principle
  • PLC Interview Questions and Answers
  • Alarm and Trip Documentation
  • What is Inductive Proximity Switch?
  • WirelessHART Network Protocol
  • Foundation Fieldbus Parameters
Yokogawa DCS and SIS System Architecture
Difference Between FC and FB in Tia Portal
Surface Grinding Process using PLC Program
Compare Two Offline PLC Projects
PLC Program for Temperature Control using Thermostat
PLC Output Types
2 Comments
  • Mohamed ragab says:
    December 28, 2016 at 1:48 pm
    graphics are switched too fast !! i. cant read them
  • Sandeep says:
    May 20, 2018 at 9:44 pm
    Any possibility of manually switching graphics.
Flexible Input Output Modules
What is a PLC Retrofitting Project? – Importance, Procedure
Main differences between Sinking and Sourcing Circuits
PLC Raw Count Calculation for Pressure Transmitter
PLC Programming: Sorting and Distribution of Boxes by Height
Pressure Transmitter Animation
Basics of PLC Programming
PLC Programming Sequence Logic
PLC Programming to Control Lights in a Sequence
Add an alarm display to the graphics.
How to Configure an Alarm in InTouch SCADA?
PLC PID tuning parameters
Vortex Flow Meter Animation
Pulse Generation using Timer in Siemens PLC
PLC program Permissive Circuit
PLC Electric Motor Interlocks
Area Velocity Flow Meter Principle
Quiz on Electrical Meters and Measurement
200+ Quiz on Electrical Meters, Measurement, and Troubleshooting
Stilling wells
Stilling Wells for Level Measurement
Hydraulic versus Pneumatic Systems
Electropneumatic Valve Positioner Working Principle
Electro Pneumatic Valve Positioner Schematic & Principle
Needle Valve Schematic
How Needle Valve Works ?
Compressor Coolers
Practical Process Control System Questions
Process Control Loop Testing
Difference Between MCB and MCCB
