  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: PLC Sequential Operation Example Program
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > PLC Tutorials > PLC Sequential Operation Example Program
Design a PLC program and explain the sequential operation using a push button example ladder logic programming.
Last updated: March 4, 2021 10:51 am
2 Min Read
Write a PLC program so that when the step push button is pressed and qw0 is equal to zero the first bit in the output word is energized by one, and when the step push button is pressed again the next bit is energized and so on till the reset push button is pressed.
Inputs & OutputsPLC Sequential Operation ExamplePLC ProgramRead Next:
This is an example of sequential operation of output bits using one push buttons.
Note: the best practice to learn the PLC programming is to start writing the PLC program, take your time before you review the answer.
Inputs & Outputs
I0.0: step Push Button (Normally open contact)
I0.1: reset Push Button (Normally open contact)
Qw0: output word i.e from (Q0.0 to Q1.7)
Memory Word order of bits
Before you start your programming you have to understand the order of bits when you hear memory word, here in the table attached you can figure out the address of any bit number.
PLC Program
Network 1:
In every time the positive edge of step push button is detected the shift left instruction moves 1 to next bit of the QW0,
if QW0 = 0 the move instruction is energized and move the hexadecimal value 16#8000 to QW0 which is equivalent to 1000 0000 0000 0000.
Network 2:
In any time when the reset push button is pressed, 0 is moved to QW0 which will reset all the output word.
Author: Karim Ali Anwar
  • PLC Permissive Inputs
  • PLC Sequential Operation
  • PLC Counter Comparison
  • Packaging Carton PLC Logic
  • Delta PLC Simulator
Download Allen Bradley RSLogix PLC Software
208kSubscribersSubscribe
Recent Comments
Related Articles
Why Use Normally-Closed Contact for Stop Buttons
Why Use Normally-Closed Contact for Stop Buttons?
Advanced Skills Required for a PLC Programmer to Get a Job
STAR DELTA Starter PLC Logic
STAR DELTA Programming using PLC Controller
Communicating Delta PLC Software to Simulator
Siemens Profibus Interface DP
How to Create New Project Using Simatic Manager
Simple Conveyor Control PLC Program
XG5000 Example of Simple Conveyor Control PLC Program
21 CFR in SCADA and HMI Systems
What is 21 CFR in SCADA and HMI Systems?
More Articles
Inductive Time Constant
Human Machine Interface
What is Human Machine Interface (HMI) ?
U-tube Water Manometer
How much Pressure applied to U-tube Water Manometer?
Emergency Block Valve
SIS Emergency Block Valves (EBV)
Disk valves
What is a Disc Valve ?
Top 100 Biomedical Instrumentation Engineering Projects for Students
Boolean Logic Operations Objective Questions
two chemical streams are mixed together
Practical Process Control System Questions & Answers – 12
