Reading: PLC Program to Control a Water Pump
Inst Tools > Blog > PLC Tutorials > PLC Program to Control a Water Pump
PLC program to control a water pump driven by an electric motor. It will be manually started and stopped by pushbutton switches, and shut down automatically by any one of several “permissive” switches.
Last updated: March 4, 2021 11:04 am
PLC Tutorials Practical Questions
3 Min Read
A engineer needs to write a PLC program to control a water pump driven by an electric motor. This water pump will be manually started and stopped by pushbutton switches, and shut down automatically by any one of several “permissive” switches.
The operating statuses of these switches are listed here:
  • Start pushbutton (normally-open): open when unpressed, closed when pressed
  • Stop pushbutton (normally-closed): closed when unpressed, open when pressed
  • Low water level (normally-closed): closed when level is low, open when level is adequate
  • Low oil pressure (normally-open): open when pressure is low, closed when pressure is adequate
  • High vibration (normally-closed): closed when still, open when vibrating
  • Water leak detector (normally-open): open when dry, closed when wet (leak detected)
The engineers’s first attempt is shown here, but it contains a serious error. Identify and correct this error:
Answer :
The Oil_press_low contact instruction should be drawn as normally-open rather than normally-closed as shown in the engineer’s first draft of the PLC program.
The program is designed to shut down the motor if ever the Shutdown bit goes to a 0 state. This means the motor will shut down if any of the permissive contact instructions become uncolored (i.e. fails to “conduct” virtual power).
We have been told that the real-world oil pressure switch is NO, which means its contact opens when oil pressure becomes too low. This means a low oil pressure condition causes that bit to be 0, which necessitates an NO contact instruction so that it will un-color under that condition.
More PLC Questions :
PLC Programming Questions & Answers – 1
PLC Programming Questions & Answers – 2
PLC Programming Questions & Answers – 3
PLC Programming Questions & Answers – 4
PLC Programming Questions & Answers – 5
PLC Programming Questions & Answers – 6
PLC Programming Questions & Answers – 7
What is SCADA System?
Calculate Process Temperature using a Thermocouple
What is Rewire Tool in Simatic Manager?
ControlLogix Architecture – Rockwell Automation
Indentify Faults in Simple Lamp Circuit including Failed Wires
How to use Converters in PLC
Your First Steps Through STL Language
Problem with Sump Tank Level Transmitter
Which Connection is Best for PLC? – Sinking or Sourcing
How to Work with Allen Bradley RsLogix Emulator?
How to Control VFD with PLC using Ladder Logic
Create an Application in HMI using Tia Portal
Practical Control Systems Questions & Answers
Practical Process Control System Questions & Answers – 1
Ladder Rung with Two Outputs
PLC Multiple Outputs Configuration
GSD File installation in Simatic Manager
How to Install GSD File in Step 7 PLC using Simatic Manager?
HMI configuration for Delta VFD
Modbus Communication between Delta PLC with VFD
Difference between Signal Cables and Control Cables
Ladder Logic Programming Examples
Faceplate in WinCC
Siemens HMI Training – Using UDTs with Faceplates
Open Circuit without Freewheeling diode
Freewheeling Diode Working Principle
device-specific-diagnostics-to-ne107-status-signals
NAMUR NE107 Standard
Structured Text Automatic Gate Logic
Structured Text PLC Programming for Automatic Gate Control
Induced Draft Cooling Tower
Cooling Tower
Boiler Intelligent Control Cabinet
IoT based Smart Boiler Control System with Cloud PLC and SCADA
Instrumentation Cables Questions Answers
Instrumentation Cables Questions & Answers
Which instrument is faulty
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Electrical Power Grid Automation
